Backup sensor removal - how???
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dacon, Jul 4, 2017.
  1. Jul 4, 2017 at 7:52 PM
    Dacon
    Dacon [OP] 2017 Tacoma TRD PRO Quikrete
    Danny
    Gilbert, Arizona.
    2017 TRD PRO DCSB. DOP 02.20.2017
    TRD PRO Cement 2017 TRD CAI and AFE Magnum Flow Dry Air Filter Camburg KINETIK Series Billet UCA Icon LCA skid plates Icon Coilover extended travel shocks with 700# springs Icon 2" rear shocks Icon RXT leaf springs full pack (new rims and tires soon)
    Need to remove the top black plastic cover on top of the rear bumper. Enough I have to remove the license plate lights but also I need to remove the sensors. Has anybody removed the backup parking sensors and how to do it? How hard is it?
    Need to go slow and sure without damaging things and digging for more $$$ to fix.
    Attempting to realign the rear bumper caps to the frame.
  2. Jul 4, 2017 at 8:14 PM
    imdav2u
    imdav2u Well-Known Member
    St. Louis
    2016 TRD Offroad DCSB 4X4
    Take it to the dealer and have it fixed under warranty.
    tomwil likes this.
  3. Jul 4, 2017 at 8:22 PM
    Psycho2
    Psycho2 Well-Known Member
    AZ
    '16 DC TRD Sport Barcelona
    The sensors are not really that hard to remove - they are just held in by 3 little push-in clips in the outer ring.
    On another note, don't bother with trying to re-align the bumper caps - there is not enough wiggle room in the assembly to give you any kind of adjustment. If your bumper mounts to the hitch, there is just about 0 tolerance in the holes.
    Like the other guy said, dealer is probably best to perform this kind of work, since the bed probably needs to be adjusted, not the bumper.
  4. Jul 4, 2017 at 8:53 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    Post #22 on this thread has good step by step instructions on removing the rear bumper and sensors.
    https://www.tacomaworld.com/threads/16-tacoma-bumper-cap-removal.404082/page-2
  5. Jul 4, 2017 at 8:59 PM
    Dacon
    Danny
    Gilbert, Arizona.
    The metal frame that supports and top plastic bumper and the caps and that attaches to the hitch bar is aligned OK. The problem are the end caps behind the painted plastic outer caps that are not installed the right way. As you see in the pictures, the distance is not even between the caps and the metal frame and the screw hole is misaligned also. Driver side (large gap) is crooked and passenger side (normal gap) is more IN and straight.
    Need to remove the top plastic cover to get to the screws that hols the plastic end caps support. In order to remove the top plastic cover I need to remove the license plate lights and the backup sensors.
