bad Center support bearing
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacomaforlife, Jan 14, 2010.
  1. Jan 14, 2010 at 6:34 PM
    tacomaforlife
    tacomaforlife [OP] Well-Known Member
    Robbie
    AIKEN, SC
    Its a Toyota what more is there to say.....
    TRD S/C 3" sky jacker suspension lift,33" kumho road venture mt kl71's 16" 320c pacer wheels,billet grill,EBC slotted and dimpled rotors,super 44 muffler with gutted cat,smoked l.e.d. tail lights, deck plate mod with K&N filter,fog/blinker mod,cobra cb with 4' firestick antenna/100W PA,clear corners with l.e.d bulbs,55w back up lights,urd O2 sim., blue l.e.d bulbs behind gauge cluster.
    So the center support bearing on the drive shaft has finally gone out at 160,000 miles and is making a squeaking noise and is vibrating at around 40+ mph. Ive never replaced one has anyone else? can i do it my self with out any special tools or having to get it pressed on?
  2. Jan 15, 2010 at 7:50 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Piece of cake, easiest drive line component to R&R,1st & foremost when dropping the drive shaft before you start taking out bolts ,make a note of the original location where the U-joints bolt to the flanges on front & rear yokes so you can re install in original location. I'm not positive but I think there are 4 bolts that hold the carrier & the mount to a cross member maybe ? I've changed alot of center berings but not one on a Toyota yet, at least mine anyway lol but really , its easy, get ya a ratchet & a combination wrench the bolt size could be anything from 13mm - 17mm. Shit I haven't even looked at mine & I'm telling you what to do,, haha its really pretty self explanitory. You'll need a vise after you get the shaft out to hold it while you scribe on both sides of bearing where it sits on the intermediate shaft all the way around so you can re-align the new bearing back on to the intermediate shaft in its original location. To get the old bearing off keep it snug in the vise & give it a couple of good smacks with a mallet or get a piece of hard wood or a flat nosed punch & use a hammer , hitting it in several spots working your way around the center bearing it should be off the shaft & rolling down your driveway about now. Clean & inspect the area before re assembling the center bearing, as a matter of fact make sure to inspect & clean all that you can since your down there anyway.......:cool: Good Luck
  3. Jan 15, 2010 at 12:56 PM
    tacomaforlife
    Robbie
    AIKEN, SC
    alright thanks for the advice.:)
  4. Jan 18, 2010 at 8:29 AM
    Keystone Designer
    Keystone Designer Member
    Colorado Springs, CO
    02 SR5 Ext Cab red
    Doug,
    I am trying to chase an intermittant annoying squeak that sounds like a fan belt, or a spinning bearing...except it is coming from my drive train. It seems to be triggered by cold temperatures. All of my belts are fine, U-joints are tight and greased. Which leads me to suspect the carrier bearing. I don't see any grease fittings on it, I wish it did. I am able to wiggle the drive shaft up and down about 1/4" total at this connection. Is this normal or a tell tale sign of failure. 2002 Taco w/82K miles
    thank you for your 1500 mile wrench.
  5. Jan 19, 2010 at 8:19 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    A 1/4" at the Carrier (center)bearing ? Does it sound like a piece of wire wrapped around the drive shaft ? If it does, almost 99% time it'll be U joints, I'm not sure on the tolerances on center bearing but it sounds suspect, also the noise you hear, does it increase as speed increases & at what point does it stop ? I need a little more info ok bro'?.......:cool:
  6. Jan 19, 2010 at 8:52 PM
    saltshaker
    saltshaker Well-Known Member
    johnny
    north carolina
    2011 TRD Off Road MGM AC
    AFE CAI, Fold-a-cover
    my 01 has the same noise I think, in cold weather when I let off the gas, sometimes it's terrible, sounds like a fan belt but under the truck. It worried me to death at first. never did figure it out, I kind of forgot about it when spring came and it's intermittent like you said. Now it's been doing it for nine years so I don't worry about it anymore, It's gotten a lot better, which could be a bad thing I guess, but I'm going to the dealership for a new turd-roller next week.
    the sound reminds me of metal rapidly cooling, like if you throw a piece of dry ice on a piece of steal and it starts to scream. at one time I thought it might be in the exhaust.
  7. Jan 20, 2010 at 4:12 AM
    tacomaforlife
    Robbie
    AIKEN, SC
    yea i fixed the center support bearing but i still have that wire wrapping around the drive shaft noise sometimes.
  8. Jan 20, 2010 at 11:56 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Ok, time for a good ol' fashioned U joint check, After securing your truck (can't move on you) Get underneath & firmly grab the drive shaft near where the U joints bolt up & firmly wiggle both up & down & side to side, if you feel ANY MOVEMENT (or see any shiny metal in visual of U joint) Any up & down or side to side movement your U joints are done especially when that "piece of wire wrapped around something" is present. Bottom line is my money is on U joint replacement especially for you guys with manual trans... :cool:
  9. Jan 20, 2010 at 6:29 PM
    tacomaforlife
    Robbie
    AIKEN, SC
    ok ill try that tomorrow thanks for the help.
  10. Jan 28, 2010 at 9:49 AM
    Keystone Designer
    02 SR5 Ext Cab red
    Doug, cRaZy OLd mAn !, You get the 1500 mile wrench award for pin pointing the solution to my dilemma. Turns out greasing the u-joints did the trick. Still puzzling, I didn't observe any slop in them, just gobbed them up good. Problem gone.
    Thank you
  11. Jan 28, 2010 at 10:20 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Not a problem my friend, I shoulda mentioned that lubing everything underneath that has a zirk(grease) fitting is pretty key maintenance for longevity especially where you are with extreme cold,wet winters etc; Glad it helped Bro'........:cool:
    :mudding:
  12. Jan 28, 2010 at 4:42 PM
    tacomakid96
    tacomakid96 Lions Not Sheep
    Phil
    Out n' about
    1996 Tacoma / 2000 4.7 Tundra TRD
    I have a 96 Tacoma and when i hit around 50 mph there is a vibrating sound coming from the front end almost sounds like the tires but its not? I dont know if the cv joints are making it or what?
  13. Jan 28, 2010 at 6:50 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    When you say "vibrating sound" does that mean you have a vibration with the sound ? I need a little more info dude, is it stock? What kind of tires & last time you rotated them? is it an extended cab or standard? Is the drive shaft a one piece or two? (ex. cab = 2 piece, standard= 1 piece) 4X or pre runner? etc;............ :confused::confused:..... :cool:
  14. Jan 29, 2010 at 4:56 PM
    tacomakid96
    Phil
    Out n' about
    Its a extended cab SR5, it is stock, just bought it so i dont know when they were rotated know that the tires were purchased last year and there Toyo open country A/T's also it is a 4x4. Sorry about the lack of info:D
  15. Jan 29, 2010 at 7:37 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    No problem dude, As long as it drives straight, even with vibration & noise, I'd start with tire rotation & if this truck is fairly new to you , ya really need to spend a whole day, shit even a whole weekend underneath it checking things out on frame & drive line for tightness of bolts, any damage, any loose parts (not bolted, look for broken or bad welds ) & I cannot stress this enough, Get a grease gun (or take it to someone you trust ) & LUBE THE SHIT OUT OF ANYTHING THAT HAS A ZIRK
    (grease) FITTING !!! Chassis, Driveline ,etc;. but start with the tire rotation & inflation ...OK ?.... good luck .......:cool:
  16. Jan 30, 2010 at 2:40 PM
    tacomakid96
    Phil
    Out n' about
    Cannot thank you enough bought the greese gun lubed the shit out of everything i could find and the noise went away! Thanks again dude:D
  17. Jan 30, 2010 at 9:36 PM
    topjimmy
    topjimmy Member
    Jim
    maple valley, wa
    04 PreRunner SR5 TRD
    Linex Bed Liner
    Yup I had this sound on my 04 ex cab trd sr5 only when i got off the gas or just cruising with very little load on the drive train. I took it tot he dealer and they looked at me like my head fell off and said I had something rattling around in the cab WHATEVER. Well low and behold I thought crap this must be the carrier bearing. it wasnt. When I het all the zerts in the driveshaft the noise was gone. Now I know when the squeel comes back it's grease time. I'de hit the zerts before zi went wrangling the center carrier bearing. Good luck.
  18. Jan 31, 2010 at 1:06 PM
    tacomakid96
    Phil
    Out n' about
    Ya never trust anyone when it comes to your truck" except maybe doug lol," if somebody doesnt have the answer they will make shit up to get you outta there
  19. Jan 31, 2010 at 6:44 PM
    tacomaforlife
    Robbie
    AIKEN, SC
    i greased the u-joints and its quiet now but still have a small vibration still not as bad as before i had greased it though.
  20. Jan 31, 2010 at 8:49 PM
    4421.frank
    4421.frank Well-Known Member
    Southside chicago
    02 double cab prerunner supercharged
    nasty dent on driver's side bed panel, shabby seats, cigarette burned interior roof, missing berf bar pad, cracked rain visor, removed hood scoop, unmentionable stain on back bench?
    mine made thata noise as well
    greased the shit out of it and everything was fine
    for a couple days, then it came back
    gonna take it into a professional have 'em check it out
    if they say i need to replace it then I'll look into a aftermarket driveline
    p.s. noise was more pronounced after certain suspension lifts were installed
