Backed into Garage with Back Canopy Window Open
Discussion in '1st Gen. Tacomas (1995-2004)' started by bawilson21, Sep 11, 2020.
  1. Sep 11, 2020 at 3:43 PM
    bawilson21
    bawilson21 [OP] Well-Known Member
    Bryan
    WA
    00 SR5 V6 4x4 5-speed
    Rear Diff Breather Extension Deck Plate Mod 31" Destination A/T 3" Body Lift Rancho 5000 Shocks Grey Wire 7Pin Tow harness
    Doh!!
    I backed into my friend's garage with my rear canopy window open. I was going slow so nothing broke per say, other then the the seal to keep out the rain. That and the window frame is visibly bent and requires a little tug to the left when closing the window. Otherwise it opens, closes, and locks shut as expected.
    Since the glass isn't cracked, I think its safe to assume that the damage is confined to the frame only. Upon removal of the frame, I'll check for damage on the fiberglass shell, but I think that part is fine.
    So my question to the TW Community is;
    Any advice on how to fix this before I try? I plan on camping out of this so no leaks allowed.
    I know I'm not the only one who has done this.
    Photos Below.
  2. Sep 11, 2020 at 4:26 PM
    Parkvisitor
    Parkvisitor Do you know midnight?
    Juan
    So Cal
    It’s a truck
    stuff
    Just re-insert the rubber molding
    GQ7227 likes this.
  3. Sep 12, 2020 at 2:26 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    It comes down to how finicky you are !!
    Myself I would use it like it is .
    Maybe you need to replace the door if you can buy one from the manufacture of the shell the frame looks ok from the pictures
  4. Sep 12, 2020 at 8:25 AM
    bawilson21
    Bryan
    WA
    Not sure I follow. Do you mean just remove the window and reinstall, allowing the gasket to reseat itself?
    I'm pretty finicky!
    I think I'm going to remove the back window and see if I can straighten out the frame with a few pieces of wood and a hammer. I'll let you know how it goes when I get to it. I'm going to wait until Monday for the smoke to clear before I try. If I cant find a new gasket, does anyone have a liquid gasket recommendation? Some sort of RTV silicone sealant perhaps. Will tighten slowly in star pattern... Also, anyone know of the torque spec offhand for something like that...lol (Pretty sure I'll just be going by feel).
  5. Sep 12, 2020 at 1:39 PM
    Hamer95USA
    Hamer95USA Well-Known Member
    1999 Toyota Tacoma 4x4 SR5 extended cab reborn!
    Complete OME suspension kit, Used low mileage V6 engine swap, black powder coated Chou Seiki T15x7JJ, ARB deluxe bumper, Smitty Bilt nerf bars, Weathertech floor liners, Torklift tiedowns
    You might find this YouTube helpful for your dilemma:
    https://www.youtube.com/watch?v=qKXKZ7q5M24
  6. Sep 14, 2020 at 9:59 AM
    bawilson21
    Bryan
    WA
    This is actually pretty helpful. I have slightly different damage then he does but it gives me a few ideas like straitening the frame for the window in the vice grips. I'm going to head out there now and start taking a look at it. Thank you for sharing this.
    LarryDangerfield likes this.
  7. Sep 14, 2020 at 11:15 AM
    ElChapoSr
    ElChapoSr Well-Known Member
    Al
    I did exactly this - had a friend "guide me back" while we were moving at night, then whoops! My bad duuude...
    I bought another camper shell that was roached for $140 but had good windows, and used all the good windows and parts from one to the other. Replaced the bent/tweaked frame and window with a used frame and window. Super simple, all self tapping screws.
    They are typically aluminum extrusion frames, so your chances of bending it back straight and the frame not cracking are slim. Also parts from the manufacturers, if you can get them, are stupid expensive.
