Bakflip G2 cover review
Discussion in 'Tonneau Covers, Caps and Shells' started by rbark11, Nov 4, 2016.
  1. Nov 4, 2016 at 10:32 PM
    rbark11
    rbark11 [OP] Well-Known Member
    Bay Area, CA
    Just bought a new '17 tacoma, and looking to get a hard, folding cover for the bed. Right now I'm leaning towards the Backflip G2 cover. Just wondering if anyone can share their experiences with that cover.
  2. Nov 4, 2016 at 10:45 PM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    Have you considered getting an OEM one?
  3. Nov 5, 2016 at 7:45 AM
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
  4. Nov 5, 2016 at 8:05 AM
    anonemoose
    anonemoose Well-Known Member
    Bill
    Big Pine, Calif
    2015 White TRD Sport V6 DCSB
    Ride-Rites, Everything Weather-Tech Makes Added some 12 volt outlets with relays
    I bought the BakFlip fibermax, loved it, stronger if you are putting weight on top of it. Only down side was the rails were made like crap. First set, driver side was bent bracket and passenger side - seems like they did not deburr the holes and the support bracket was off angle. They sent two more sets, now the driver's side was good but the same issue on the passenger side, and that support was bent in addition. Gave up, drilled out the pop rivets, cleaned the burrs, used the bracket from the first set, all was good. Got to be an expert at mounting and mounting it, aligns easily, very water proof.
    Hated to sell it but ended up needing more room for camping stuff, the Tacoma's bed is not very deep. Oh, attached to the rails so use loose the tie downs, I made a small slider, treaded it and put in an eye bolt, worked well as a replacement.
  5. Nov 5, 2016 at 5:48 PM
    rbark11
    Bay Area, CA
    I have looked into that a bit, but I read somewhere that this cover requires you to cut into your bed rails, which I would try to avoid.
  6. Nov 5, 2016 at 6:04 PM
    tomwil
    East Coast USA
    2014 Reg Cab 4x4
  7. Nov 29, 2016 at 4:16 PM
    Niner1969
    Niner1969 Well-Known Member
    2016 tocoma sport
    Seats
    Check out the undercover Flex Tonneau. It looks the same as a backflip. And it's cheaper
  8. Nov 29, 2016 at 4:16 PM
    Niner1969
    2016 tocoma sport
    Seats
    I will be putting mine on soon
  9. Dec 4, 2016 at 3:56 PM
    Bocsy44
    Bocsy44 Well-Known Member
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    This that and the other thing.
    got the fibermax, no major complaints, works great and didn't run into any issues. no major water gets in, a little depending on the angle I'm parked and the direction of the wind. I didn't install it myself. the only thing I was a little disappointed with was the fact it didn't come with straps to secure the final fold without standing it up on end like it said it would in the catalog but there was at least some d rings for me to throw a rubber bungee on if need be.
  10. Nov 12, 2017 at 8:36 PM
    LDL
    LDL Well-Known Member
    San Diego, CA
    2017 Tacoma 4x4 DCSB
    Air conditioning, floor mats, seat belts
    So I bought the Bakflip G2 tonneau cover brand new from this seller on eBay
    https://www.ebay.com/itm/Bakflip-G2...e=STRK:MEBIDX:IT&_trksid=p2060353.m1438.l2649
    I mention this, bc it was $120 less (shipped) than other sites like autoanything.com and bakflip.com. Shipping was fast, I ordered on a Friday and got it by Tuesday.
    I just installed the Bakflip G2 tonneau cover a wk ago. Installation was straightforward, no issues. It looks good.... but I washed my truck today with a pressure washer and noticed some leakage in the truck bed even with the drainage tubes provided. Nothing major, others on TW have the same issue with this model. I live in SoCal, so it should be okay for me.
