BAKFlip MX4 Tonneau Cover Installed
Discussion in 'Tonneau Covers, Caps and Shells' started by John3976, Aug 18, 2023.
  1. Aug 18, 2023 at 2:44 PM
    John3976
    John3976 [OP] Well-Known Member
    Bill
    2023 Tacoma SR 2.7 4x4
    I just installed a BAKFlip MX4 Tonneau cover on my 2023 Toyota Tacoma SR Access Cab 2.7 4x4. Install was not had took about an hour and a half total, the BAK rail system reuses the tie down rails so you don't lose them. The tie down rails are moved down about 1 1/2 inches. I have now owned four BAKFlip MX4 Tonneau covers and have had good experiences with each of them.
    I like how the BAKFlip MX4 sits flush with the bed rails. Because I have an access cab with the long bed this tonneau cover has four panels instead of the three panels the short beds have.
    I recommend the BAKFlip MX4 covers because of the quality of them and the ease of installation. I did one thing different on the install, instead of running water drain hoses through the bottom of the bed I drilled the holes in the side and ran the hoses through the side and down. I have the OEM rubber bed mat and if you run the hoses do the floor and drill out the factory drain hole you will have to also drill or notch the rubber bed mat.
    Here are three photos of the MX4 closed:
    71408402933__A7157B16-A5DA-44BF-AB94-4AE5FD807F9D.jpg 71408400385__9C950D4E-00AC-461A-9367-06E4333F0D23.jpg 71408401590__10A0FFEC-898B-4ECE-920A-2622B5F45DA8.jpg
    LukeLifts and LeakyAC like this.
  2. Aug 20, 2023 at 5:51 PM
    CraigTacoCanada
    CraigTacoCanada New Member
    Craig
    2023 Red Tacoma 4x4 TRD Sports Premium
    Looks great....what does it look like folded up?
  3. Aug 20, 2023 at 5:51 PM
    CraigTacoCanada
    Craig
    and when folded up, does it lock up?
  4. Aug 20, 2023 at 6:04 PM
    Merling
    Merling Well-Known Member
    James
    NH
    2021 Black Tacoma TRD OR
    RCI IFS Skid Eibach Stage 2 Explore Overland Sliders
    It has clips to secure it folded until the last panel. If you have it fully folded you can lock it up with what look like struts. But they aren’t, it’s a rod that goes in and then you tighten to keep it secure
  5. Aug 20, 2023 at 6:30 PM
    Billpro215
    Billpro215 Member
    Bill
    I have the same BAKFlip as you being installed in 2 weeks. Not doing it myself only cause I don’t want to. With that said I wonder if you could show me a pic of where you put your drain hose. I don’t really want to deal with the bed mat.
    I seen your post right after I ordered mine and watched an install Vedic. Could have done it my self but! Don’t feel like it. Although I was thinking of telling then not to drill the drain hoses and I will route them myself.
    Thank you
  6. Aug 20, 2023 at 7:03 PM
    Merling
    James
    NH
    some people, myself included, got a barbed hose adaptor at like lowes that fits like perfectly down the drain holes already in the bed. I drilled a hole in my bed mat and it keeps the drains from moving. The hole needed to fit it is really small
  7. Aug 20, 2023 at 7:26 PM
    Billpro215
    Billpro215 Member
    Bill
    I understand what you are referring to. Plumber by trade. That would work. I was just curious as to how the OP did his.
    Merling[QUOTED] likes this.
  8. Aug 20, 2023 at 7:39 PM
    Merling
    James
    NH
    Just don’t drill into your gas tank lol
  9. Aug 20, 2023 at 8:02 PM
    Billpro215
    Billpro215 Member
    Bill
    why not lol. Measure twice. Drill once. I would defiantly check what’s on the other side. I’ve had electricians drill thru my water lines cause they don’t check the other side of the juice.
  10. Aug 20, 2023 at 8:13 PM
    LeakyAC
    LeakyAC Captain jackass
    2016 SR5 Access Cab 2.7 4x4 Super White II
    -Uni filter secondary air pump mod -A/C drip line extension mod -ARB F + R diff breathers relocated -ARB front recovery point -"Tow Package" class V receiver + oem 7/4 plug + aux ATF cooler -Toyo Open Country ATIII 245/75R16 -Yellow fog lights (amber Lamin-X w/ PIAA amber H16s) -BakFlip G2 tonneau cover -TRD Pro grille -Body-matched bumper caps -Blackout emblems -Husky X-Act Contour floor liners -RokBlokz mud flaps -oem bed mat Not yet installed: -0" lift Bilstein 5100 F + R w/ 4Runner front shock lower bolt swap -Total Chaos LCA cam tab gussets
    These are great imo
  11. Dec 13, 2024 at 5:30 AM
    pete2734
    pete2734 Member
    Pete
    Fresh Meadows, NY
    If you use the drain holes already in the bed for the drain tubes coming from the tonneau cover; then, if water happens to get into the bed will that prevent it from draining out? Or do the tonneau cover drain tubes do a good job keeping water out of the bed?
  12. Dec 14, 2024 at 6:05 PM
    Merling
    James
    NH
    I never had an issue with water that got into the bed not draining from when I had the cover
    pete2734[QUOTED] likes this.
  13. Dec 14, 2024 at 6:26 PM
    OLDTRAP
    OLDTRAP Well-Known Member
    2021 TRD OR Super White
    Stock
    Best looking cover hands down, congrats. I'm almost ready to pull the trigger on one. Mind saying what you paid for it?
  14. Dec 14, 2024 at 6:30 PM
    Merling
    James
    NH
    1000$?
    Like 2-3 years ago tho
    OLDTRAP[QUOTED] likes this.
  15. Dec 15, 2024 at 5:12 AM
    pete2734
    pete2734 Member
    Pete
    Fresh Meadows, NY
    $1199 delivered from Walmart one year ago.
