bad o2 sensor- is this a symtom?
Discussion in '1st Gen. Tacomas (1995-2004)' started by hgufrin, Jun 19, 2012.
  1. Jun 19, 2012 at 7:33 PM
    hgufrin
    hgufrin [OP] Member
    My 2003 3.4 auto will simply turn off while i am driving.. it does it at 60mph... it does it going around a corner... sometimes at a stop sign but then i just put it in neutral and it starts right back up. Can this be the o2 sensors?
    I must say that my check engine light is callin for a new sensor but that is before this stalling issue even started.....
    Any ideas on if the o2 sensors would cause stalling? I appreciate any help.
  2. Jun 19, 2012 at 9:42 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    The actual trouble code number would help.
  3. Jun 20, 2012 at 7:50 AM
    hgufrin
    hgufrin [OP] Member
    P0031 is the code.
    Do you think this is what is causing the car to randomly just "turn off". Or do you think it would be an IAC or something like that?
    Thanks for your help.
  4. Jun 20, 2012 at 10:11 PM
    tan4x4
    Rick
    Folsom, CA
    That code means that the heater circuit for the sensor has too low of a voltage. Possibly a fuse or relay that supplies power to the heated sensor.
    I don't know why this issue would cause a stall. No experience here with heated sensors. You might have another issue causing the stall.
  5. Jun 20, 2012 at 11:32 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Fix the O2 sensor first and foremost. O2 sensors have to do with emissions. Emissions has to do with your truck running clean & efficient (and that includes timing, fuel delivery, etc)
    I can't say replacing it will fix your stalling problem..... but you'll have eliminated an issue that you otherwise 'don't know for sure' if it was a contributing factor or not.
  6. Jun 28, 2012 at 12:34 PM
    hgufrin
    hgufrin [OP] Member
    All,
    Okay - so before I replaced the sensor - I cleaned the MAF, Throttle Body, Fuel Filter, and air filter.
    I also replaced both sensors now... upstream and downstream... the car still stalls when i put it in drive or reverse... A new code has pulled up. The P0031 went away and now P0351 comes up.
    Can you tell me what Ignition Coil A is? Which of the three? The autoparts store was not able to tell me :(
    Sure appreciate your help.
  7. Jun 28, 2012 at 12:46 PM
    98tacoma27
    Ben
    Not Beech Creek
    It isn't a specific coil.
    Do you have another code?
  8. Jun 28, 2012 at 12:54 PM
    hgufrin
    hgufrin [OP] Member
    uh oh. I knew there was something wrong.
    I had the auto parts store guy clear the code and re do it because i didnt believe he knew what he was doing. It pulled P0351 two times and he said there was NO OTHER code...
    I sure don't want to replace all three of them... Any ideas?
  9. Jun 28, 2012 at 1:00 PM
    98tacoma27
    Ben
    Not Beech Creek
    Yes, it's more than likely the ignitor, not a coil.
  10. Jun 28, 2012 at 1:23 PM
    hgufrin
    hgufrin [OP] Member
    Ignitor? Don't suppose you can tell me what that is? Im good with old cars just not my father n laws Tacoma...
  11. Jun 28, 2012 at 1:55 PM
    hgufrin
    hgufrin [OP] Member
    Oh yes - as it stands right now... I am driving... the car will only sputter and die when i put it in reverse and try to back up....any ideas?
    I guess with P0351 I will replace the #1 coil and the ignitor??? just going to get pricey. Two oxygen sensors themselves were expensive :mad:
  12. Jun 29, 2012 at 2:22 PM
    hgufrin
    hgufrin [OP] Member
    Problem Solved.
    P0351 - on my car meant the coil on cylinder #5. I looked at it this morning and it was not fully fastened/clipped in.:mad:
    Wondering if someone at the dealership sabotaged it when they were running the 02 sensor codes and changing my oil... Hey- I have to blame someone because those things just dont pop off...:rolleyes:
    The stalling was caused by a loose coil wire and the P0031 was the 02 sensor.
    So, two 02 sensors, fuel filter, MAF cleaning, Throttle Body cleaning, Air filter, and wire connection checking finally paid off!!!!!!!!!! All it was was a loose coil wire.
  13. Jun 29, 2012 at 7:50 PM
    98tacoma27
    Ben
    Not Beech Creek
    Interesting. I'm still surprised you didn't throw a 300 series code (cylinder misfire). Glad it was simple and cheap fix.
  14. Jul 2, 2012 at 5:48 AM
    hgufrin
    hgufrin [OP] Member
    I definitely didnt have a 300 cylinder misfire code. That was interesting to me too.
    P.S. - called the dealership and asked them what P0351 code meant... The tech there told me to put it on the #1 Cylinder !:mad: Glad I didnt listen to her.
