Backup camera and lights don’t work??? FIXED
Discussion in '2nd Gen. Tacomas (2005-2015)' started by edgerat, Jul 29, 2019.
  1. Jul 29, 2019 at 7:07 PM
    edgerat
    edgerat [OP] Well-Known Member
    Isaac
    Olympia, WA
    Brown Tacoma
    gas and oils
    Not always the best idea to buy a grampy truck but, apparently I could not be stopped. 2009 ac cab v6, 6spd, SR5, 33,000mi on it. The backup lights and camera do not work. But, if you unplug the backup light bulb, whilst in reverse, there is a tone in the cab and the rearview mirror camera fires up. Thoughts?
  2. Jul 29, 2019 at 7:59 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
  3. Jul 29, 2019 at 8:14 PM
    edgerat
    Isaac
    Olympia, WA
    Brown Tacoma
    gas and oils
    my hunch is there is a short somewhere no? That would be the only explanation for the backup camera to start working when I unplug the bulb??? The passenger side bulb does not illuminate when I unplug the drivers bulb. I will try to decipher the diagram now :) Thank you!
  4. Jul 30, 2019 at 8:16 AM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    Give this a shot:
    • Get some electrical spray cleaner;
    • Use it on both reverse light sockets;
    • Replace both reverse lights w new ones;
    • See what you get from there; and
    • Let us know:D
    You might want to slap some anti seize on the rear light housing bolts- I know they can freeze up to the point of making them useless. (Ask me how I found that out...)
    Sounds like you made quite a find w that truck!!
    Jimmyh and edgerat[QUOTED][OP] like this.
  5. Jul 30, 2019 at 8:49 AM
    blu92in99
    blu92in99 Hates everyone, equally
    Elk Grove, Ca
    @edgerat Just to make sure I understand; neither reverse lamp(s) nor camera operate, when shifted into reverse. With the driver-side reverse lamp bulb unplugged, the camera turns on - but the passenger side reverse lamp does not illuminate. Correct?
    Have you looked closely at both reverse lamp bulbs, to verify; neither bulb is shorted, and no corrosion in the bulb socket or taillamp harness connector?
    With both reverse lamp bulbs removed, does the camera operate normally? Any aftermarket junk spliced in, like an alarm or remote start, etc?
    b_r_o and edgerat[OP] like this.
  6. Jul 30, 2019 at 10:56 AM
    edgerat
    Isaac
    Olympia, WA
    Brown Tacoma
    gas and oils
    Correct! I did purchase new bulbs yesterday, no change. I did try the passenger side bulb and it had the same result (camera on, still no lights on). One other wrinkle, after a handful of times doing the bulb unplug, it stopped having the same effect. That one has me more baffled... What is there a capacitor someplace that I dis-charged and now it doesn't work to unplug the bulb any longer???
    I tried "squishing" wires and wiggling the harness all the way up to the back of the cab to try and knock loose any short, no change.
    The whole truck has some, "it sat there for how long?" stuff going on so it is very possible that there may be some corrosion there. I will check for corrosion. What is the method for determining that there is a short? Put the ole voltmeter on there? If I understand the wiring diagram, the camera and lights are directly tied together so, fixing one issue will fix both the camera and the bulbs???
    No offense but, it looks like an 18mo old wired up the trailer lights connection as well. Someone took the time to do a two-wire run from the engine bay all the way to the trailer plug
  7. Jul 30, 2019 at 11:09 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    it's got shit trailer wiring ? been backed down into a boat ramp ass-under water ? rip all that crud
    out and go back to stock save yourself headaches
  8. Jul 30, 2019 at 11:15 AM
    DVexile
    DVexile Exiled to the East
    Ken
    2015 DCSB V6 TRD OR 4X4
    So based on your description the best explanation is that the IG voltage going to the backup lights and the review mirror has too much resistance on it. By removing one backup bulb you are reducing the load and thus the voltage appearing at the mirror is now high enough to cross whatever logic threshold turns on the camera. With two bulbs in there there is more load and the voltage drops even more and no longer triggers the camera.
    This probably means loose connection or corrosion somewhere from the fuse, through the back-up switch and then onto the harnesses that carry that voltage to the lights and the camera. I would use a volt meter to probe that voltage while in reverse (i.e. when the reverse switch is closed) to see where along the way it drops. An obvious place to start to test this hypothesis is as close the mirror's "REV" signal as possible.
    Good luck!
    PzTank, VirusCage, 127.0.0.1 and 2 others like this.
  9. Jul 30, 2019 at 11:42 AM
    edgerat
    Isaac
    Olympia, WA
    Brown Tacoma
    gas and oils
    Would a bad reverse switch possibly cause this? I am leaning more toward the corrosion side as several have pointed that out. However, not knowing how the reverse switch works on these it would make sense if that switch is dead/dying then it is not sending enough voltage to the circuit to operate everything.
  10. Jul 30, 2019 at 12:18 PM
    blu92in99
    Elk Grove, Ca
    Oh, joy!
    Gotta start with the obvious then. Even if you don't remove that BS trailer wiring, at least verify it's not tied into the reverse lamp/camera circuits before chasing this rabbit too far down the hole. The wiring diagrams are your friend here.
    A bad reverse switch could absolutely cause this, but I'd be hesitant to shotgun any parts at it without more diagnosis first. Unplug the reverse lamp switch and (key on, engine off) jumper the terminals in the connector; if the reverse lamps light up and camera engages - the switch has failed. The reverse lamp switch connector is located at 'B1' in this image; should make it easier to test this theory.
  11. Jul 30, 2019 at 12:32 PM
    DVexile
    Ken
    Yes, this. Definitely the low hanging fruit test at this point.
  12. Jul 30, 2019 at 12:43 PM
    edgerat
    Isaac
    Olympia, WA
    Brown Tacoma
    gas and oils
    on it! Will report back, pun intended.
  13. Jul 30, 2019 at 1:24 PM
    edgerat
    Isaac
    Olympia, WA
    Brown Tacoma
    gas and oils
    It also has this installed and doesn’t appear to be run to anything... just the alternator. :alien:
  14. Jul 30, 2019 at 1:32 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Looks like the truck had 2 batteries at one point.
    Both of which were on a separate circuit.
    Mostly used RV, camper, and things you don’t want tied to your main truck battery.
    edgerat[QUOTED][OP] likes this.
  15. Jul 30, 2019 at 1:37 PM
    blu92in99
    Elk Grove, Ca
    Yup. If I had to wager a guess; Probably part of that hacked-in battery wiring run all the way back to the trailer plug. The PO probably used to charge a trailer on-board battery while towing.
    edgerat[OP] likes this.
  16. Jul 30, 2019 at 1:42 PM
    TnShooter
    Deogee
    STOCK
    Yeah, I believe you are correct.
    I would probably start at the trailer wiring to see if they used the factory tail light wiring.
    I hope you get this figured out.
  17. Jul 30, 2019 at 2:01 PM
    edgerat
    Isaac
    Olympia, WA
    Brown Tacoma
    gas and oils
    This section of the forums is so much more cordial than the snake pit 3rd gen area heheheh. Makes me to keep grampy truck and build it up.
    Jimmyh likes this.
  18. Jul 31, 2019 at 2:42 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    If you have an Automatic the reverse switch is in the Park Neutral Safety Switch on the side of the transmission.
    If you have a Manual the switch is screwed into the transmission body.
  19. Jul 31, 2019 at 4:00 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    I agree with removing all aftermarket wiring before beginning the troubleshooting process. Personally, I would start by replacing the reverse switch just because it's a possibly of a faulty switch and it's only a $13 part.
  20. Jul 31, 2019 at 4:08 AM
    pgm944
    pgm944 Active Member
    SE Massachusetts
    2009 Tacoma Access I4
    Where is this located on the Manual Transmission?
    Can I get to it without jacking up the truck?
    Mine is "intermittent".
    Also thinking of wiring a dash switch to activate the lights and camera without being in reverse.
