Bad battery cables
Discussion in '1st Gen. Tacomas (1995-2004)' started by Sullicosta, Feb 2, 2024.
  1. Feb 2, 2024 at 5:50 AM
    Sullicosta
    Sullicosta [OP] Member
    Sullivan
    2004 Tacoma
    Seems like my car has some bad cables somewhere, doesn’t start really well, not sure how to track where the problem is though, any suggestions?
    I’m also confused about this red wire that is cut, looks like it should’ve connected to the battery in the past
  2. Feb 2, 2024 at 5:57 AM
    iwashmycar
    iwashmycar a lot
    Adam
    Lewis Center, Ohio
    07 FJ 4x4 AT
    33's | 3" | skids | rails | dent | CB | lights | dingus
    Yeah thats not super pretty, but if the connection is tight, then its probably not the worse thing....seeing a twist connector down in that fender is bad news....horrible wiring jobs have been done to this truck most likely. Those battery terminals are cheapo part-store ones...could check that the rust and corrosion has not infiltrated where the wires bolt on.
    The battery itself is like a uber cheapo $100 battery with over 100 CCA less than what came in it originally from the looks of it. May be the larger part of your problems.
  3. Feb 2, 2024 at 5:59 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Chasing down aftermarket wiring issues is never fun.. Especially when its a hack job like what Im seeing in those pics. Household wire nuts, loose wires, we wont even talk about that green wire in your last pic :facepalm:
    My recommendation - start simple. Check all those aftermarket crimps are tight, make sure the terminals are clean and tight, make sure none of the aftermarket stuff is drawing the batt down overnight
    Bivouac likes this.
  4. Feb 2, 2024 at 6:06 AM
    SR-71A
    Zack
    Southern Maine
    That's true. 26R is a small oddball size
  5. Feb 2, 2024 at 6:10 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    I would start with all new battery cables and decent terminals !
    Those terminals are made for an emergency far from home to get the vehicle home and repair things correct.
    I did like the relay just sitting on the split loom.
    rocknbil and SR-71A like this.
  6. Feb 2, 2024 at 6:18 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Home made wiring job show it to some one that knows what they are doing before you start removing things will make it a lot easier to repair.
    Sullicosta[OP] and Bivouac like this.
  7. Feb 2, 2024 at 6:28 AM
    Sullicosta
    Sullivan
    2004 Tacoma
  8. Feb 2, 2024 at 6:28 AM
    Sullicosta
    Sullivan
    2004 Tacoma
    How do I check if it’s drawing from the battery overnight
  9. Feb 2, 2024 at 7:54 AM
    iwashmycar
    iwashmycar a lot
    Adam
    Lewis Center, Ohio
    07 FJ 4x4 AT
    You would typically take off neg battery cable, and put a multimeter from that removed neg cable to the neg post.... then start pulling fuses one at a time until you see a substantial drop.
    Id first look at any aftermarket items added to the truck. Also check the underdash panel for any add-a-fuses and see if they are on switched power or always on.
  10. Feb 2, 2024 at 8:45 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    Hmmm
    Appears that the green and red wire go to this unknown/unplugged relay
    fog lites?
  11. Feb 3, 2024 at 9:40 AM
    rocknbil
    rocknbil Well-Known Member
    Bill
    2003 Taco Ext Cab DLX TRD 4WD MT 3.4L
    Ditch those terminals and install military spec terminals. Do not go cheap, go straight to Napa and throw down $30 for them. You can order online way cheaper, just you won't know what you're getting, be sure they are not the lead free type. Pick up some copper crimp connectors too, and crimp them well.
    <TL;DR>
    I had exactly those terminals for a while, they worked fine, but it has always kept me awake at night. Found a set of "military spec" terminals on FleaBay, big mistake. These were the "lead free" terminals, which means they weren't pliable like lead. Had to tighten them so much I was concerned I was going to damage the battery, just as they started to snug up . . . SNAP goes the left side of the terminal by the nut, total junk.
    So make sure they are lead, not lead free. You crimp one wire on each side of the reminal with the bendy-parts of the copper connectors facing inward so your covers slide on well.
    Sullicosta[OP] and SR-71A like this.
  12. Feb 3, 2024 at 1:16 PM
    Old metals
    Old metals Well-Known Member
    02 x-cab 4x4 2.7 2018 TRD Sport 4x4 3.5
    Original
    iwashmycar likes this.
  13. Feb 4, 2024 at 10:44 AM
    rocknbil
    Bill
    Those look like good ones, you just gang the wires each side and torque them in there? What I like about the mil-spec is my Taco has two wires for each terminal, I can put a proper connector on each wire and bolt them individually.
  14. Feb 4, 2024 at 10:52 AM
    Madjik_Man
    Colorado Front Range
    I sucked it up and bought the SDHQ upgrade kit.
    rocknbil likes this.
  15. Feb 4, 2024 at 11:41 AM
    Old metals
    Original
    @rocknbil yes, just insert the wires and torque. Not the best choice if your not sure about future add-ons. That's where the ones you use shine. I was introduced to this screw style connector on welding leads and 3 phase equipment. Out in the field they were bullet proof. And rock crushers can wreck anything. When I stumbled on them for battery terminals I all ready knew what kind of abuse they would take and how simple they are to put together.
