Axle Swap for LT
Discussion in 'Long Travel Suspension' started by 661prerunner, Nov 24, 2011.
  1. Nov 24, 2011 at 11:22 AM
    661prerunner
    661prerunner [OP] Well-Known Member
    Santa Clarita
    01 prerunner
    FabTech C/Os, Solo tubular UCAs (on order)Solo spindles(not installed) Glassworks front and rear, made by me Rocksliders, Premier Navi,
    I was curious to see if any one has swap out a stock taco axle. to a T100 or Tundra. Wondering how easy it is to on. Im also guessing it has to be off a 3.4 liter engine if off a Tundra/T100. So if any one can help or if there ia already a thread for this
  2. Nov 24, 2011 at 11:32 AM
    Nicks4x4LT
    Nicks4x4LT Official Villain
    Nick
    714 Orange county
    2010 4x4 V6
    Custom front bumper, Icon 2.5 ext. travel coilovers, Defined rear long travel King smooties w/ resi. Avid Offroad sliders, Fiberwerx front fenders, Glassworks Shorty TT style rear glass, URD MAF calibrator, DT shorty headers, URD TCAI, Magnaflow catback
    Im sure both have been done :popcorn:
  3. Nov 24, 2011 at 11:35 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    search google, been done numerous times
    2004Taco likes this.
  4. Nov 25, 2011 at 9:45 PM
    Tacorunner87
    Tacorunner87 Well-Known Member
    Chino Hills Ca
    To much to list!
    The yoke will bolt right up to the drive shaft since the tundra/t100 use the same 3rd member as the 95.5-04 4x4/prerunner tacomas. The spring perches are in the wrong locations and will have to be cut off and moved. If i remember correctly they are on the bottom of the axle where on the stock setup they are on top. If you are doing a LT setup you want them on the bottom as well.
  5. Nov 25, 2011 at 9:55 PM
    Dmonkey
    Dmonkey Well-Known Member
    Branden
    NorCal
    VZN159L (2002 DC)
    Eibach height adjust shocks in front, KYB monomax shocks in the back. Stock springs front and back. Level 8 MK6 10mm offset wheels on Cooper ATP tires (stock size)
    ford 8.8 go
  6. Nov 30, 2011 at 7:46 AM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
  7. Nov 24, 2012 at 8:06 PM
    adrn1986
    adrn1986 Well-Known Member
    Adrian
    Riverside Ca
    04 Pre-Runner
    -Icon Coilovers and Bypasses -LT Front and Rear -Supercharged
    If you can LT SUA a Tacoma axle, you can LT SUA a Tundra/T100 axle. The spring mounts and axle mounts have to be moved anyway, as well as cycle the leafs to figure out shock mounts. Using a wider axle housing while doing the fab process isn't really going to make a big difference. Brake line bolts up, ABS(if applicable) clips right in and E-Brake will work too w/so minor mods.
    *Direct Bolt-On Exception: My truck is a 2004 TRD. So the stock pinions have a higher spline count then prior year Tacoma's (27 teeth vs 33 teeth, I think, I could be wrong). I used a 2006 TRD w/LSD axle for my LT, which I re geared prior to installing it. After market ring and pinon gear sets have the spline count of the older year Tacoma/Tundra so I had to buy an older Tacoma drive shaft yoke. Easy fix :D
    LukeCC likes this.
  8. Nov 26, 2012 at 1:25 PM
    661prerunner
    Santa Clarita
    01 prerunner
    sweet thanks. I look in to doing it after I finish MTing the front end
  9. Nov 27, 2012 at 7:59 PM
    Conman117
    Conman117 AWESOME MEMBER
    Nathan
    BC, Canada
    98 Brap-coma
    Blue LED dash lights
    Just keep in mind that the tundra axle is 3" wider per side, plus different wheels and tires can put you pretty far out. My tires sit about 5" wider per side over stock. Just make sure you get the right bedsides if you need to cover the tire tread with your fender where you live. I have 7" flares and they just cover.
  10. Dec 7, 2012 at 6:56 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    This. It's much wider. And people generally d it match the 3.5" wider stance of LT setups...but if your just doing mid travel..what's the point??
  11. Dec 9, 2012 at 12:10 AM
    661prerunner
    Santa Clarita
    01 prerunner
    Well this was last year and Since i recently bought Solo spindles I'm just gonna MT then work on LT for the rear. But I still do plan on full LT. But I still have to do gusseting and boxing the frame. And the axle is just an idea to have more bed space by running the shocks outside the frame. Just for my bikes
  12. Jun 2, 2016 at 2:55 PM
    RedManRocket
    RedManRocket Well-Known Member
    Red
    Sonora, Central Cali
    2002 Double Cab LT
    Esb 5.5 with Kings Mcneil 6.5 fenders Other stuffs
    How would this be for a double cab, I'm looking at a good deal right now, but don't know if I will be able to find fenders to clear it.
  13. Jun 5, 2016 at 12:29 AM
    whitetoblack
    whitetoblack ******
    Tyler
    SoCal
    02 Prerunner & 08 Prerunner
    Johnny Branch Fabrication, King, Deaver, Glassworks, Toyo Tire, Alpine, work in progress...
    Here was my setup with a Tundra axle and Glassworks 6" glass. It is not listed on their website from what I remember but they do have a mold and make them.
  14. Jun 5, 2016 at 12:50 AM
    RedManRocket
    Red
    2002 Double Cab LT
    That's badass that's exactly what I need I have 6.5 McNeil up front and 6 inch in the back would be awesome. Thanks man!!
  15. Jun 5, 2016 at 12:55 AM
    whitetoblack
    whitetoblack ******
    Tyler
    SoCal
    No worries. I can't remember for sure if they called it 6" or 7" but just give them a call. Much better than email to get ahold of them
  16. Jun 5, 2016 at 1:41 AM
    RedManRocket
    Red
    2002 Double Cab LT
    I'll call them tomorrow, I'm working on gathering supplies for the ass end long travel.
  17. Jun 5, 2016 at 2:01 AM
    RedManRocket
    Red
    2002 Double Cab LT
    Also what leafs are you running? And how do they feel?
  18. Jun 5, 2016 at 2:53 AM
    whitetoblack
    whitetoblack ******
    Tyler
    SoCal
    I am running the Giant Motorsports 64" Deaver kit. Best rear suspension hands down without going to a link setup. It requires a Tundra axle or wider to run it on 1st gens.
    photobucket-40822-1359684082118_zps09eda_cfac40253f0f531ada762833292674a60fcf0406.jpg
    photobucket-4651-1359858063966_zps606484_57f95e6c5ca7ef8fab14b5ea5278dce648d78462.jpg
    Still running them with the new custom rear end
    Hawk373, Brice, Zam15 and 2 others like this.
  19. Sep 27, 2016 at 8:25 PM
    felixre7
    felixre7 Member
    Tucson
    01 Tacoma TRD
    Camburg LT Bumpers Sliders OBA Winch 35"s
    +1 to the f67's they are amazing
  20. Jan 15, 2017 at 7:03 AM
    adrenal321
    adrenal321 Member
    Edgar
    Los Angeles County
    95.5 Tacoma 4x4
    None all stock
    Hi, what front kit are you running?
