Bad FM reception - can you help?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SlappyDave, Aug 3, 2023.
  1. Aug 3, 2023 at 6:16 AM
    SlappyDave
    SlappyDave [OP] Member
    David
    2016 Taco Off Road
    I live in a moderately sized city with plenty of strong FM stations. But my radio reception is absolutely embarrassing - static on almost all stations, even in town and no reception once I get 5+ miles out of the metro area. I've replaced the antenna wire but it made no difference. I have a roof rack that completely surrounds the shark fin and I suspect that's the issue. I haven't had any testing of any of the individual components done, but the head unit doesn't seem like the likely culprit.
    I haven't found a replacement mast that would look good and raise my antenna above the level of the roof rack. Does anyone have a source for a decent looking unit that will solve my problem? Or, do you have a better suggestion? I'm all ears!
    Thanks!
  2. Aug 3, 2023 at 6:32 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    I have a roof rack and the shark fin is completely covered with steel. I still get great FM reception in city and country. I would say you have another issue other than antenna exposure.
  3. Aug 3, 2023 at 6:41 AM
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 1999 Corvette 6MT
    Building a Broja
    Have you changed anything electrical in your truck?
    I notice a ton of FM interference when the third brake light on my bed light bar illuminates. You might have something similar going on potentially.
    Rock Lobster and Chew like this.
  4. Aug 3, 2023 at 7:34 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Fixed the stupid Entune FM radio antenna for good- added a 2nd 2m NMO mounted VHF antenna to my roof rack that I can use as an APRS beacon antenna when not connected to the radio.
    It works so well I get clean stereo and even digital HD signals for the first time from a FM station over 100 miles away!
    To do this, you will need all four of these items plus a NMO VHF 2m antenna.
    $33 Tram NMO Mirror Mount Kit with 17' Coaxial Cable
    https://www.amazon.com/dp/B00IDTJ1VY
    $8 Ancable 2-Pack SO-239 / PL-259 UHF Female to Female Coax Cable Barrel Adapter Connector PL259 Coupler Plug for CB HAM Radio Antenna, SWR Meter
    https://www.amazon.com/dp/B01N9N2C3Q
    $15 Best Kits BAA45 OEM Radio Antenna Adapter for Select Lexus Vehicles
    https://www.amazon.com/dp/B00JR218X0
    $8 Eightwood PL259 UHF Male to DIN AM/FM Male Plug Extension Lead 12"es Coax RG58 for Radio Antenna Receiver
    https://www.amazon.com/dp/B071DV23W1
    NMO mount on the rear bar of my Prinsu:
    PL259 male from antenna to a female /female PL259 barrel to the PL259 male to RCA female antenna adapter. From there it goes to amale/male RCA antenna cord up to the back of the head unit is where the RCA female to Entune adapter is. I have extra slack in order to connect the antenna (tuned for 2m VHF) to my APRS radio when needed off road (don’t useAPRS on daily drives):
    100 miles away with HD reception, baby! :bananadance:
    musicisevil, SunRunner and Jeffch like this.
  5. Aug 3, 2023 at 9:01 AM
    SlappyDave
    David
    2016 Taco Off Road
    Thank you all for very quick responses. I've made no recent changes to the truck and the reception is sucky with or without the brake light illuminated. It's good to know that the roof rack isn't likely to be the culprit. And, with the fantastic (and detailed!) info on the antenna upgrade, I think I see my path forward. Thank you again!
  6. Aug 3, 2023 at 9:09 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    wow, I never knew this! Thanks for the info!
    ALI3N_123 likes this.
  7. Aug 3, 2023 at 9:39 AM
    OnHartung'sRoad
    I was just looking up parts and do you know what? I was wrong!!! The shark fin is a combination antenna for both satellite and radio- I believed it was separate all this time as a tech told me this when I first complained about my FM reception. Seeing the two cables for each going to the back of my radio led me to keep assuming this… sorry for the wrong info- I edited the post to correct it.
    cryptolime likes this.
  8. Aug 3, 2023 at 9:54 AM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    Even with no changes made by you, have you checked all the connection in the back of the head unit? Sometimes they work loose.
    OnHartung'sRoad and Rock Lobster like this.
  9. Aug 3, 2023 at 10:06 AM
    crashnrondo
    crashnrondo Well-Known Member
    Ron
    Wisconsin
    2021 DCSB Limited
    Do you have anything powered off 12v truck power that reduces the power to 5v USB? I had a dash cam that absolutely ruined my FM reception that used a 12v cigarette plug that converted it to a USB micro plug. I couldn't figure it out and even swapped a new stereo and antenna on the 4Runner. I found the problem the day I traded it for my Tacoma. :frusty:
    OnHartung'sRoad likes this.
  10. Aug 3, 2023 at 10:22 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Radio interference is tough as hell to chase down without an RF sniffer.
    I had a slight interference problem for over 6 months, where I would notice stations dropping sooner than they should whenever I left town, and constantly flipping between HD and analogue signals when in town. The brief pause whenever it clicked into HD mode drove me bananas. It was every 10 seconds or so.
    It turns out, the power supply for my dash cam was producing the problem. Replacing that unit cleared it up. It was one of those weekends where I was bored as hell, and started unplugging and uninstalling things one at a time then going for drives while tuned into a weak station.
    stftaco and OnHartung'sRoad like this.
  11. Aug 3, 2023 at 10:24 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    Have you installed any aftermarket lighting? Diode dynamics crap created huge interference issues for me. Removed their stuff and was back to good.
    stftaco, Irons and OnHartung'sRoad like this.
  12. Aug 3, 2023 at 12:11 PM
    OnHartung'sRoad
    If you only plan to use FM and not a two-way radio with the antenna, you can cut a regular 2-meter antenna (any Amazon 2-meter NMO mounted one will work as I described above), or you can also get them with cable and connectors attached. In order to tune it you have to just shorten it by cutting it for the best FM radio reception. The best quarter wave length for the FM band is 2.5 feet.
    I now have mine mounted on a hood mount on the passenger side where real AM/FM radio antennas used to be on the real Toyota Trucks!
  13. Aug 3, 2023 at 12:16 PM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    let me guess. dealership tech? I had such a bad experience last time, the tech should have been the customer...
  14. Aug 3, 2023 at 12:18 PM
    OnHartung'sRoad
    Yeah- a lot of them make silly assumptions- I did also just by believing him!
  15. Aug 3, 2023 at 3:19 PM
    Tallwalker
    Tallwalker Too tall to hide, too old to run.
    @OnHartung'sRoad you might want to consider either shortening your coax cable or not coiling it in a nice neat loop like that. It acts like a choke and can actually attenuate the signal. Not picking, just a friendly suggestion because it is a common thing everybody does without thinking.
  16. Aug 3, 2023 at 3:29 PM
    OnHartung'sRoad
    :thumbsup:You are right. I actually did get a short one as I changed over to a hood mounted FM antenna (a modified VHF one), but I still have the long one and just store it like that as when I am doing APRS, HamSAT or other comms, I uncoil it for a remote antenna on the ground while I’m parked.
    For others who are only using a long coax to reach a roof mounted FM radio antenna, it is good advice to use just the length you need as the signal gets more attenuated the longer the coax.
  17. Aug 3, 2023 at 3:45 PM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    My FM has always sucked in my Tacoma’s. I either stream using my phone or use the Sirius.
    I was gonna cancel but telling them that lowers price a lot. Just about up on 6 months for 5$. I’m gonna call and cancel we shall see what they offer!
    Shit even the FM converter in my 69 Chevy seemed better.
    I do remember a modulator even back then. Too much tech!!!
    stftaco likes this.
  18. Aug 3, 2023 at 6:33 PM
    4x4junkie
    4x4junkie Well-Known Member
    So Calif. (SFV)
    2018 TRD Sport ACLB MT
    FM reception on my Tacoma sucks compared to every other vehicle I've had with a normal (¼-wavelength) FM antenna mounted on the fender, however I don't think I would call it out as bad as OP put it. Nonetheless, I do plan to experiment with a standard whip antenna on it since I'm driving it in the outskirts more now (there's a nice flat spot right at the base of the A-pillar that looks the perfect spot for an antenna... If it works out, I got no issue popping a hole and hard-mounting an antenna there (yes I realize I may need to put a reinforcement inside the fender since it is a bit flimsy there).
    Some clarifications:
    Coiling up a coaxial cable does NOT attenuate the signal energy traveling through it, but will make it act as a choke attenuating any extraneous (unwanted) RF energy traveling on the outside of the shield. This makes a coiled coax cable potentially useful for RF interference suppression, as well as it acting as a balun for feeding dipole and j-pole antennas (reduces antenna pattern distortion caused by feedline radiation). The only bad part about coiling up excess coax is that it is excess coax cable, and will have an additional line loss associated with it compared to a shorter (uncoiled) piece of cable.
    I do agree that if there's no need for it to be coiled, a shorter straight piece of cable would be better.
    A 2M antenna is ~19" tall... FM broadcast being 3M, would need a longer (~28" tall) antenna for that use... What am I missing?
    Edit:
    Or were you referring to cutting down a ⅝-wave 2M antenna to ~28" for ¼-wave FM use? That I can see working as long as the ⅝-wave doesn't have a shunt coil in it's base (it will show a DC short to ground if it has a shunt).
    No HD icon... Not HD reception
  19. Aug 3, 2023 at 7:04 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    My FM is great. No mods. No rack. Just stock.
  20. Aug 3, 2023 at 9:36 PM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    Spotify - listen to exactly what you like with no commercials.
    But even now I hardly use it ( i'm on the family plan ) .... I'm just not interested in hearing anything much these days.
