Bad bearing? Fan pulley? HELP PLEASE
Discussion in '1st Gen. Tacomas (1995-2004)' started by JayARRGHH, Sep 29, 2011.
  1. Sep 29, 2011 at 5:41 PM
    JayARRGHH
    JayARRGHH [OP] Well-Known Member
    Jay
    Bellingham, MA
    03 Tacoma SR5 TRD
    285/75/R16 Eldarado MTZ, Alpine CDE-102 Deck, DIY Snorkel, 2" Spacer Lift, Uniden Bearcat 880 CB, Custom over head console w/ map lights, CB Mount, and external CB speaker, 2 12" Kenwood Subwoofers, 300 Watt Alpine Amp, Alpine 3" lift 500# capacity
  2. Sep 29, 2011 at 5:55 PM
    JayARRGHH
    Jay
    Bellingham, MA
    03 Tacoma SR5 TRD
    bump to make up for the time it took me to embed the video -____-
  3. Sep 29, 2011 at 6:16 PM
    JayARRGHH
    Jay
    Bellingham, MA
    03 Tacoma SR5 TRD
    nothing?? :/
  4. Sep 30, 2011 at 3:25 AM
    JayARRGHH
    Jay
    Bellingham, MA
    03 Tacoma SR5 TRD
  5. Sep 30, 2011 at 6:09 AM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    I heard a squeak --belts??
    have you put anything on the belts--belt dressing?
    too loose or TIGHT?
    Some belts squeak when it rains--moisture levels high.
    Is this on a 03?
    Thats what I drive--want me to check or compare something?
  6. Sep 30, 2011 at 6:15 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    I'm hearing a whine in the background that maybe an idler pulley starting to complain, & I think I noticed your fan pulley painted ? work done recently ? Sounds like a water pump noise too...
  7. Sep 30, 2011 at 6:25 AM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
    DITTO on the WATER PUMP.
    How many miles--ever been changed?
    Idler pulley turning? Have you checked for looseness?
    Had one on my 91 go bad--but that was 185000 mi.
  8. Sep 30, 2011 at 12:58 PM
    JayARRGHH
    Jay
    Bellingham, MA
    03 Tacoma SR5 TRD
    Hey thanks for the responses. Its been going on for about a week, when it first started I put some crc belt dressing on, went away temporarily, then came back strong and won't go away now, the belts all seem tight and the pulleys all turning the only work done since I've owned it is new tranny lines and axle. Someone else suggested the water pump, its at 97k today so. shit.
  9. Sep 30, 2011 at 1:39 PM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
    Have not checked mine yet--But is that a tension pulley on the BOTTOM center?
    Need to remove the skid plate to get access. W/only 98K--look for the easiest FIRST.
    Are you running hot? Have a Leak?. Would expect the water pump to last to 100K.
    Checked fluids? Alternator? With the A/C on--is there a difference.
  10. Sep 30, 2011 at 3:07 PM
    monoman
    monoman Time to get dirty!
    Dave
    Exotic, San Jose, Cal.
    2018 Silver Sky Tacoma SR Access Cab 4X4
    SnugTop SuperSport shell CaliRaisedLED light bar BFG K0 AT’s Bilstein 5100's up front, (#2) & 4600 in rear N-2 Designs remote start/keyless entry Anytime 12v outlets... one by shifter & one in bed Daily driver....
    Yea, at 97K, it's a good time to get the timing belt & water pump done anyhow. That way, you could replace all your belts at the same time and hopefully not worry about it anymore.
  11. Sep 30, 2011 at 3:52 PM
    JayARRGHH
    Jay
    Bellingham, MA
    03 Tacoma SR5 TRD
    That's what has me confused, not running hot, no leaks, just the noise everything else completely normal. Water pump and timing belt is like $100 so just gonna get that tomorrow. When I get home I'm going to put a long screw driver onto the water pump and ps pump and listen to it since I don't have one of those fancy stethiscopes.
  12. Sep 30, 2011 at 8:27 PM
    UndefinedTaco
    UndefinedTaco I'll eat all your food.
    Justin
    Tracy, CA
    Toyota
    It's an 89 Toyota Pickup. I got some stuff done to it.. FJ axles going under it soon.
    Take your belt off and see if your pulley is grooving or shiny...could be belts are too tight.
    Does sound like your truck is due for the 100k interval service(pump, belt, plugs, wires, air filter)
    Your fan clutch might be going out too though..try spinning it with engine off..is it easy to spin or resistance?
  13. Sep 30, 2011 at 8:29 PM
    NegroTundra
    NegroTundra Well-Known Member
    Land of Enchantment
    03 Tacoma TRD 4WD 5 spd
    You make it sound so easy :D Let us know what becomes of this.
  14. Oct 1, 2011 at 7:00 AM
    JayARRGHH
    Jay
    Bellingham, MA
    03 Tacoma SR5 TRD
    Underfined taco: its not like a flick and it will spin but if you push it it will spin with your hand, a little bit of resistance.
    Negrotaco: LOL is anything ever easy on these? Everything turns out bigger than made out to be haha. Hopefully my brother in law who was a mechanic can help out a bit better.
  15. Oct 1, 2011 at 9:49 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    The fan clutch is an easy-to-check item, if its loose & sloppy, its shot, if its hard to turn or froze, its shot, if it turns smooth & straight with some resistance its good...;)
  16. Oct 1, 2011 at 11:38 AM
    UndefinedTaco
    Justin
    Tracy, CA
    Toyota
    Yep^ if it has some resistance then it's fine
    Sounds like your fan clutch is fine.
  17. Oct 2, 2011 at 9:20 PM
    JayARRGHH
    Jay
    Bellingham, MA
    03 Tacoma SR5 TRD
    Yea fan clutch is good, thanks for all the tips guys, i put a pry bar on the water pump while it was running and listened to the vibrations, 100% the water pump and the PS was making a little bit, but if i understand correctly, that should always make a bit of noise, and I'd rather have coolant than power steering.
  18. Oct 8, 2011 at 11:55 PM
    JayARRGHH
    Jay
    Bellingham, MA
    03 Tacoma SR5 TRD
    Update. WOW this is a pain in the ass. literally taking the engine apart, I've had to take off nearly all of the pullys, all of the belts, the fan, the power steering pump, the air conditioning compressor. Holy shit this is a PITA. I figured it'd be a challenge, but this?? It also didn't help because the NCTTORA FSM I was using was for the 4 banger and not my 6, so nothing added up. Hopefully getting it done tomorrow for good. I've been working on it slowly after work every night. On the Air Conditioning compressor, there's ONE bolt holding it that I can't get to, and I can't crack, most of my bolts are rusted to shit but two of them sheared -____-
  19. Jul 14, 2012 at 10:22 PM
    x2468
    x2468 Well-Known Member
    '02 TRD 4wd V6 Xcab Sr5
    How'd this work out for you, i think i need to do a few of my pulleys. any tips?
  20. Jul 14, 2016 at 1:10 PM
    spoof720
    spoof720 New Member
    Hello Everyone,
    I think I'm encountering a similar problem. My 01 V6 Tacoma has about 208K miles. I had the timing belt changed out at 198k. I originally thought the loud noise was from the fan clutch, so I replaced. Started her up and it sounds like something is slipping. I'm also getting a battery light come on when she's idling. Any advice?
