Baby Seat in Access Cab - Possible?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Negative1, Mar 31, 2009.
  1. Mar 31, 2009 at 5:16 AM
    Negative1
    Negative1 [OP] Well-Known Member
    I've searched and found a couple of topics but they were related to fitting baby seats into a double cab.
    My question is, can a baby seat fit in a "Access Cab" ?
    If so, does anyone have a picture, it would help reinforce my decision on the truck I bought last night :confused:
    Me and my wife would greatly appreciate it.
    Thanks
  2. Mar 31, 2009 at 5:20 AM
    JDCPA
    JDCPA Well-Known Member
    Jim
    SW FL
    09 5 Lug Access Cab SR5
    Curt Hitch and etrailer.com wiring harness.
    You put it behind the passenger seat and have to move the seat up a little but it will fit and there are LATCH connections to fasten it to.
  3. Mar 31, 2009 at 5:30 AM
    AUDITECH
    AUDITECH Carolina Alliance: LAZY DIVISION
    charlotte nc
    07 double cab prerunner
    none
    I wouldnt even try its tight in the double cab
  4. Mar 31, 2009 at 5:34 AM
    harshest
    harshest I am the Sofa King
    Michigan
    05 PreRunner SR5
    Fog Light On, Hidden Garage Door Opener, Scanguage II, Weathertech Liners, Cig lighter always on, Door buzzer removed from dash- Upcoming: 5100s for front and rear, set fronts to 2.5" and Toytec AALs.
    I have a one and a two year old that I put in my 05 AC. It is a tight fit but it can be done safely. Just refer to the manual on how to properly connect it. This is not my primary kid hauler so for us it's OK.
  5. Mar 31, 2009 at 5:50 AM
    paintdiddy
    paintdiddy Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
    its not going to fit rear facing in a access cab. i had to buy a d/c for that reason of a newborn,and its still a tight fit. if you face the seat foward it should be a problem (i think)
  6. Mar 31, 2009 at 5:51 AM
    TL697
    TL697 Well-Known Member
    Jacksonville, FL
    '09 DC SB 4x4 TRD Offroad Magnetic Grey Met
    This was the deciding factor for me buying the DoubleCab... I don't even have kids, yet... So far, I love my DoubleCab Shortbed...
  7. Mar 31, 2009 at 6:28 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    It will fit rear facing....it's tight.but doable. Forward facing would be better...and it might not be great as a primary kid hauler cause it is tight...but I'm taking my boy to daycare in mine in a few minutes...
  8. Mar 31, 2009 at 6:40 AM
    PatHLC128
    PatHLC128 College.
    Pat
    Austin, TX
    09 TRD Off Road 4x4 AC
    OME complete 3" kit, 265/75/16 Cooper STTs, Pro Comp 7089 wheels, Shrockworks sliders, UWS Low Pro Toolbox, AFE Pro-Dry S, OEM Bedmat, Ventvisors, Husky Liners, Tint, De-badged
    ive done it with a rear facing seat as well...it was very tight and the passenger seat had to be all the way up. as stated above its fine as long as its not your primary kid hauler since it does work but not very comfortably.
  9. Mar 31, 2009 at 6:47 AM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    the primary reason I got the double cab is that I didn't want to struggle with baby seats. If I were you, I'd return it and get the DC.
  10. Mar 31, 2009 at 7:09 AM
    harshest
    Michigan
    05 PreRunner SR5
  11. Mar 31, 2009 at 7:13 AM
    06dak
    06dak Well-Known Member
    Central Ohio
    05 PreRunner SR5 4cyl
    Undercover hard tonneau, Husky front liners
    It'll fit, don't worry... it may not be comfortable though, depending on what you mean by baby seat (forward facing, rearward facing, booster, etc)
    If forward facing I'd put the baby seat in front (front seat has LATCH, airbag can be turned off) and the wife in the back. Or in the back with the passenger seat folded to a table. Either way you only have that seat for a year so it's short term. In mine I have a forward facing baby seat in the back passenger side and a booster on the driver side and we can fit 4 comfortably for shorter trips. Even long trips if we had to, just don't have space for other stuff (like diaper bags, movies, etc).
  12. Mar 31, 2009 at 10:00 AM
    Veccster
    Veccster bass turds
    Eric
    Pittsburgh - The City of Champions
    2020 Pro
    It'll work. Hell, I had one in both positions (rear and forward facing) in the back of my 1st gen access cab.
    I bought the doublecab because it was EXTREMELY uncomfortable if someone had to ride up front with me. It was better for my wife to sit in the back because the front seat had to be all the way forward. This may be moot point because the 2nd gen is bigger.
    BUT....plan on growth. Those legs are small now but eventually grow and stick out past the end of the car seat. They don't bend down a first - just stick straight out.
    I have a seat in my Doublecab and it fits well. This is a multi-use seat that accommodates from 0-80#'s. Here it is forward facing in my DC. You can see how tight it is. She is only 1.5 yrs old and I have since wrapped the rear of the front seat because she kicks it with her dirty shoes.
  13. Mar 31, 2009 at 10:32 AM
    Negative1
    Thanks for the responses guy's.
    I should have mentioned that this Tacoma is not our primary vehicle, we do have a camry for most of our car needs.. The taco will be used every now and then, when we need to.. So if it's possible (and some of you are saying it is) then I think were ok.
    On the 2009's, (at least in Canada) the car seats have to be put in the rear of the drivers seat, and not the passenger side. It has the instructions there and the nylon strap.
  14. Apr 10, 2009 at 2:47 PM
    IndigoBlue2006
    IndigoBlue2006 Member
    Spokane, Washington
    2006 Access Cab 4WD
    K&N Drop In Air Filter, Rear Spring TSB, All Weather Mats, Hood Protector
    I have an 06 Access Cab and yes you can fit a car seat in it. We have the Chicco KeyFit 30. It is rear facing and has a base that stays connected in the car and the seat just snaps in and out. In my truck, i fold down the little seat covering the storage compartment, set the base on, and used the LATCH anchors. The car seat base has a bubble level on both sides and I had to put a couple sheets under the seat handle to jack it up to a proper level. Yes, you do have to have the passenger seat rather far forward, but I usually only have the little guy in my truck when I'm alone. If my wife is coming along, we drive her 09 Matrix.
  15. Sep 19, 2017 at 11:16 PM
    joestacos
    joestacos Ice cold rice water
    that1tacoguy
    CenCal
    17 Tacoma TRD Off Road
    Pro Driver inside
  16. Sep 20, 2017 at 8:41 AM
    Flyinhigh
    Flyinhigh Well-Known Member
    GA
    2018 SR DCSB 4x4
    In my 2012 I put my sons rear facing car seat in the middle of the truck when my wife rode in the truck too, the two front seats cradled it also and hooked to a latch on each side. This worked very well. When it was just me and him I put him behind passenger seat and folded the front seat or pushed all the way up. Hope this helps your situation. It was also the chico keyfit.
  17. Sep 20, 2017 at 8:51 AM
    gkomo
    gkomo Well-Known Member
    San Diego, CA
    2014 MGM AC SR5 4x4
    I don't have kids yet but my fiance and I are already contemplating getting a double cab for future growth. She has a '17 Jetta, but does outside sales so she can't really have baby crap in her car when taking clients out... whiiiiiich leaves my truck for potential kid duty.
  18. Sep 20, 2017 at 8:54 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    carried my twins in my 99 taco access cab both on pass side. it was a tight fit and had to take out the front seat one everytime
  19. Sep 20, 2017 at 9:02 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    Buy a full size!
  20. Sep 20, 2017 at 9:18 AM
    gkomo
    San Diego, CA
    2014 MGM AC SR5 4x4
    She wants a Raptor... i'm all for it!
