Backup Camera Wiring Question – Always-On Power Option?
Discussion in 'Audio & Video' started by apbright, Nov 11, 2024.
  1. Nov 11, 2024 at 10:53 PM
    apbright
    apbright [OP] Well-Known Member
    Aaron
    2007 Silver Tacoma Base
    I'm wiring a backup camera and have a question about the power setup.
    So far, I’ve got:
    • Black wire (ground): Connect to a ground point.
    • Green wire (trigger): Wire to the reverse lights to activate the camera when in reverse.
    Now here’s my question:
    For the optional "always-on" power line, can I wire it into the running lights? I don’t see myself using the backup camera outside of reverse too often but having the option to turn it on sounds nice.
    Would this simple setup work, or would I need to use a different power solution? Any advice would be appreciated!
  2. Nov 12, 2024 at 5:19 AM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    You can wire it to the radio’s accessory wire, or the cig lighter.
