badland offroad jack?
Discussion in 'Off-Roading & Trails' started by TacoTuesday1, Feb 8, 2023.
  1. Feb 8, 2023 at 10:36 PM
    TacoTuesday1
    TacoTuesday1 [OP] Well-Known Member
    FL
    Thing looks pretty sick
    you getting it? Where/how will you mount it?
    The one time I tried using my previous Arcan ALJ3T "3 ton high lift quick rise" it didn't even reach up to the truck...
    It was aluminum and lighter though, I'll give it that. Even the Arcan hybrid steel/aluminum weighs barely more than all aluminum, but much lighter than all steel competitors if not half the weight; not sure how the Badland is
    That would be awesome if this thing is light enough to keep in the truck; maybe a well-tinted shell and bike cable lock
    Unless a hi-lift is enough; that I already have (48") with 360deg armor to lift from
    but that can be tricky. If you're in a narrow garage, there's no space on the side to be cranking the lever of a hi lift
    or other uses for a conventional floor jack
    Ricardo13x likes this.
  2. Feb 9, 2023 at 4:07 AM
    RockfishTaco
    RockfishTaco Well-Known Member
    Nate
    Massachusetts
    I bought one a few weeks ago because I was sick of using blocks of wood to get the front of my truck off the ground… love it. My neighbor came by and saw it, went out and bought one the next day.
    I plan on making a mount for it in the bed of the truck once I get around to it..
    my only complaint is you can’t lock the wheels so the thing just rolls around if you just leave it in the bed and not on it’s side.
    TwistedOmYoga likes this.
  3. Feb 9, 2023 at 11:26 AM
    TacoTuesday1
    FL
    what kinda mount you gonna make
    I see there’s pro eagle off road jack mounts but they’re like $300, ouch
    thing could probably be secured decently with some creativity using bungee cords or ratchet straps
    Maybe to bed rails, existing cargo hooks, or adding more cargo hooks
    I did the sprinter van/MOPAR D-ring mod (adds D-rings to bed bolts) when I ran a bed mat, cut holes in it with hole saw
    But now I have a bedrug covering them; maybe I need to cut holes in that too
    that might work to secure it
  4. Feb 9, 2023 at 12:05 PM
    BigCountry762x39
    BigCountry762x39 Well-Known Member
    TL
    PNW, Oregon!
    2009 Tacoma, with the cool white paint peel
    Arb Deluxe bull bar Front Bumper Ironman4x4 12k winch synth line AFE Intake OME 2.75in Dakar Leaf springs (R) Fox 2.0 bypass shocks (R) Bilstein 6112 (F) 33's on KMC wheels off road lighting comfort mods Redrock HD roof rack Retevis rt95 Radio Slotted Rotors and HD pads
  5. Feb 9, 2023 at 12:15 PM
    BKinzey
    BKinzey Well-Known Member
    Beauford
    Hollywierd, CA
    2015 White Tacoma Access Cab TRD Off Road 4x4 V6
    RCI aluminum front skid, SnugTop, Sliders, bedside supports, LED interior, CaliRaised fogs & brackets, rear diff breather mod, DIY bed platform
  6. Feb 9, 2023 at 12:23 PM
    RockfishTaco
    Nate
    Massachusetts
    I was planning on copying proeagles a little bit with aluminum and just mounting it close to the tailgate on the floor of the bed. Have a family member that works with aluminum and was going to run it by him.
  7. Feb 9, 2023 at 12:35 PM
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    https://ac-fab.com/products/badlands-3ton-mount
    RockfishTaco likes this.
  8. Feb 9, 2023 at 12:45 PM
    TacoTuesday1
    FL
    thanks
    just found this only $60 shipped
    https://www.911motorsports.net/Vehi...Jack--Harbor-Freight-Mounting-kit_p_1117.html
    I wonder a good way to put it secure and tucked away in the bed with a camper shell
    as opposed to welding a mount vertically to a tire swingout, which
    1) requires a swingout not everyone has
    2) leaves the jack exposed and visible to thieving eyes as well as weather corrosion
    strapped to a MOLLE panel might be a good way
    RC and Hooke Road probably the cheapest source on MOLLE panels
    5B880556-0B7D-4A28-8B75-7DC1F31FCA60.jpg E6DE201C-412A-45E4-942E-45394D9466F5.jpg
  9. Feb 9, 2023 at 12:51 PM
    RockfishTaco
    Nate
    Massachusetts
    Yeah never mind I’m just buying a mount. I figured someone would put something out there
  10. Feb 9, 2023 at 12:52 PM
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    My only option is the one i posted since i have a full drawer system and fridge in the bed. Ill have to mount on my swing arm but that's a good option for those that have an open bed.
  11. Feb 17, 2023 at 3:06 PM
    TacoTuesday1
    FL
    step 2 determine mount and security pending
    thing makes my previous Arcan look like trash
    Lighter than I thought it’d be
    still need to tighten the holder bracket and make sure the fluid is topped off, bled, and working
    Probably isn’t ready to go as I know that’s how my old Arcan came when it was new (dry of fluid)
  12. Feb 17, 2023 at 3:12 PM
    Ricardo13x
    Ricardo13x YT: @UrbanOpsOffRoad IG: @urban.ops.offroad
    Upland, CA.
    05 OR DCSB ProRunner(4x4 conv.), Chevy 63”s, NWF EcoCrawler, 35”s
    Random stuff. Oh! and converted to non ADD 4x4.
  13. Feb 17, 2023 at 3:14 PM
    Ricardo13x
    Upland, CA.
  14. Feb 17, 2023 at 4:14 PM
    BigCountry762x39
    TL
    PNW, Oregon!
    how big is that thing!? looks like its bigger then my ARCAN
    could you throw a 2nd D ring on that bed bolt on the back on one of the sides and tuck the jack along the side of the bed?
    Ricardo13x[QUOTED] likes this.
  15. Feb 17, 2023 at 4:20 PM
    Ricardo13x
    Upland, CA.
    31 3/4”
  16. Feb 17, 2023 at 4:44 PM
    Ricardo13x
    Upland, CA.
    And yeah easily you could do the extra d ring. As you can tell all my bed bolts have anchor points.
  17. Feb 18, 2023 at 3:01 AM
    ClassyTacos
    ClassyTacos National Treasure 3, Times a ticking Nickolas
    Papalote
    Florida
    2017 TRD Sport 4x4
    Stockish
    TwistedOmYoga and Ricardo13x like this.
  18. Feb 18, 2023 at 9:51 AM
    Ricardo13x
    Upland, CA.
    Hell yeah new sub to support the boys!
    ClassyTacos[QUOTED] likes this.
  19. Feb 19, 2023 at 5:16 AM
    cpc
    cpc Well-Known Member
    MASS/ESSEX COUNTY
    TRD PRO
    cbi front receiver, rigid lights, leitner designs, mobtown sliders, Brute Force Fab
    aluminum angle originally bolted in the bed with a Titan strap. Lift onto tailgate then roll to front of the bed, pull handle down to lift front wheels over wheel stop then strap down. Love my Pro Eagle.
  20. Mar 20, 2023 at 5:55 AM
    bboggio28
    bboggio28 Well-Known Member
    2020 TRD Sport
    i have mine "mounted" in the bed of my tacoma, kinda. i slapped together a little 2x4 box so that groceries wouldn't slide around and also to hold gravel bags in winter for added bed weight. fortunately for me, the dimension from the front of the wheel well (DCSB) to the back is roughly the length dimension of the badlands jack. you can lay the handle pieces in front of it as an added wedge. the outside tire fits in the grooved bed liner too to prevent lateral shifting. then i just slapped a bungee chord around it. But this spring i am taking a look at the bed layout again as i want to add a horse stall mat on the floor and redo my grocery bin.
