Awning without a rack on my cap?
Discussion in '1st Gen. Tacomas (1995-2004)' started by coldaccord, May 21, 2021.
  1. May 21, 2021 at 8:19 AM
    coldaccord
    coldaccord [OP] Well-Known Member
    André
    Buffalo, NY
    2000 Tacoma 3.4L 4x4
    I have a snugtop camper shell but no roof rack. I’ve searched and haven’t really found much, which likely means I need to buy a roof rack heh
    Any suggestions for mounting an awning with no roof rack? Looking to take my truck on its first camping trip where I don’t bring a stand-alone tent. Will be setting up camp for 3 days, doesn’t have to be a cool/quick/easy method
  2. May 21, 2021 at 8:49 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I'd just suggest a pop up.
    Very versatile as you can set it up anywhere you want versus orientating the vehicle in a specific manner to block the sun; this could limit how you set up camp.
    I do have an awning, and I've used it (really like it) but only because I've been lucky to have an open area to park in. Otherwise, I've always used a pop up before I ever bought it.
  3. May 21, 2021 at 8:59 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    You don't really need a full-on rack, but you'll need some sort of brackets to mount it to. Those would likely have to be custom.
    I definitely see the advantages to an awning, but I'm with @Kwikvette here, an ez-up is way more versatile and you can leave it set up while you head out for the day.
    For the types of trips where you set up camp then head out for day trips, ez-ups are definitely the way to go, but you of course don't get the "overlander" street cred.
  4. May 21, 2021 at 9:04 AM
    coldaccord
    André
    Buffalo, NY
    I take a lot of road trips, hoping to just sleep in the truck bed now that I have a cap and pad. I’m a little hesitant to use an EZ Up, saw one properly secured put some nice dings in a friend’s vintage gt350 on a windy camping trip at watkin’s Glen
    awning would be nice to keep the sunny side off the cap window is a main reason. I don’t have any bars on the cap or cab though
    What type of brackets options do people use on cap/cab? Or do I need bars on each likely?
  5. May 21, 2021 at 9:12 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Well if you insist on having one, figure out a means of adding a rack or some an extruded aluminum bar.
    Here's my awning set up -
    Here's my pop up setup -
    Again, the awning is cool and all but the pop up can be moved in a variety of ways for convenience, not to mention having walls that provide additional wind/sun block.
    Kjstaco likes this.
  6. May 21, 2021 at 10:09 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Large beach umbrellas
    Try not to look like all the other overlanders.
  7. May 21, 2021 at 10:22 AM
    coldaccord
    André
    Buffalo, NY
    not many overlanders in Buffalo, NY, don’t really have to worry about that
    I do have a gigantic beach umbrella I bought for a past gf & her dog, but it wouldn’t be able to accommodate my shading-the-sunny-side-of-the-cap hope
  8. May 21, 2021 at 10:55 AM
    Bluecord
    Bluecord Well-Known Member
    Jeff
    Louisiana
    2003 Tacoma 4x4 TRD Lunar Mist Metallic
  9. May 21, 2021 at 11:28 AM
    Bluecord
    Jeff
    Louisiana
  10. May 21, 2021 at 11:37 AM
    jbrandt
    Justin
    If it's wind you're worried about, the awnings honestly don't really fair that much better. Most are pretty flimsy and need to be tied down just like the ez-ups would
    Generally, a roof rack is the easiest option for mounting an awning, but like I said, if you don't want a rack, you're likely looking at a custom set of brackets. Although you'll probably still want something that uses normal cross braces (what the rack would attach to) for strength.
  11. May 22, 2021 at 3:00 AM
    Five
    Five Well-Known Member
    I'm in the same delema, I want an awning but don't want a roof rack. I was toying of the idea of installing angle iron and then bolting/securing the awning to it. I do not care about putting holes or resell value of my truck shell.
  12. May 25, 2021 at 3:29 PM
    coldaccord
    André
    Buffalo, NY
    I'm hesitant to put holes in my cap for water-tight reasons
  13. May 26, 2021 at 6:33 PM
    coldaccord
    André
    Buffalo, NY
    A local friend had this to say on the truck awning vs ez up:
    “they are easy, light, move aroundable and cheap! But they are NOT water proof, light duty, and cheap!”
    some of you may be interested in what he daily drives, so photo attached
    Steves104x4 and ekul310 like this.
  14. May 27, 2021 at 5:42 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I tried different mounts all but drilling tend to fail or leave things hanging at the worst time.
    look at stand alone awnings about all the option if your not drilling your cap.
    SLAPS 65 likes this.
  15. May 28, 2021 at 7:31 PM
    Five
    I drilled a 6" hole for a fan on a brand new $2,200 truck cap for my Tundra. Its been 6 years, no leaks. It does leak around the bed rails due to poor gaskets or install tho.
  16. May 28, 2021 at 7:50 PM
    BookieBob
    BookieBob Beer Drinker
    Racine,Wisconsin
    2021 Silver Sky TRD Sport 4WD MT
  17. May 28, 2021 at 8:01 PM
    MNMLST
    MNMLST Well-Known Member
    Earth
    tinfoil lined cab runflat headlights pee-thru seats
    small, simple, light, wind goes through it, doesn’t do anything for rain, can tie it to the truck if I want…
    https://www.neso.com/
  18. May 28, 2021 at 8:26 PM
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    I had a set of these on my snug top shell. It does require drilling into the shell though.
    I had a 270 degree awning attached to it.
    It worked well.
    I paid a lot less for two cross bars and brackets.
    https://vantech.us/product/m-series-ladder-roof-rack-system-for-box-trucks/
    Edit: as for drilling I had no leaks for 6 years.
    Steves104x4 likes this.
  19. Jun 3, 2021 at 9:38 AM
    coldaccord
    André
    Buffalo, NY
    The EZ Up worked well, kept the sun off my bed for much of the morning. I didn’t move the truck for 4 days but I appreciate the option to.
    Now if I can just find a waterproof model
  20. Jun 3, 2021 at 9:44 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Told ya a pop up would work well :burp:
    Stupid convenient.
    coldaccord[OP] likes this.
