Baja Designs - 30" S8 LED Light Bar Mount Kit - 3rd Gen ORDER NOW !!!
Discussion in 'Lighting' started by Baja Designs, Nov 3, 2016.
  1. Nov 3, 2016 at 3:21 PM
    Baja Designs
    Baja Designs [OP] The Scientist of Lighting Vendor
    San Marcos, CA
    [​IMG]3rdGen30 by Baja Designs, on Flickr
    *Minor Trimming Required
    Baja Designs - 30" S8 LED Light Bar Mount Kit - 3rd Gen (16-18) ORDER NOW !!!
    https://www.bajadesigns.com/products/Toyota-Tacoma-30-S8-16-Grille-Mount-Kit.asp
    This kit allows our 30" S8 LED Light Bar to sit nicely in the OEM bumper opening. This fits nicely in the 3rd Gen (16-18) Tacoma. Please enter code BDForums to order with Forum Discount
    $89.95 ------ $80.95
    - S8 30" LED Light Bar
    https://www.bajadesigns.com/products/S8-30-Inch-LED-Light-Bar.asp
    $849.95 ------ $764.96
    - Wiring Harnesses:
    On/OFF ONLY
    https://www.bajadesigns.com/products/onx6-s8-xl-pro-sport-harness-2-light-max-150-watts.asp
    $24.95 ------ $22.45
    On/OFF/Mode (2 Switches - 1 Amber Backlight - 1 On/OFF)
    https://www.bajadesigns.com/products/s8-ir-wire-harness-w-mode-2-bar-max-325-watts.asp
    $74.95 ------ $67.45
    - Security Hardware (Replaces Stud on End Cap)
    https://www.bajadesigns.com/products/onx6-s8-xl-xl-r-pro-sport-security-hardware-kit.asp
    $19.95 ------ $17.95
    www.bajadesigns.com - Code: BDForums
  2. Nov 7, 2016 at 9:52 AM
    Baja Designs
    San Marcos, CA
  3. Nov 8, 2016 at 4:01 PM
    Baja Designs
    San Marcos, CA
    These kits started shipping today. Get yours now and be completely setup for your next trip!
  4. Nov 8, 2016 at 4:08 PM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    i want one! i dont even own a 3rd gen
  5. Nov 8, 2016 at 4:09 PM
    MattJakobs
    MattJakobs Everything but a Tacoma
    Matthew
    NorCal
    1985 4Runner w/ FlipPac
    You won't
  6. Nov 14, 2016 at 10:02 AM
    Baja Designs
    San Marcos, CA
    Time for an upgrade :thumbsup:
    these kits are in stock and ready to ship!
  7. Aug 8, 2017 at 5:15 PM
    Glenn_R
    Glenn_R The Unicorn Turd Gen
    Glenn
    17 Tacoma DCSB OR Inferno
    Hi Bailey,
    Is there an installation guide for the brackets or pictures of it installed with the grill removed? I have a winch and want to see if it will still work. Looks like it would but can not see what the bracket bolts to.
    Thanks Glenn
  8. Aug 9, 2017 at 8:09 AM
    Baja Designs
    San Marcos, CA
    Glenn,
    Attached are the installation instructions. I do not have any photos without the grille installed. If you have any specific questions give us a call at (800)422-5292.
    Thank You,
    Bailey, Baja Designs
  9. Oct 12, 2017 at 1:46 PM
    itsraymondang
    itsraymondang Spam King
    Houston, TX
    2017 White TRD Sport DCSB
    Does it only work with your light bar? Or I an use it on any other 30”
  10. Oct 12, 2017 at 2:19 PM
    Baja Designs
    San Marcos, CA
    This was designed specifically for our S8 30" LED Light Bar. It will not work with any other light bars. Thanks!
    -Bailey, Baja Designs
    bailey@bajadesigns.com
  11. Oct 12, 2017 at 9:40 PM
    itsraymondang
    Houston, TX
    Is there a way to take the entire plastic thing off of the truck to have a clean cutting job?
    I do not want to cut it while it’s on the truck as I feel it’ll be restricted
  12. Oct 13, 2017 at 7:50 AM
    Glenn_R
    Glenn
    You can it is part of the bumper cover. If you look at some slim line front pumper threads there are a few videos on how to do it. It is some work though. Having done the bumper install I can tell you I would cut the plastic out on the truck.
  13. Jan 18, 2018 at 2:41 PM
    Baja Designs
    San Marcos, CA
  14. Feb 17, 2018 at 1:52 PM
    Minimedic
    Minimedic Well-Known Member
    Tacoma DCLB OR MGM
    I don’t know if it’s been asked before but I’m assuming that I can’t fit an onx6 bar with this same bracket on 17 Tacoma
  15. Apr 29, 2020 at 11:50 AM
    msgs350
    msgs350 Well-Known Member
    PNW
    2020 Tacoma OR Cement DCSB 4x4 AT
    Some Mods
  16. Apr 29, 2020 at 1:28 PM
    Baja Designs
    San Marcos, CA
    That would be our clear lens. :)
