Bad Timing Belt Symptoms?
Discussion in '1st Gen. Tacomas (1995-2004)' started by hedricksan, Feb 29, 2012.
  1. Feb 29, 2012 at 12:10 PM
    hedricksan
    hedricksan [OP] New Member
    Brent
    Athens
    04 Prerunner
    What should I watch for to know the timing belt is ready to blow? I know I'm close to the 90,000 recommended replacement mark, but money-wise, the later I do it the better...someone told me look for antifreeze spatter? I don't understand the relationship between the two.. thanks
  2. Feb 29, 2012 at 1:50 PM
    buzzard1992
    buzzard1992 Yep
    Alex
    Summerville, SC
    01 4wd trd, 255/85/16 km2s
    5100's with eibachs. And 255/85/16 km2s
    I'm havin the same worries. I'm very worried about mine since I just bought the truck with 137,xxx. The guy I bought it from said it was changed by the previous owners who lived in myrtle beach, sc. And that it was done at a dealer. Well I have no sticker on my timin belt cover. And I called the dealerships in myrtle beach and they have no record of it bein done.
  3. Feb 29, 2012 at 1:56 PM
    Tacomadude89
    Tacomadude89 Well-Known Member
    Austen
    There are going to be no symptoms of it going bad. It's either going to break or it's not. To inspect it, you'd have to see if there is any cracking between the teeth for tell tale sign of it nearing the end of it's life. But even then, you still can't totally base its life off of that.
