Bad mpg and oil smells like gas
Discussion in '2nd Gen. Tacomas (2005-2015)' started by westracing9, Jan 30, 2015.
  1. Jan 30, 2015 at 2:07 PM
    westracing9
    westracing9 [OP] Member
    Ohio
    16’ Off Road DCSB,01’ 4Runner
    Have a 08 tacoma 2.7 5speed just recently change the oil about a month ago with royal purple 0-20 with toyota filter.noticed I was geting terrible mileage all of a sudden so was checking over a few things while checking oil noticed it smelled like gas and was darker than usual but not over full.i have no check engine light on and drives perfectly fine beside a very slight rough idle other than that runs like a champ.was getting around 400 miles on a tank now only getting a little over 300. heres a list of things that have been done in the last few months.
    New Dealer iridium plugs gaped .043
    Cleaned throttle body and put new oem gasket in old gasket had screen in bottom new one didn't dealer said it was fine
    Checked and Cleaned mass air flow sensor
    Checked and cleaned PVC valve
    Checked and cleaned both o2 sensors
    New stock style drop in air filter k&n not over oiled already check to make sure wasn't oil on mass air flow sensor
    All new royal purple fluids in tranny,transfer case and front and rear diffs
    Any ideals would be greatly appreciated thanks!
  2. Jan 30, 2015 at 2:14 PM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    Does it smell like gas when you pull the dipstick? Or just at the valve cover when you pull the oil cap off?
    You'll always get a little gas blowby at the rings when you start the engine from cold, and a small amount of gas can make a lot of oil smell bad.
    Also, maybe consider going back to the recommended oil weight for your engine on the next oil change.
  3. Jan 30, 2015 at 2:31 PM
    westracing9
    Ohio
    Dipstick smells like oil haven't pulled the cap and smelled in there yet.thats the oil weight recommended in my manual 0-20 or 5-20.
  4. Jan 30, 2015 at 3:40 PM
    Noelie84
    Noel
    Wales, Maine
    I thought that the 05-12 2.7's took 5W-30...
    That's what the owners manual in my '10 specifies for the 2.7, at least.
  5. Jan 30, 2015 at 3:50 PM
    westracing9
    Ohio
    My manual says 2.7 0-20 or 5-20 but for the 4.0 engine it calls for 5-30
  6. Jan 30, 2015 at 4:05 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I'd run some Lucas fuel system cleaner with what's left of fuel in the tank to maybe clean and free up any sticking fuel injectors then change the oil and filter. Let it drain for an hour or so. In a week or two change only the engine oil filter, again.
  7. Jan 30, 2015 at 4:07 PM
    Taco gator
    Taco gator Taco with 6.5" front 0" rear lift
    J.D.
    Lakeland, FL
    2014 2wd Taco
    6.5" Spindle/5100 lift front lift
    Could be the Royal Purple? I heard it wasn't a good brand for Oil.
  8. Jan 31, 2015 at 9:58 AM
    BDL5589
    BDL5589 Well-Known Member
    NE Georgia
    '14 MGM 4WD RC
    How many miles between changes? I've always noticed a little gas smell in the oil on newer vehicles with long intervals. I don't let it worry me.
    Also, I got caught up in the Royal Purple advertising a few years ago and switched to it from Mobil 1. The engine in my 08 GT was noticeablely louder and more coarse with the RP. Switched back to M1, quiet as a mouse again. Draw your own conclusions.
  9. Feb 2, 2015 at 7:40 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    FWIW stick with the major brands of oil... like Mobil 1 is is always a good call
    boutique oil from small houses (royal purple) guess what ? they have not spent the tens of millions doing research with the military on severe use...Mobil has...
    not saying royal purple is bad, just saying why guess ?
    as long as you are changing the oil regularly, almost anything is going to do just fine.
    anyhow gas in oil sounds like a stuck or bad injector dribbing gas into the cylinder on shutdown, or bad coil or bad plugs....should pop all injectors and have them bench tested. pop and inspect plugs too.
  10. Feb 2, 2015 at 9:24 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    If it's forcing fuel into the sump there is no doubt that it would throw a code and probably would over heat the cat. All used oil has a smell to it.
