Bad ABS module?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Nalpak99, Jan 29, 2021.
  1. Jan 29, 2021 at 10:54 AM
    Nalpak99
    Nalpak99 [OP] Booty Hunter
    Kyle
    2005 Toyota Tacoma pre-runner
    mid travel
    I have to push my brake peddle halfway down before any breaking occurs. I replaced my master cylinder and brake booster which did not help. I've bleed my brakes over 10 times and even took it to two shops to get the brakes inspected and bled. They even adjusted the rear drums and resurfaced the drums. the parking brake holds the truck when in neutral on a hill. I just replaced my rear brake lines with metal ones and that didn't fix it either. there is no leaks in the system either. Im gonna put metals on the front today too. only thing I can think of is a bad abs module.
  2. Jan 29, 2021 at 2:51 PM
    MR5X5
    MR5X5 Well-Known Member
    ...sounds about normal?
  3. Jan 29, 2021 at 7:47 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Braking not Breaking.
    The ABS Module will not cause a low pedal.
    Air in the ABS System will. Did these "shops" cycle the ABS Solenoids while bleeding. If they didn't then they didn't bleed the system correctly and you have air trapped in the ABS Solenoids.
    06Tacooo and Key-Rei like this.
  4. Jan 30, 2021 at 10:07 AM
    Nalpak99
    Kyle
    mid travel
    They bled the abs module
  5. Jan 31, 2021 at 1:33 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    OK.
    TnShooter likes this.
  6. Jan 31, 2021 at 2:02 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    If that’s the answer they gave you, it’s not a good one.
    That like saying, “We rotated your right front tire”
    You’ll likely need to have the system pressure bled WITH the ABS Module activated.
    This is not exactly simple. And most people don’t have the equipment to do it. (Me included)
    You’ll need a scan tool to activate the ABS module. They aren’t cheap.
    (I don’t trust sketchy hacked software, so I won’t buy the eBay stuff)
    When I have to disconnect a brake line, I cap the line with vacuum caps.
    And check the reservoir often. These trucks can be hard to bleed. I do all I can to keep air out of the system.
    Key-Rei and Jimmyh like this.
  7. Jan 31, 2021 at 8:30 PM
    Tzilla2ndgen
    Tzilla2ndgen Member
    2006 Red Tacoma TRD Offroad
    I had the same problem last year where and it ended being a seized star wheel in the rear brakes. Took it to a local shop and they had it on the lift. With brakes applied one wheel was still moving freely.
  8. Jan 31, 2021 at 8:47 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    05-06 do not have solenoids on the abs those didn't start until traction control.
  9. Jan 31, 2021 at 8:53 PM
    sparkystaco
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    Another thing you can try is find a place with low traction and do a couple panick stops to cycle the abs then bleed again.
  10. Feb 1, 2021 at 5:14 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    How do you think the valves switch in the plain old ABS System pre-traction control system?
    I would really love to hear your explanation of how the Four sensor four channel ABS System works for a 2005 and 2006 Tacoma. Looking forward to it.
    salazam, Muddinfun and Torspd like this.
  11. Feb 1, 2021 at 5:45 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    See all of those little round doo-hickies? Each one of those is a solenoid.
  12. Feb 9, 2021 at 12:40 PM
    Nalpak99
    Kyle
    mid travel
  13. Feb 10, 2021 at 7:36 AM
    EdgemanVA
    EdgemanVA Well-Known Member
    Virginia Beach
    2008 X-Runner
    Several
    Can you find a shop that repairs ABS modules? Saw an episode of Wheeler Dealers, and they used a shop to do a repair on their unit for MUCH less than buying a new one. It was when they were based in California.
    (This week's episode shows them packing up to move back to England. Somehow I don't see Ant leaving, even though he's getting a divorce from his Hollywood actress wife.)
  14. Feb 10, 2021 at 8:49 AM
    Nalpak99
    Kyle
    mid travel
    a used ABS module is about $200 while a repair is already $200 in parts not including labor.
  15. Aug 23, 2022 at 1:06 PM
    bosshog1
    bosshog1 Well-Known Member
    micah
    West monroe, la
    '05 DCSB TRD Off-Road
    OME lift w/ 886's and Dakar AAL, Cooper Discoverer ST Maxx 285/75/16, Cruisin Off-road front bumper, custom Toyota grille
    Did you ever figure our what your problem was? I'm having similar issues on my 05 TRD Off Road.
  16. Jun 1, 2023 at 11:30 AM
    salazam
    salazam Active Member
    It's air in the module. I have the same problem. Dealership only manually bleeds and lies to you about needing drums and how you didn't adjust the rod properly when you changed the MC but they'll fix it for $2k.
    I know because I bought a new module and proceeded to put air in that one as well when bleeding the brakes (I swear the res looked like it had fluid in it still!).
