Back seat headrest removal?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 12TRDTacoma, Aug 27, 2017.
  1. Aug 27, 2017 at 8:39 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    This is pretty straight forward.
    I have owned this truck for four going on 5 years now, and I have never once for the life of me been able to remove the backseat headrests.
    I thought it was just me until a buddy with a 2013 was trying to figure out the same thing. Even told me he read the manual and there was nothing about it.
    No matter what I have done in the past and what we did today I was never and we were not able to pull them out. So what gives? Is there a magic way to remove them or what? It seems pretty stupid to me.
    And before the smartass comments YES we have tried depressing the button which usually releases the lock on them.
  2. Aug 27, 2017 at 8:44 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
  3. Aug 28, 2017 at 7:39 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Push the button hahaha
    I've had my headrests in the back removed since I bought it.
    boogie3478 likes this.
  4. Aug 28, 2017 at 7:49 AM
    Climberclimb
    Climberclimb Well-Known Member
    Stacey
    British Columbia
    2020 TRD Sport premium
    Stock!
    They are a pain to remove - broke the centre one trying to remove it. Try and tap underneath and in the middle of the headrest as you pull it out. Good luck!!!
    Cheers
    12TRDTacoma[OP] likes this.
  5. Aug 28, 2017 at 11:06 AM
    Sidney Vicious
    Sidney Vicious Well-Known Member
    NOLAUSA
    2013 Black DCSB Prerunner
    Weird that you are having such trouble - all three came out with no effort on my 2013 - but I put them back as they area good safety feature for rear seat passengers - and folded down they offer very little obstruction to my view.
  6. Aug 28, 2017 at 11:43 AM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    Push the button while pulling up...simple
  7. Aug 28, 2017 at 11:44 AM
    BlueHeli
    BlueHeli Well-Known Member
    AZ
    2017 Quicksand TRD OFFROAD 6MT
    None
    All you need is too push the button and stick a paperclip in the small hole and lift up.
    brittbuck likes this.
  8. Aug 28, 2017 at 3:29 PM
    JdevTac
    JdevTac Well-Known Member
    Josh
    GA/WA
    2nd gen
    Are your headrests in backwards? Sound stupid but you'd obviously know cause they wouldn't fold the correct way, and they'd look wrong.
    Otherwise it's depress the button real hard and pull up hard as hell. They don't like to come out easily but they shouldn't be stuck in there either, they just take a little force which imo is best applied upwards on the button sided post then sort of work it up and out from there as you go.
  9. Aug 28, 2017 at 4:43 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Which way are these headrests supposed to fold? His folded a different way than mine, he has a 13 though. Either way we pressed the buttons on ours pretty hard and were pulling with a good amount of strength, neither of the headrests on either of the trucks have budged.
  10. Aug 28, 2017 at 4:54 PM
    QChawks
    QChawks Well-Known Member
    Davenport, IA
    2009 TRD Sport DCLB
    Easy peasy
    I took mine off because the kids car seats fit a lot better without them.
  11. Aug 28, 2017 at 6:03 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Had mine out on Saturday cleaning the rear window. Takes a little force, but they come out. They should fold forward. You should know if they're backwards. The fronts have regular seat like material, the back has a fuzzier carpet like material.
  12. Aug 28, 2017 at 8:31 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    It's funny you say that because my buddies folded backwards and that was the way it was designed. I forgot there was fuzzy carpet back there.
    I've considered putting pliers to squeeze the tab while someone used the might of Thor to remove them. It seems to be an impossible feat thus far.
  13. Aug 28, 2017 at 8:33 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
  14. Jul 22, 2018 at 4:23 PM
    brewhaha846
    brewhaha846 New Member
    Pennsylvania
    13 TRD Sport Dbl
    I realize this is an old thread but in case the answer wasn’t out there:
    2013 double cab
    Depress the button on the base of the left post with a finger/thumb
    While holding the left button, insert a screwdriver or other small object into the slot at the base of the right post to depress the release.
    While both releases are being pushed the headrest should slide up and off.
    12TRDTacoma[OP] and Dan 77 like this.
  15. Jul 22, 2018 at 4:24 PM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 Super White S/C DCLB TRD SPORT
    It’s not that hard lol
  16. Jun 22, 2019 at 12:46 PM
    Shreddr69
    Shreddr69 Member
    Joshua
    Royal Oaks, Ca
    '13 TX 4 door, 6 spd, 4wd
    3" Old man emu lift, front runner rack, TX decal delete, ARE camper shell and step bars.
    Screwdriver requirement is annoying but worked. Thanks dudes!!
