Axle nut
Discussion in '1st Gen. Tacomas (1995-2004)' started by vtlogger, Sep 12, 2021.
  1. Sep 12, 2021 at 2:55 PM
    vtlogger
    vtlogger [OP] Well-Known Member
    jerry
    bridport
    tacoma
    small 2" lift 32" tires
    Does anyone know what size socket I need to remove the front axle nut, the ones I have don’t fit
  2. Sep 12, 2021 at 3:02 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Your talking Manual locking Hubs or ADD ??
  3. Sep 12, 2021 at 4:01 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    35mm for add.
    vtlogger[OP] and Area51Runner like this.
  4. Sep 12, 2021 at 4:09 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    A 1 3/8" socket will work as well.
    Area51Runner likes this.
  5. Sep 12, 2021 at 4:33 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    CLICK ME
    vtlogger[OP] likes this.
  6. Sep 12, 2021 at 4:40 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    You will also need a torque wrench that can do 173 foot pounds.
  7. Sep 12, 2021 at 6:22 PM
    vtlogger
    jerry
    bridport
    tacoma
    Sorry guys, it’s the Add front end, thanks for the help
  8. Sep 12, 2021 at 6:22 PM
    vtlogger
    jerry
    bridport
    tacoma
    ADD
  9. Sep 13, 2021 at 8:48 AM
    warmingupmymind
    warmingupmymind Well-Known Member
    Anmol
    San Francisco
    2000 Lunar Mist SR5
    33s and lockers
    The real pro tip. Mine only went to 150 ft lbs so I had to order one and wait 3 days to get my truck off stands.
  10. Sep 13, 2021 at 9:05 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    I would have probably done 150 ft/lb and 1/8 turn past but as always YMMV
    vtlogger[OP] and treyus30 like this.
  11. Sep 13, 2021 at 9:32 AM
    warmingupmymind
    Anmol
    San Francisco
    2000 Lunar Mist SR5
    33s and lockers
    Fortunately, the taco isn't my only vehicle so it wasn't a big deal but I thought about doing something like that
    vtlogger[OP] and Wulf[QUOTED] like this.
