Bad MPG after catalytic converter removal
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TrickyTrey, Feb 10, 2014.
  1. Feb 10, 2014 at 11:07 AM
    TrickyTrey
    TrickyTrey [OP] Raggamuffin
    Trey
    Knoxville, TN
    08 PreRunner SR5
    Long time reader here, popping my thread posting cherry with this one. I recently removed my catalytic converters (both pre-cat and the rear) because they became clogged. I then installed spark plug non-foulers on the oxygen sensors because of course my computer threw a CEL. This I was hoping would get the sensor itself out of the actual pipe, letting less oxygen to it. While my truck is running fine, I still find that my gas mileage has dropped a noticeable amount. My assumption is that the oxygen sensors are still "tasting" too much oxygen, thus telling the computer to send more fuel. Could I be right... could I be wrong? I have pondered on the option of stuffing something along the lines of steel wool, into the bottom piece of the non-fouler to let it have even less o2.
  2. Feb 10, 2014 at 11:43 AM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
    I suggest that you replace your converter as I understand there is a hefty fine.;)
  3. Feb 10, 2014 at 12:01 PM
    TrickyTrey
    Trey
    Knoxville, TN
    08 PreRunner SR5
    That's out of the question for now lol. I live in east TN, and in a county that does not do emissions testing. Around here, finding a truck without a catalytic converter is as easy as finding a hooker with an STD
    rmorse likes this.
  4. Feb 10, 2014 at 12:09 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    I don't think there is a quick fix to your problem. With the cats gone the o2 sensors are going to throw a code putting you into a 'default' safety mode. That leads to your engine running rich until you have the problem remedied.
  5. Feb 10, 2014 at 12:33 PM
    RacecarGuy
    RacecarGuy Well-Known Member
    Houston, Texas
    '12 DCSB OR
    Pelfreybilt front and rear HC bumper w/swingout, BAMF LCA Skids, BAMF Diff skid, Pelfreybilt IFS and Trans skid, RCI gas tank skid, Bronze SCS F-5's, Icon RR's ext travel, Dakar leafs, Archive Garage shackle flip
    The O2 sensors before the catalytic convertors can be screwed in without non-foulers. These are the ones that set your fuel trims. The rear O2's are the ones that check for cat efficiency, and will most likely need to be replaced with O2 simulators like what URD sells. This will tell the PCM that the cats are always working, even when they are missing.
  6. Feb 10, 2014 at 1:06 PM
    TrickyTrey
    Trey
    Knoxville, TN
    08 PreRunner SR5
    Thank you all for your input, my question has pretty much been answered! I just wanted to make sure I had the problem narrowed down to the sensors and didn't have a malfunction in another area. I'm gonna try the steel wool trick, and if it still throws the code and is sucking down gas I'll go the simulator route.
  7. Feb 10, 2014 at 1:12 PM
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
    REPLACE YOUR CATALYTIC CONVERTERS ALREADY!!!! YOUR TRUCK IS RUNNING LIKE CRAP WITHOUT THEM AND YOU WILL BURN OUT YOUR VALBVES SOONER!!! Just replace your cats with one converter it is as easy as getting a wrecked tscomas good converter and fixing your exhaust system to run into just one.
  8. Feb 10, 2014 at 1:15 PM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    so you think the o2 sensor being out wont effect the PID loops that the ecu uses? How else will it be able to tell how it is tuned?
  9. Sep 14, 2019 at 10:00 AM
    tupac
    tupac Member
    2001 tacoma 4x4
    SO what does the front o2 sensor do. URD only sells a rear
  10. Sep 14, 2019 at 11:14 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Just cause you can doesn’t mean you should. I thought the hole in the ozone looked a little bigger today.
  11. Sep 14, 2019 at 1:31 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Deleting smog items on an electronic controlled truck is never a good idea.
  12. Sep 14, 2019 at 1:49 PM
    That one old guy
    That one old guy Well-Known Member
    Chuck
    08 Base 4x4 2.7 Access 5spd
    Stockish
    So you removed an essential component(s) of the ECU system, and you're wondering why you MPG went to shit? OK.
    Back in the 70's when CATS were in their infancy, we could get away with these kind of shenanigans. Some establishments even sold 'test pipes', that eliminated the converter for 'test purposes' only, of course. This was before ECUs controlled everything but, well, everything..
    Good luck, somebody has a hack I'm sure.
    gotoman1969 likes this.
  13. Sep 14, 2019 at 2:08 PM
    campoman45
    campoman45 Well-Known Member
    Al
    96 tacoma 4x4 extra cab
    headers, warn winch, Detroit lockers 2 inch lift
    I wouldn't use the steel wool it will just get hot and burn up, if yours is a 4x4 gutting the converters wont make that much difference ,we used to pull the converter and use the test pipes to experiment, for 1/4 mile performance , it did improve the performance but these were high performance vehicals not off road machines, I would put the converters back on and enjoy your truck , it was designed to run its best with the converters , unless you want to buy a pre 74 vehical then you can do just about any mods you want and be legal
  14. Sep 14, 2019 at 2:16 PM
    rmorse
    rmorse Well-Known Member
    Bobby
    Bowie, MD
    2015 Blue Ribbon Metallic Access Cab TRD Sport
    Lol, not only is this a 5 year old thread but why are people so worried about deleting their cat....
    Lmao, imagining thinking that our vehicle emissions are actually making that big of a difference to global climate change/ozone layer.
    JeremyTaco and TacoJova like this.
  15. Sep 14, 2019 at 2:28 PM
    Darkgoatracer
    Darkgoatracer Well-Known Member
    Nick
    Northern VA
    2012 trd sport tacoma
    Stock
    @tupac its my understanding the upstream sensors measure air/fuel mixture and the rears basically measure catalyst efficiency. With deleted cats, the front sensor readings wouldn't change, which is why you would only run 02 sims on the rear (after the cat)
  16. Sep 14, 2019 at 4:26 PM
    rmorse
    Bobby
    Bowie, MD
    Yea the point of a rear 02 sensor is just to make sure the cat is working properly
