Baja Designs Squadron Sport ditch lights driving/combo lens vs. spot lens
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Taco dv, Feb 2, 2025.
  1. Feb 2, 2025 at 4:25 PM
    Taco dv
    Taco dv [OP] Well-Known Member
    2020 Tacoma TRD off-road
    Just installed Baja Designs sport ditch lights on my white truck. I have the yellow driving/combo lens and hood glare is bad. Was wondering if a spot lens would help with hood glare because of the tighter beam pattern not reflecting off the hood so much. Thoughts? Angling them more out to the side doesn’t help much. I’m actually thinking of ditching the ditch lights, no pun intended.
  2. Feb 2, 2025 at 5:01 PM
    Midnight beauty
    Midnight beauty Well-Known Member
    White mountains AZ
    2020 midnight black Tacoma TRD Sport
    I have the same lights on a midnight black 3rd gen but with the clear lens and I bought the amber covers and painted the edges flat black and that cut down on the glare quite a bit. Still has glare but not as bad.
  3. Feb 2, 2025 at 6:08 PM
    Veet-88
    Veet-88 Well-Known Member
    18 Tacoma DCLB sport
    Spot will always be better but I have the squadron pro combos and I found the glare very manageable. Scooped or flat hood?
  4. Feb 2, 2025 at 6:17 PM
    Taco dv
    Flat hood. 2020 TRD OFF-ROAD. Truck was waxed recently and hood is real shiny.
  5. Feb 2, 2025 at 6:19 PM
    Veet-88
    Flat hood is likely a good part of the difference i get nothing ontop of the scoop.
  6. Feb 2, 2025 at 6:21 PM
    4x4junkie
    4x4junkie Well-Known Member
    So Calif. (SFV)
    2018 TRD Sport ACLB MT
    That's just part of the deal with lights mounted like that (same goes for overhead lights that also reflect off the hood). Darker-colored vehicles (or hoods) will have an easier go of it. Otherwise, the only sure-fire way around this is to mount the lights at the corners of your front bumper.
  7. Feb 2, 2025 at 6:23 PM
    BigTang
    BigTang Well-Known Member
    C
    2022 SR
    ppf on the hood
    Veet-88 likes this.
  8. Feb 2, 2025 at 6:27 PM
    Veet-88
    Should be noted above flat finished ppf does better than a gloss
    BigTang[QUOTED] likes this.
  9. Feb 2, 2025 at 6:34 PM
    BigTang
    C
    2022 SR
    i was going to recommend the matte but its kinda awkward looking unless you use it for a ghost pattern or more than just the panel.
  10. Feb 2, 2025 at 7:05 PM
    Willy Lump Lump
    Willy Lump Lump Well-Known Member
    21’ dcsbmt
    This and that
    You could get a cascadia 4x4 solar panel… they cut down glare. Of course the sun hits the rest of the hood.
  11. Feb 2, 2025 at 7:45 PM
    Veet-88
    This route gains the most broverland points. Buddy actually has one works quite well for changing and anti glare
  12. Feb 2, 2025 at 7:53 PM
    Willy Lump Lump
    21’ dcsbmt
    This and that
    Damn… I’ve got a lot of broverland points:anonymous:
  13. Feb 2, 2025 at 8:47 PM
    Veet-88
    I wish I had more broverland points. Especially with the truck in stripped down winter mode.
  14. Feb 3, 2025 at 9:40 AM
    Baja Designs
    Baja Designs The Scientist of Lighting Vendor
    San Marcos, CA
    The Spot will definitely help minimize the glare but just due to the placement it's unavoidable. I personally switched mine to a spot amber which still glares on the hood but is not as harsh as clear light. Or you can also just move the lights lower.
    https://www.bajadesigns.com/products/squadron-light-pod-lens-kit/?sku=668411
    Best,
    Brahian Herrera| Forum Sales & Support
    Email: brahianh@bajadesigns.com | Phone: (760) 560-2252
    Taco dv[QUOTED][OP] likes this.
  15. Feb 3, 2025 at 10:12 AM
    Taco dv
    Is it typically better to run spot lenses up high, like ditch lights, and have wider beam patterns down low on the truck?
  16. Feb 3, 2025 at 10:22 AM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    Is no one going to point out that DITCH lights are called DITCH lights cause they are supposed to be pointed towards the DITCH, lol? I've got wide cornering lenses on my BDs, they give a great wide view from shoulder to shoulder pretty much even with my A-pillar. I had missed side trails before when offroad at night before getting these installed. For driving lights, down in the front bumper keeps them from reflecting on your hood. As offroad lights, I think ditch lights are the most important of all. I'm usually not doing high speeds, just slow offroad, and the WIDE view has been indispensable.
  17. Feb 3, 2025 at 11:03 AM
    Taco dv
    I understand they are called ditch lights for a reason. I tried aiming them out to the sides but still lots of hood glare. So in effort to make them usable (as far as hood glare), I’m thinking of using a spot pattern for the ditch lights for a distance light, and my fog lights for the wide beam to light up the sides. I’ve heard it’s better to keep the wide beam patterns down low, such as grill or bumper, and spot patterns up high, as in hood or roof area. Any opinions on this?
  18. Feb 3, 2025 at 11:21 AM
    Veet-88
    I would say it all lands on intended use. I use mine to widen my high beams at distance for better deer detection on back roads. I have been debating s2's off my roof rack to act as proper "ditch" lights but have yet to bother with it as it already looks like a Christmas tree.
    Close ditch far ditch it all still counts
    YF_Ryan[QUOTED] likes this.
