Awesafe Factory Radio replacement
Discussion in '3rd Gen. Tacomas (2016-2023)' started by NYK, Aug 6, 2023.
  1. Apr 15, 2024 at 10:53 AM
    atc250r
    atc250r Recovering Ram Owner
    Orange County, NY
    2022 Tacoma SR5 - DC/LB
    LED interior, license plate, and fog lights. More to come.
    Put mine in the other day. Had a bad experience with an Awesafe in my 05 Accord due to it cold booting everytime I started the car and also it not running the rear defroster effectively but this one seems OK (it isn't involved in the HVAC system). It's about what I exoected from a cheap Chinese unit without a lot of memory or processor power. I did notice there was a connector on the radio end that matched to two plugs on the factory truck harness in the dash so either could fit in the connector. One was black and one was white. IIRC the white one was what you use.
  2. Apr 16, 2024 at 9:57 AM
    hunnersanners
    hunnersanners Member
    Hunter
    2016 Quicksand Tacoma TRD OR
    3in lift Cat Back Exhaust TRD Pro Grille
    Tried taking a good photo. The radio comes with 2 main harnesses. You only use one that matches all your plugs from the factory radio. Be sure to plug in the orange box that comes with the new unit into whichever harness you use. For the backup camera, the main harness has a single yellow connector labaled as “back video in”. This connects to one of the small additional harnesses with a single yellow connector. The other plugs you should see in the photo. One of which goes to the truck and the other comes from the main harness. I hope this makes sense and best of luck with your install!
    atc250r likes this.
  3. Apr 19, 2024 at 7:08 AM
    atc250r
    Orange County, NY
    Probably my biggest complaint is the volume controls work but the other two buttons on the steering wheel do nothing and it won't let me program them at all. I've reached out to Awesafe about it and they claim it's a bad CANBUS module and that they're shipping me a new one. I'm skeptical because I'd think if it was the module it wouldn't work for one but not the other. The other issue is it doesn't automatically switch Waze from day to night mode when it's dark out but the Xtrons Android head unit in my daily driver does so I'm forced to either leave it in dark mode on both vehicles or switch back and forth when I switch cars. I guess we'll see what happens when the new CANBUS module shows up. We're leaving for a 10 hour drive to WV in 5 days and it'd be nice to have the steering wheel buttons working 100%.
  4. Apr 19, 2024 at 4:23 PM
    hunnersanners
    Hunter
    I agree, my skip buttons do not work either and i’ve tried “learning” them multiple time. I thought I had just gotten a bad egg like you. Let me know if the new CANBUS module works, if so, i’ll reach out and do the same thing. My other biggest complaint is the back-up camera seems to be super laggy sometimes.
    atc250r likes this.
  5. Apr 19, 2024 at 5:30 PM
    atc250r
    Orange County, NY
    Yeah, in my 05 Accord I had to "teach" the head unit which button did what. You could assign the buttons however you wanted so you could make volume up skip to next track and volume down do volume up if you wanted. This one I go through a similar screen but nothing changes.
  6. Sep 3, 2024 at 9:00 AM
    NYK
    NYK [OP] Member
    2019 Concrete Tacoma TRD OFF-ROAD
    from what I noticed there's a setting in the actual head unit that you have to turn to learning then go and relearn the controls. In default that switch stays in a mode that won't learn or update anything. Let me know if that helps I can take some more pics of where the settings is when I get back to the car if you'd like
  7. Sep 3, 2024 at 10:56 AM
    atc250r
    Orange County, NY
    I tried that with mine and had no luck. Awesafe sent me another CANBUS adapter that they said would fix it but at that point I was fed up with getting blinded when it was dark out because it doesn't automatically switch Android Auto between day and night mode so I had already pulled it out. Of course by then it was too late to return it. When I get a minute I've got to take pics and make a FS thread, I went back to the stock HU and added a Motorola wireless AA dongle to it until I figure out something better.
  8. Sep 3, 2024 at 11:19 AM
    NYK
    NYK [OP] Member
    Damn sorry I wasn't able to help. I want to add another camera but I'm not sure if I'm able to do it with this head unit so I might be in the same boat. So far it's been good just some issues with connecting a different Bluetooth device and delay in auction but it does the job for me atleast. It's nice having wireless CarPlay but if I can't add another camera might have to upgrade to something better I've been looking into this one https://aucarauto.com/product/aucar-tesla-android-13-13-8-car-radio-for-toyota-tacoma-2016-2023/
    atc250r[QUOTED] likes this.
  9. Sep 3, 2024 at 1:20 PM
    atc250r
    Orange County, NY
    No worries, I appreciate the help. :thumbsup::thumbsup:
  10. Oct 13, 2024 at 4:44 PM
    hunnersanners
    Hunter
    I have went through all of the settings and seemingly cannot find it. If you would take a photo or just type out a simple step by step it would be great appreciated!! TIA
