Bad shift lock solenoid
Discussion in '1st Gen. Tacomas (1995-2004)' started by Surfishsail, Apr 22, 2022.
  1. Apr 22, 2022 at 4:44 PM
    Surfishsail
    Surfishsail [OP] Member
    1998 Tacoma 4x4 V6
    My shift lock solenoid went...can't shift out of park without using the overide...any ideas how to delete the locking mechanism so I can get it inspected without having to stick a screwdriver in the overide?
  2. Apr 22, 2022 at 4:48 PM
    TartanEagle
    TartanEagle Well-Known Member
    '17 ACLB 4x4 MT
    Could it be your brake switch? I had '93 where the plastic parts started to fail. Brake switch and clutch switch both did with a year of each other.
    On some vehicles, even a burnt-out brake light BULB can cause this. The system requires a closed loop and the failed bulb interrupts that loop. Double check that too.
  3. Apr 22, 2022 at 11:03 PM
    NvrSyNvr
    NvrSyNvr Well-Known Member
    Jim
    2000 Green PreRunner Xcab V6 Auto w/locking diff
    Hayden 678 Transmission Cooler
    There are some threads on it around here somewhere... is your automatic shifter loose? On mine the plastic bearings were worn out. That causes a misalignment that prevents a switch from being in the correct position. I got stuck at a home depot parking lot one time. After removing the console cover around the shifter, I followed the wiring to a connector nearby under the dashboard and disconnected it. This allowed me to shift the truck and get home. That said... this is dangerous because it removes the locks that prevent you from going in reverse or park while moving forward! The bearings were fairly cheap from Toyota.
