Backup Sensor Constantly Beeping
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoAlex16, Jan 4, 2020.
  1. Jan 4, 2020 at 11:10 AM
    TacoAlex16
    TacoAlex16 [OP] New Member
    Alex
    2016 Tacoma Sport
    When I put my 2016 Tacoma in reverse with the parking sensor on, the beeper is constantly beeping. I’ve cleaned the sensors and the backup camera but it still beeps. I don’t have a hitch or anything obviously within its view. It started anytime it would rain, now it does it constantly when turned on and in reverse.
    Any thoughts?
    Any way to test the sensors? I’ve seen the replacements on Amazon, but not sure which sensor(s) might be broken.
  2. Jan 4, 2020 at 11:32 AM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    Kinda Sounds like a short in the sensor. Water got in making it short when wet, now it’s corroded making a permanent short. You can test them with a multimeter, info should be in the Toyota maintenance manual if you have a copy of that.
  3. Jan 4, 2020 at 12:23 PM
    Eticket
    Eticket Well-Known Member
    Thomas
    Holly Springs, NC
    2016 Tacoma TRD Sport 4x4
    I had it happen today as well (rained two days). I turned it off, two key cycles later, it’s working as normal.
    maybe not much help, but I would ask dealer if no one on here can help...
  4. Jan 4, 2020 at 1:43 PM
    Vinci
    Vinci Well-Known Member
    Sarasota, FL
    '17 MGM Limited 4x4
    I had this happen once a week ago. Dry day. It didn't happen again after. Hopefully it doesn't..
  5. May 4, 2020 at 7:19 AM
    Jeremyd859
    Jeremyd859 New Member
    Jeremy
    Kentucky
    2016 Tacoma limited
    Iron Cross Patriot step bars
    Same issue on my 2016 Tacoma. Passenger rear sensor alarms when in reverse during and after moderate to heavy rain.
    I’ve researched aftermarket sensors as factory ones are 200 each. I’m a little unsure on aftermarket based upon reviews.
    This is an annoying issue. I found a new factory sensor on eBay for much lessor cost. I’ve decided to replace the sensor but retain the old one in case anyone were to discover a fix for this issue
  6. Jun 17, 2020 at 7:48 AM
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    16 Super White Limited 4x4
    Any update on this. Mine go off every time it rains heavy.
  7. Jun 17, 2020 at 8:51 AM
    Doobfucious
    Doobfucious I get it. It ain't makin' me laugh but I get it.
    Doobie
    WNC -> Midwest
    2020 TRDOR DCSB 6MT
    Stock AF. My 68 Bronco and 2000 2.5RS get the mods.
    Bad sensor or harness issue.
    On many cars, you can liiiightly touch and move your finger around the sensor and you'll feel it clicking when it's on and working. Maybe youll get lucky and all but one will be clicking and you found your bad one. I'll have to check mine this evening, I really want to know if ours click the same way; no way I'll remember though.
