Bad Idea? - Replace steel cable with synthetic rope on come-along/cable puller
Discussion in 'Recovery' started by Pinatacoma, Mar 26, 2023.
  1. Mar 26, 2023 at 6:09 PM
    Pinatacoma
    Pinatacoma [OP] Well-Known Member
    Vancouver Island, BC
    2020 ACOR
    Just wondering if anyone has considered this or done it. I'm referring specifically to a 4t hand operated cable puller a.k.a. "come along".
    My thinking is that it would reduce the weight of the gear, provide better flexibility and easier to work with, plus reduce the amount of metal loading up and flying around to cause injury and damage when things go wrong.
    Thoughts? Suggestions? Considerations? Admonitions? Random information that has nothing to do with my question?
  2. Mar 26, 2023 at 6:11 PM
    YamaDirtrider
    YamaDirtrider Custom bumpers @FORT-ifyRigs
    Josh
    Elizabeth CO
    06 DCLB sport postrunner
    What hasn't been modified?
    If it was a new one, I don’t see why not.
  3. Mar 27, 2023 at 8:56 AM
    tacomaboned
    tacomaboned Well-Known Member
    Georgia
    Silver 2012 Toyota Tacoma TRD Offroad
    Theose handheld come alongs are not very heavy in the first place, not sure there is much to really gain in making them lighter.
    perterra and wilcam47 like this.
  4. Mar 27, 2023 at 9:14 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    It would depend on how it was used and only by you!! Being so very careful !
    Having used these over the years in my millwright career The crews I worked with the winch rope would never even last a day. in just normal use.
    I myself don`t see a practical gain. You would need to carry replacement winch rope for when it gets compromised . No doubt when it is needed the most!
    Good luck!
  5. Mar 27, 2023 at 9:22 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    My winch(s) have had synthetic rope. Lighter. Same concept. I also use ratchet straps as “come along(s)”.
    Pinatacoma[OP] likes this.
  6. Apr 18, 2023 at 2:30 PM
    Marc70
    Marc70 Well-Known Member
    Marc70
    Northern Ontario
    2012 TRD Sport 4.0L, 6MT
    2” lift, ARB front bumper, steel rear bumper, Trail Gear weld-on sliders, aFe cai, 2lo kit, air bag suspension, RA Motorsports AL skid plates
    Kodiak420, 02Duck and TartanEagle like this.
  7. Apr 18, 2023 at 9:01 PM
    Pinatacoma
    2020 ACOR
    Marc70[QUOTED] likes this.
  8. May 5, 2023 at 10:34 AM
    Zuba Gooding Jr
    Zuba Gooding Jr Well-Known Member
    My thinking is now you would move the weakest link to something like a nut or bolt on the come along
    :nuclear:
  9. May 5, 2023 at 2:31 PM
    Pinatacoma
    2020 ACOR
    Point taken.
    However, my understanding is that the handle on most of these units is designed to yield when a force over the rating is applied.
    And really, if the system is in full tension and nothing is moving except the tree you're pulling from then it's time to back off and rethink the approach.
  10. Jul 3, 2023 at 10:56 AM
    GTGallop
    GTGallop Well-Known Member
    Greg
    Anthem, Arizona
    2023 Magnetic Grey TRD-OR 4x4
    Dash Cams and Hams!
    CORRECT!!! Which is why you should never slip a "cheater" tube over the handle to get a longer throw. It binds and inadvertently reinforces the handle which is intentionally designed to fail first. It also gives you more leverage than the unit was rated for when it is at that failure point.
    We always called it the Suicide Pipe for that very reason.
  11. Mar 28, 2024 at 4:18 AM
    taintedtattoo
    taintedtattoo Member
    Any follow up on this? I have a brand new nice come a long in my truck that I would like to do this with. I don't care about the weight, but I do care about the fact that you could get allot more line on it with synthetic rope. I may almost double the pulling length by changing over.
  12. Mar 28, 2024 at 4:55 AM
    RugglesTarlek
    RugglesTarlek Well-Known Member
    California
    basic basic basic 14 AC
    You probably know this already, but you can magnify your pulling power by tightening up the comealong and then pushing the cable sideways from the middle. Fizziks, y’all.
  13. Mar 28, 2024 at 6:41 AM
    Pinatacoma
    2020 ACOR
    I didn't try it yet but still think it should work fine. I'd take some time to round over any sharp edges on the come-along's drum though.
    I hadn't considered the potential to increase pulling length.
  14. Mar 28, 2024 at 5:43 PM
    Toy_Runner
    Toy_Runner Well-Known Member
    99 4Runner SR5
    3" OME lift, heavy coils f/r 3/16" steel skids Modified Coastal Offroad diy bumper 5spd swap ('98 donor)
    One point to consider, dyneema/synthetic winch ropes lose a lot of their strength when they make tight bends, so if the drum portion is fairly small in diameter, it may not be a good idea. Same problem with tying knots in synth line. Even knots with relatively large bend radius : rope diameter can reduce the strength by 50%
