B&M/Derale/other Transmission cooler with a fan
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sandman614, Jan 22, 2014.
  1. Jan 22, 2014 at 7:12 AM
    Sandman614
    Sandman614 [OP] Ex-Snarky TWSS elf, Travis #hotsavannahdotcom
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
  2. Jan 22, 2014 at 11:09 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    I'm ready to order one now, credit card in hand. Any opinions?
  3. Jan 23, 2014 at 4:58 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    Bump. Help me spend some money.
  4. Jan 23, 2014 at 9:44 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    After reading and watching YouTube I'm debating if I need a fan.
  5. Jan 23, 2014 at 9:47 AM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    most factory ones dont have a fan
  6. Jan 23, 2014 at 3:05 PM
    trdtoy
    trdtoy Well-Known Member
    North Carolina
    02 sr5 4x4 auto v6 turbo (sold)
    Turbo with supporting mods and tranny to hold power.
    Plate and fin > tube and fin
    Fan > no fan
    If you want for low/no speed cooling and off road plate fin fan and thermo switch is way to go.
  7. May 27, 2018 at 9:53 AM
    AR15xAR10
    08 SR5 4x4 V6 IndigoInkPearl ACLBFTMFW
  8. May 27, 2018 at 12:11 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
  9. May 27, 2018 at 1:10 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    #zombiethread
  10. May 27, 2018 at 1:12 PM
    Sandman614
    Tim
    '06 SR5 Off Road
  11. May 27, 2018 at 1:12 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    That is a huge cooler. My oil cooler is that large. That cooler has -10AN fittings. You would need to adapt down to a smaller fitting. I believe the trans ports on the radiator are 3/8" which is -6AN.
    AR15xAR10[QUOTED] likes this.
  12. May 27, 2018 at 1:17 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
  13. May 27, 2018 at 1:25 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
  14. May 27, 2018 at 2:06 PM
    AR15xAR10
    I didnt not realize. You know that I dont know what i'm doing :anonymous:
    Do you know if they have something more my size?
    I'm currently pulling hills in an unloaded truck at 210-240* no factory towing package, so i have to do something. I would like something of really good quality that can handle mud and abuse.
  15. May 27, 2018 at 2:28 PM
    Sandman614
    Tim
    '06 SR5 Off Road
  16. May 27, 2018 at 4:14 PM
    lynyrd3
    Bill
    East Central Upstate NY
  17. May 27, 2018 at 7:09 PM
    04TacoRunner
    04TacoRunner Toyota Junkie!
    CC TX
    Fluidyne Fluid Coolers DB-30115
    I am running one of these on both my trucks my 4runner would run hot as hell at times but since adding this I have had to ad an external thermostat for cooler weather. Fluidyne makes some great stuff have used them in the past on a few high HP car builds and have always been impressed... Factory Tacoma cooler in front for reference.
    TACOVRD and Torspd like this.
  18. May 28, 2018 at 9:48 AM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    does this model require any fitting modifications? I have an o/r 4x4 and want added cooling to cope with supercharger stresses.
  19. May 28, 2018 at 9:29 PM
    AR15xAR10
    TACOVRD likes this.
  20. Aug 9, 2018 at 6:30 PM
    TACOVRD
    TACOVRD I Identify As A Prius
    TW Addict
    AZ/WA
    2019 T4R ORP - Formerly 2013 DCSB OR Spruce Mica
    Workin' on it....
