Backup camera-beep problem
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BlackdogGS, Mar 28, 2023.
  1. Mar 28, 2023 at 9:03 AM
    BlackdogGS
    BlackdogGS [OP] Well-Known Member
    This issue just started. When I put it in reverse it detects an object and triggers the alarm. Truck is a 2018.
    what’s the fix?
  2. Mar 28, 2023 at 9:04 AM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    Do you have anything blocking the sensors or have you made any changes to how the beeps function?
  3. Mar 28, 2023 at 9:15 AM
    BlackdogGS
    nothing has changed. Just starting doing this. Driving me nuts.
  4. Mar 28, 2023 at 10:36 AM
    blackZEBRA
    blackZEBRA Well-Known Member
    California
    '23 TRD OR DCLB
    But did you go out and physically check the sonar sensors?
    RIX TUX and Rock Lobster like this.
  5. Mar 28, 2023 at 10:39 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Thirded. Clean & check sonar. Make sure its plugged in.
    Failing that, just turn off sonar until you get it fixed. Its the button that says "P."
  6. Mar 28, 2023 at 11:04 AM
    BlackdogGS
    Yes, checked and cleaned the sensors.
    blackZEBRA likes this.
  7. Mar 28, 2023 at 11:34 AM
    BlackdogGS
    I’ve had a aftermarket step on my receiver hitch for the last 4 years and it never affected the sensor alarm. I removed it and the sensor worked fine. Reinstalled and it triggers the alarm again. I just adjusted the step to a lower position, haven’t checked it yet.
  8. Mar 28, 2023 at 2:13 PM
    stftaco
    stftaco Well-Known Member
    22 MGM DCSB Tacoma TRD Sport
    I think I read in another thread someone having same difficulty and culprit was salt and water incursion in the wiring I believe at the connector of the sensor. Good luck.
  9. Mar 30, 2024 at 4:44 AM
    hilighter
    hilighter Master of Disaster
    Portland, OR
    21 Tacoma MGM TRD OR DCSB ABCDEFG
    3” Ironman IM2.5 lift Body Armor stubby front bumper 10k Superwinch Ironman Raid rear bumper Custom sliders Nomad 501 17x8.5 Satin black wheels Smartcap Dashmat
    Did you ever find the fix for this?
    I was just rear-ended yesterday, ironically by another 3rd Gen Tacoma. After the “tap” that my trailer hitch received my back-up sensor has a constant beep (like you are super close to something).
  10. Mar 30, 2024 at 6:26 AM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Have your frame, hitch and sensors checked. Something is bent or a sensor is damaged
  11. Mar 30, 2024 at 10:42 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    You may get quotes to properly fix, it might have you filing a claim against their insurance. Especially if you have BSM.
  12. Mar 30, 2024 at 1:06 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    disconnect battery for 10, or
    check sensor plugs, or
    turn off. or
    take to shop
