Baja Designs S1 | Over 2k Lumens from a single LED light
Discussion in 'Lighting' started by Baja Designs, Sep 14, 2019.
  1. Feb 6, 2020 at 2:41 PM
    #121
    bigztaco
    bigztaco Well-Known Member
    '19 MGM TRD
    Icon 2.5" FR and Icon rear leafs w/2.0"
    Just got delivered today...
    If only there were rock covers for them.
    tony453rd, lynyrd3 and CttAznRanger like this.
  2. Feb 6, 2020 at 7:25 PM
    #122
    brentano
    brentano Well-Known Member
    2017 TRD OR AC SSM
    I configured a Spot and an Amber wide on two separate SwitchPro 9100 switches. The S1's are resting on Rago Low Pro stainless mounts. High beams will trigger both lamps.
  3. Feb 6, 2020 at 7:27 PM
    #123
    Rome604
    Rome604 I am the Captain now
    Dave
    Alexandria, VA
    2023 TRD Pro Sequoia
    Interesting choice. How come you went with two different patterns/colors?
    lynyrd3 likes this.
  4. Feb 6, 2020 at 7:35 PM
    #124
    brentano
    2017 TRD OR AC SSM
    Camping with a truck camper is focused on the passenger side (the awning is on this side). A dimmed amber provides appropriate camp lighting.
    The driver side is for spotting/rescue. The SwitchPro effectively creates two distinct lighting systems.
    lynyrd3 likes this.
  5. Feb 10, 2020 at 5:16 PM
    #125
    Baja Designs
    Baja Designs [OP] The Scientist of Lighting Vendor
    San Marcos, CA
    The S1 with Wide/Cornering pattern will get you out 200-300 feet. The S1 Spot will get you a few hundred feet of usable light beyond the 300 foot range.
    CttAznRanger likes this.
  6. Feb 14, 2020 at 8:17 AM
    #126
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    Quick question for you guys. Or maybe a few.
    What’s the lower Voltage threshold on the S1’s? I installed some wide cornering ones on my bike’s crash bars and I have a Denali Electronics CANSmart that I can use to control intensity. I need to hook it up and play with the setting to see what the voltage output is at different intensity settings. I’d like to make sure they work, if not I guess I’ll be running at 100%.
    I have them wired up right now to a switch only and not connected to the CANSmart
    I did have to order some extra connectors though to make a pigtail to go between the Denali harness and the BD connectors. More to follow.
    BEA6FB70-C175-4259-8878-7815447341F3.jpg 7E79D749-9C6F-4FA9-8B6F-A4D689D55091.jpg
  7. Feb 14, 2020 at 10:25 AM
    #127
    nvnv
    nvnv Stop geotagging
    Connor
    2016 Tacoma TRD OFF ROAD
    I don’t know what the actual voltage threshold is but my SwitchPro will dim down to 10% and they still work fine. I’m not sure how that 10% converts to actual voltage. I would assume it would be about 1.5 volts?
  8. Apr 8, 2020 at 5:21 PM
    #128
    Nick1992
    Nick1992 Well-Known Member
    Nick
    2017 Tacoma
    Not the best shot, but running a set of amber wide S1s off the back off my roof rack! Absolutely love them. (I went with the white housing with amber wide lens)
  9. Aug 6, 2020 at 8:43 PM
    #129
    taco2uesday
    taco2uesday Well-Known Member
    1999 Tacoma SR5 TRD 5 Speed
    Map Lights, Grey Wire Mod,
    Are there any discount codes for tacoma world when ordering direct? Looking to get the S1's. Thanks
    Baja Designs[OP] likes this.
  10. Aug 7, 2020 at 7:38 AM
    #130
    Baja Designs
    San Marcos, CA
    BD10off :) We also have a free shipping promotion going on for orders above $100.
  11. Aug 7, 2020 at 7:44 AM
    #131
    Tacospike
    Two Trucks
    Hey BD, what are the plug types for these S1's? I have some current rear POD's and wondering if I could just swap the lights with these in the current wiring or if I would need to run new wiring harness?
  12. Aug 7, 2020 at 7:45 AM
    #132
    Baja Designs
    San Marcos, CA
    We use a two pin weather pack connector on the S1s. What's the amp draw of your current auxiliary lighting?
    Tacospike[QUOTED] likes this.
  13. Aug 7, 2020 at 7:47 AM
    #133
    Tacospike
    Two Trucks
    • Amp Draw: 2
    • 27 Watts
  14. Aug 7, 2020 at 7:48 AM
    #134
    Baja Designs
    San Marcos, CA
    Perfect. The S1 takes up 20 watts/1.45 amps each. You should be good! :thumbsup:
  15. Aug 7, 2020 at 7:49 AM
    #135
    Tacospike
    Two Trucks
    Sweet!. Thank you!
  16. Aug 7, 2020 at 7:50 AM
    #136
    Baja Designs
    San Marcos, CA
    When you purchase any of our LED lights, they do come with the opposite connector in case you need to utilize a current harness. FYI
  17. Aug 7, 2020 at 8:33 AM
    #137
    taco2uesday
    @Baja Designs Thank you! I got impatient and ordered the S1's last night. Still need to find a slim 20 light bar so Ill remember the code.
    Rome604 and Baja Designs[OP] like this.
  18. Aug 19, 2020 at 9:42 PM
    #138
    OffroadAlliance.com
    OffroadAlliance.com Well-Known Member Vendor
    Brockton, MA
    2018 Tacoma TRD Pro
    We absolutely love the S1's! They might be small, but they pack a punch. We've had great results using them for all kinds of applications from fog lights, to ditch lights to reverse lights. Here's a pair in wide cornering:
  19. Aug 19, 2020 at 9:56 PM
    #139
    Rome604
    Dave
    Alexandria, VA
    And I absolutely love Offroad Alliance. Anyone looking to buy parts for their Tacoma should hit them up. I bought my Prinsu through them and loved the customer service.
  20. Aug 21, 2020 at 4:07 AM
    #140
    Xringer07
    Xringer07 Member
    Justin
    2012 TRD Sport DCLB
    I installed a set of S1 Flush Mounts in Work/Scene pattern in the bumper of my '12 TRD Sport. Install wasn't bad although I used an Air on Board switch instead of the one that came on the BD harness.
    These things are ridiculous for their size. The Work/Scene pattern is perfect for a rear/backup light. I was back and forth with the Wide Cornering, but I'm glad I went with the Scene. The periphery is fantastic.
    20200821_065108.jpg 20200821_065146.jpg 20200821_065026.jpg20200811_213855.jpg20200811_213827.jpg 20200821_065920.jpg
    I couldn't be happier with the end result! Now just need a set of the S1 Pods for ditch lights lol
