Bad u-joint?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Slend96, Oct 13, 2024.
  1. Oct 13, 2024 at 3:43 PM
    Slend96
    Slend96 [OP] Member
    09 Reg Cab
    Hey tacomaworld. Just started hearing this squeak only when rolling slow, under 10 mph. Goes away when clutch is depressed. Any thoughts? Thanks.
    https://youtu.be/vgN4Y_4VyYQ
  2. Oct 14, 2024 at 8:44 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I would say U Join or center bearing...
    Visually look for dry rusty powder around the joint caps.
    Remove shaft and manipulate all joints feeling for excessive looseness or tighness.
    Do them all 3 joints and center bearing.
  3. Oct 14, 2024 at 1:55 PM
    Slend96
    Slend96 [OP] Member
    09 Reg Cab
    Hey thanks for the reply. Ya, definitely has a dry rusty powder around a most of the u-joints. Can’t manipulate the joints by hand and haven’t tried with a screwdriver. More grease does nothing. Regular cab, so just the two without the bearing I believe?
    Jimmyh likes this.
  4. Oct 14, 2024 at 2:29 PM
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    Where does the grease come out when you hit it with a grease gun? Sometimes the passages get clogged in old u-joints and grease can't get to where it needs to. Removing the zerk on each u-joint, picking out the crusty old grease and even hitting with a torch to liquify the crud will help get fresh grease in there and that can buy you a little time.
    Really, though, it sounds like you need to pull the drive shaft and service it with new u-joints and a new carrier bearing.
    Slend96[OP] likes this.
  5. Oct 14, 2024 at 2:59 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Yeah. You got bad universal joints.
    Replace them all as the others are probably bad also.
    Slend96[QUOTED][OP] likes this.
  6. Oct 14, 2024 at 3:12 PM
    Slend96
    Slend96 [OP] Member
    09 Reg Cab
    The grease comes out of a couple of the caps of the u-joints, not all and back out of the fitting. Definitely going to pull it apart and put new ones in, they have been neglected. Hopefully that is the squeal.
    Actually have been chasing a smell for a couple months and after I crammed the joints with lube I could see the grease splattering onto the exhaust just now. So probably was that but to a lesser degree over time.
  7. Oct 15, 2024 at 9:53 PM
    FJC MAN
    FJC MAN Active Member
    Bill
    2007 FJ Cruiser
  8. Oct 15, 2024 at 9:54 PM
    FJC MAN
    Bill
    2007 FJ Cruiser
  9. Oct 18, 2024 at 2:34 PM
    Slend96
    Slend96 [OP] Member
    09 Reg Cab
    That was it, no more squeak. One of the caps wasn’t getting grease and the pins were non existent. Press made it easy.
    DesertRatliff and Jimmyh like this.
