Back Glass Replacement: Anybody use Brad's Auto Glass replacement pane?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DesertRatliff, Dec 6, 2023.
  1. Dec 6, 2023 at 1:22 PM
    DesertRatliff
    DesertRatliff [OP] Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    Through no fault of my own (yeah right :frusty:), my passenger side back glass window broke.
    After researching a bit, I see now how invasive this replacement is with lots of people claiming that the pros they used to do it damaged, scratched and/or dented the cab of their trucks or they didn't re-seal it right and now their cab is rusting, cases where the wrong Chinese glass was used, etc etc; lots of horror stories. For that reason, I'd really rather just do the replacement myself to take my time and do it right.
    While researching, though, I found this guy's replacement videos on YouTube. He's the only one I've found who retails replacement window panes for the individual panels of the back glass slider in 2nd and 3rd gen Tacomas. Here's his 3rd gen replacement vid but the 2nd gen looks similar.
    2016-2023 Toyota Tacoma Back Glass Repair - YouTube
    Aside from the low-quality vid and a pretty sloppy install method, I gotta say this is a pretty enticing repair strategy for a ton of different reasons (it's A LOT cheaper and in doing it this way, you're not disturbing the factory urethane seal/cab interface). I had nothing to lose trying to remove the broken glass from the old frame/seal and, although I'm finding it tedious, have made progress getting the old glass out and am really leaning this direction unless someone tells me it's a waste of money and should just spend the money on the whole quality replacement and try to do it that way.
    What do you all think? Anybody used Brad's Auto Glass and done this themselves?
    tacoma_ca likes this.
  2. Dec 6, 2023 at 1:41 PM
    TacoTuesday1
    FL
    insurance
    competent glass shop
    warranty
    I'd be curious to know if a power full roll down window could be done, like what Tundras and 4runner's have
    tri-panel OE window with a tiny hole in the center is pretty useless
    I think those even come with rear defroster...
    Tiedie and EL DUDE like this.
  3. Dec 6, 2023 at 1:43 PM
    Tiedie
    Tiedie The Only Shantytown Resident.
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    Aworkinprogress and tacoma_ca like this.
  4. Dec 6, 2023 at 2:00 PM
    DesertRatliff
    Mt. Hood, OR
    Mas Tacos Por Favor
    Thanks for posting but not asking about a power slider; just want to replace one panel of my existing 3-panel back glass and was wondering about Brad's Auto Glass product.
    JGO likes this.
  5. Dec 6, 2023 at 2:05 PM
    DesertRatliff
    Mt. Hood, OR
    Mas Tacos Por Favor
    Might be a consideration (half the price of a new Toyota slider) but then I'm back to the potentially destructive removal of the factory frame.
    This back glass design (with no provison to safely replace it) is another bone-head engineering flaw on these trucks.
  6. Dec 6, 2023 at 3:25 PM
    Tiedie
    David
    WFOY
    I hadn't looked into install but at half the price then let Toyota install, be on the hook for any damage.
  7. Dec 6, 2023 at 4:36 PM
    DesertRatliff
    Mt. Hood, OR
    Mas Tacos Por Favor
    The solid back glass you linked is $300 from Toyota, the sliding 3-panel back glass is $600+ and that's just the glass before install.
    I'll try to be more clear and say that making the choice to go to a local dealer for the installation of anything (even floor mats) is not a choice I'll ever make so the question is: Anybody have anything good or bad to say about Brad's Auto Glass? Lol.
    lbregman and JGO like this.
  8. Dec 8, 2023 at 12:32 AM
    TacoTuesday1
    FL
    insurance doesn’t cover dealer glass replacement
    glass replacement is done by glass replacement shops
    Another option is convert to solid single panel
    Unless you have a dog in the back
    side windows cracked down with visors vent the same
    Converting to single panel would give the ability to install defroster lines for winter
  9. Dec 8, 2023 at 2:45 AM
    Tatts521
    Tatts521 Well-Known Member
    New Jersey, Jersey Shore
    2012 tacoma-04cbr1000rr-22ktm890duke R-19 wr450f-98rm250
    Dealers normally don't installs they sub contract the work out. Tacoma back windows are held in by 8 bolts and urethane. The job isn't that difficult just time consuming. Oem glass will always be more expensive. Aftermarket isn't as bad as think it is. Hope everything works out for you.
    davidstacoma likes this.
  10. Dec 8, 2023 at 4:01 AM
    JGO
    JGO Well-Known Member
    South Central Kentucky
    '14, 4 Cyl, A/T, Silver A/C
    So far, the answer to your question seems to be "No, no one has used Brad's".
  11. Dec 8, 2023 at 5:40 AM
    DesertRatliff
    Mt. Hood, OR
    Mas Tacos Por Favor
    I'm only seeing 4 bolts. Can you confirm? Thanks
  12. Dec 8, 2023 at 5:40 AM
    DesertRatliff
    Mt. Hood, OR
    Mas Tacos Por Favor
    I'm dead :rofl::rofl:
    slossboss and JGO[QUOTED] like this.
  13. Dec 8, 2023 at 8:08 AM
    Tatts521
    I guess they are a bit different than the 2nd gen. If you do it yourself make sure you use urethane adhesive.
  14. Dec 8, 2023 at 9:09 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Two Studs and Nuts at the bottom corners, Two Tabs at the top corners and urethane glue.
    Tiedie and DesertRatliff[OP] like this.
  15. Dec 8, 2023 at 9:13 AM
    Tatts521
    Yes the whole window gets glued in. The bolts just help snug it in there. Tacomas are easy installs for a experienced tech. Nowhere near as stressful as a ram power slider.
  16. Dec 8, 2023 at 9:17 AM
    Tatts521
    I replaced @HomerTaco rear glass a couple years ago.
  17. Apr 22, 2024 at 9:50 AM
    OrellanaR
    OrellanaR New Member
    Roberto
    2023 white Tacoma TRD Sport
    Trd PRO grill
    @DesertRatliff Dis you experience window back glass patch from Brad´s Auto Glass? I am in need of changing the left panel of my Tacoma and it seems a good alternative. I have read many reviews from his youtube channer and website and it seems it works. Let me know if you tried!
  18. Apr 22, 2024 at 11:40 AM
    dtaco10
    dtaco10 Well-Known Member
    Dave
    Anoka County, Minnesota
    2010 White Tacoma 4x4, 4.0, Auto
  19. Apr 22, 2024 at 1:58 PM
    racerX969
    racerX969 Active Member
    I did my driver side with Brads, wasn't to hard looked decent but the truck had 340000 miles on it and didn't care
  20. Apr 22, 2024 at 2:12 PM
    OrellanaR
    Roberto
    Trd PRO grill
