Bad news on V8 UR-series motors from Car Care Nut.
Discussion in 'Tundras' started by GilbertOz, Sep 7, 2024.
  1. Sep 7, 2024 at 9:17 AM
    GilbertOz
    GilbertOz [OP] Driver
    CA
    2014 AC V6 MT 4WD, 80K miles
    FOX 2.5, Deavers, ARB, 4xInnovations
    Just came across this. I'm immediately skeptical of these sorts of videos, but Car Care Nut is generally not a clickbaity sort of guy, and when he brings out a sheaf of failed/failing head gaskets from a bunch of motors all with the same failure mode in the same location I get less skeptical.
    I'd say the main preventative here is probably to change coolant at least every 50K miles, not 100K+.
    https://www.youtube.com/watch?v=dfGTI0sWozc
    enforcertaco91 likes this.
  2. Sep 7, 2024 at 9:50 AM
    PNW15
    PNW15 Well-Known Member
    2015 Tacoma DC LB SR5
    At the end of the vid he says 50k or 5 years. Either way it's not gonna stop the warping, right? Just gonna prevent the leaking, maybe...
    SH10151 likes this.
  3. Sep 17, 2024 at 5:51 AM
    Jaypown
    Jaypown Well-Known Member
    Justin
    NE Ohio
    2020 Tundra SR5 Crew Max TRD Sport 4x4
    This video is hotly debated on Tundras.com I don't see how this is a "trending" issue. These aren't new engines. They've been around for a long time and a lot of them going the distance with high mileage. Just because he has a half dozen UR's doesn't mean it's a widespread issue.
    I'm not discrediting CCN because he has a lot of knowledge and great videos, but I don't see any reason to panic.
    SH10151 likes this.
  4. Sep 25, 2024 at 10:38 AM
    IEsurfer
    IEsurfer Well-Known Member
    Socal
    The 5.7 has its share of problems a major flaw they were never able to rectify in all the years they made it was the infamous cam tower leaks @Superdave1.0 works on some and perhaps he can shed some light on other flaws
    SH10151 likes this.
  5. Sep 25, 2024 at 12:21 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    I've worked on a few of them, and have replaced one 5.7 motor on a Tundra. My neighbor has a 5.7 with 90k miles. He's been chasing a misfire code. Toyota dealer recommended fuel injectors, so they replaced them. I did spark plugs and coils for him. Still has a misfire code. Needs a really good diag.
    The 5.7 I replaced that truck had 200k miles. I think that's an acceptable lifespan. Truck was a work truck and not taken care of.
    I'm no expert on this motor. I would assume they are reliable for the most part. If you look up misfire 5.7 there are plenty out there.
  6. Apr 15, 2025 at 10:27 AM
    trainsktg
    trainsktg New Member
    Keith
    2025 Toyota Tacoma SR5
    6 foot bed
    No major issues so far with our 2008 5.7, currently at about 175k, except just a few weeks ago the alternator went out, but it was a relatively quick replacement. No leaks, no codes, no rattle sounds, and it’s done several cross county trips in the last few years. The Car Care Nut video has me concerned, but so far no signs of any impending doom with ours.
    Cpl. Punishment likes this.
