backup camera wiring
Discussion in 'Audio & Video' started by flravem, Feb 8, 2020.
  1. Feb 8, 2020 at 2:54 PM
    flravem
    flravem [OP] Member
    TR
    2018 SR5 4 door short bed
    none
    Hi...I need to put a switch (spst) into my backup camera power........I back a boat trailer down the ramp before sunup almost every morning.......yes i can go into settings for the camera and turn the contrast and brightness down and that will work.....but then i need to remember to turn it back on and all of this take time......i just want to turn one switch off and the camera/light goes away....does anyone know which wire is the power wire for the camera?
  2. Feb 9, 2020 at 11:45 AM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    Are you saying you just want to have the camera NOT come on while in reverse (when switch is on)
  3. Feb 9, 2020 at 11:57 AM
    destin_meeks
    Destin
    Tuscaloosa, AL
    The wire you want is
    24 pin harness
    Pin 2
    Grey wire
    this is the reverse trigger that tells the radio you’re in reverse, which activates the camera view.
    cut this wire and add in a very simple SPST switch/toggle.
    when switch is up, reverse trigger passes through and camera shows
    When switch is down, reverse trigger doesn’t pass through and camera doesn’t show.
  4. Feb 9, 2020 at 1:15 PM
    flravem
    flravem [OP] Member
    TR
    none
    That is the information i need......and exactly what i want to do
  5. Feb 9, 2020 at 1:19 PM
    destin_meeks
    Destin
    Tuscaloosa, AL
    this is also the same wire used for the anytime camera mod. supply 12v power to this wire when not in reverse and the radio sees the backup trigger and shows the camera.
  6. Feb 20, 2020 at 10:05 AM
    flravem
    flravem [OP] Member
    TR
    none
    well i have more problems.......I put the switch in and it worked fine in the testing stage......I then bolted the radio back in and put the trim back on.......now when i crank the truck i have no power to the radio as if the fuse is blown......i find the fuse to keep the preset channels hot but not one for power.......my other thougt is i have tripped an anti-theft switch which turns off the power.......HELP!
  7. Feb 24, 2020 at 3:35 AM
    flravem
    flravem [OP] Member
    TR
    none
    Well let me post a fix.......because asking the question with out a follow up sucks.......checked all of the fuses.....under the hood where the radio fuses should be there are no fuses......under the dash on the drivers side and very hard to get there......there are no fuses marked radio.....took my power probe and tested all the fuses......found a 7.5 with no power....marked ECU ACC....and damn if that was't it
