Back seat not won’t latch
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Fishnwiz, Jan 25, 2020.
  1. Jan 25, 2020 at 8:08 AM
    Fishnwiz
    Fishnwiz [OP] Well-Known Member
    Bill
    2019 Silver TRD ORDCSB 4x4
    Seems the passenger side rear seat will not latch, nothing restricting it. I noticed it folded forward and it won’t latch back. Not an issue for me as no one rides back there, I’ll have dealer look at it on service. Might check your for proper operation.
  2. Jan 25, 2020 at 8:14 AM
    Shellshock
    Iowa
    Sometimes you’ve gotta slam it to get it to latch
    kgilly, Malvolio and Skydvrr like this.
  3. Jan 25, 2020 at 8:17 AM
    TacoMamba35
    TacoMamba35 Well-Known Member
    PNW
    2021 Tacoma TRD OR DCSB 3.5
    Make sure the seat belt latch points are tucked away.
  4. Oct 21, 2020 at 12:46 PM
    MrTacoTostada
    MrTacoTostada Member
    2019 Tacoma TRD 4x4 Off Road
    I found out mine doesn't latch either. The rear seat behind the driver.
  5. Oct 21, 2020 at 12:49 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    I leaned on mine once (the flat plastic back) and something popped. It made the noise that pushing in a fender or big piece of sheet metal makes. Ever since then, my passengers side needs to be slammed hard to latch
  6. Oct 21, 2020 at 2:01 PM
    JEEPNIK
    JEEPNIK Well-Known Member
    2020 Voodoo Blue TRD Sport
    A little lithium grease might help.
  7. Oct 21, 2020 at 2:03 PM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    I sense litigation. :evil:
    RobP62 likes this.
  8. Oct 21, 2020 at 2:39 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Can you see orange on the pull tab?
    Chew likes this.
  9. Oct 24, 2020 at 12:57 AM
    MrTacoTostada
    The rear seat that is behind the driver seat. The part where you sit on won't latch. I don't see how it logically can latch. On the bottom of the seat is the U shaped bar. On the floor there is just this white metal tab. Doesn't make sense.
  10. Oct 24, 2020 at 6:43 AM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    Happened to me right after I purchased my truck. The whole latch had to be replaced (under warranty)
  11. Oct 24, 2020 at 6:45 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    The part you sit on doesn't latch. Gravity and the top part hold it in place.
    Gunshot-6A, Skydvrr and RobP62 like this.
  12. Oct 24, 2020 at 9:51 AM
    JEEPNIK
    According to Einstein gravity doesn’t exist.
    Skydvrr likes this.
  13. Oct 24, 2020 at 9:57 AM
    ghost_ix
    ghost_ix Member
    Bay Area, CA
    2019 TRD Off Road
    This
  14. Oct 24, 2020 at 9:58 AM
    RedWings44
    Michigan
    Probably because the earth is flat
  15. Oct 26, 2020 at 7:13 PM
    MrTacoTostada
    Unfortunately, when I'm rough driving, the seat pops up. There should be something that keeps the part you sit on latched down. There's a U shaped bar under the seat and a plain white painted metal tab on the floor. The metal tab on the floor looks like something else should be there.
  16. Oct 26, 2020 at 7:57 PM
    kgilly
    kgilly Well-Known Member
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    Bed cover and Mud flaps, OEM Audio, Super Bump stops, Sumo Springs, Bed Stiffeners, Stryker hood shocks
    gotta slam mine pretty hard and now that i just put seat covers on the rears, even a little harder now..
  17. Oct 27, 2020 at 1:42 AM
    RedWings44
    Michigan
    Do you have any photos? What you're referring to sounds like it may be for child a car seat anchor, but I'd have to see to be sure.
  18. Oct 27, 2020 at 1:56 AM
    HighCountryTacoma
    HighCountryTacoma Well-Known Member
    Colorado
    2017 DCSB TRD Off Road Quicksand
    Are you hitting sweet jumps or something? That has to be some pretty "rough driving" to cause the seat to pop up.
    Watkinseli91 and RedWings44 like this.
  19. Oct 27, 2020 at 1:58 AM
    RedWings44
    Michigan
    I was thinking the same. Although it should be noted that my driver's side one will pop up if I lay the seat back down and put it back up. But a simple push back down and it is back in place and stays. No latch needed.
  20. May 2, 2021 at 2:45 PM
    Loan Wolve
    Loan Wolve ‘18 DCSB OR 4x4
    San Diego
    Cement ‘18 OR 4x4
    I can see orange on mine, and it can’t get it to ‘retract’ deep enough where it doesn’t show.
    (Reviving an old thread for help)
    Edit: if anyone is going through this (or for when I forget again), I had to take the plastic part on the back of my seat off and re-seat it. It looked bowed out, because somehow one of the plastic clips underneath the cover popped came out from under the bar they're supposed to attach to, causing the plastic cover on the back of the seat to push against the plastic below the window.
