AVH-P4000DVD Wiring conundrum
Discussion in 'Audio & Video' started by sil3ncer7, May 5, 2010.
  1. May 5, 2010 at 8:32 AM
    sil3ncer7
    sil3ncer7 [OP] Gimme some mud n ull have a good time
    Stafford Tx
    06, white, TRD offroad, and muddy
    3" Toytec, 285/70/16. Installing, sliders, cb, firestik antenna, Workin for 285's, BedBox, and undercover winch when weather gets warm.
    So I am installing my HU and I got to looking and this doesnt make sense to me. I have the speakers hooked up and I am down to the 4 main power lines and this diagram (from pioneers install manual) shows the Yellow line goes to constant AND ground?
    Now I am not that great with electronics but that seems fishy... Why would you run 1 line to constant AND ground when theres a line already from the unit to ground??
    Should I just run it to constant and not worry about it going to ground?
    -Thanks
  2. May 5, 2010 at 8:33 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    I would bet that extra ground has something to do with a safety feature on this head unit.
  3. May 5, 2010 at 8:35 AM
    sil3ncer7
    Stafford Tx
    True, I am just uneasy about runnin the constant to both places..? again I could be wrong I just wanna make sure before I go blowing something up... :D
  4. May 5, 2010 at 8:40 AM
    McJosh
    McJosh avidoffroad.com
    Josh
    Chandler
    2005 Reg. Cab 5 lug Tacoma
    Pioneer AVH-p2300DVD, 12" Memphis sub and Alpine MRP-M650 amp, 32" BFG AT tires and KMC wheels, tinted windows, satoshi grille w/ stainless steel mesh, Avid front & rear tube bumpers, Cobra wx75 CB with 3' firestik, GaragePro bucket seats, FlowMaster 40 series, aFe CAI, Black head lights, LoJack and Autopage alarm installed, Avid sliders.
    it won't blow. If anything, the safety feature won't be bypassed. That's all.
  5. May 5, 2010 at 8:42 AM
    sil3ncer7
    Stafford Tx
    So your talking about the line that is supposed to be split off the main yellow correct?
    What are your thoughts on what I should do? just not run it off to ground?
  6. May 5, 2010 at 8:43 AM
    Dark Knight
    Jeff
    NC/SC
    follow the manual!! if the wire was there from Pioneer, wire it that way.
  7. May 5, 2010 at 8:45 AM
    McJosh
    Josh
    Chandler
    yup.
    I can't really say how to wire it. Every HU is differnt. I also have a pioneer but I had to use a relay..
  8. May 5, 2010 at 8:46 AM
    sil3ncer7
    Stafford Tx
    But the line from the HU doesnt have that split wire. Its just this diagram that shows it.... So should I add a splice and add one?
  9. May 5, 2010 at 8:50 AM
    McJosh
    Josh
    Chandler
    any youtube videos on this? That doesn't seem right.lol
    I keep going back to the manual and it's funky that it's grounded and that they wouldn't provide the splice. Try doing it without grounding the cable.
  10. May 5, 2010 at 8:52 AM
    sil3ncer7
    Stafford Tx
    What HU do you have? I wonder if yours shows the same thing ?
  11. May 5, 2010 at 8:53 AM
    McJosh
    Josh
    Chandler
    the avh-p3200
  12. May 5, 2010 at 8:54 AM
    Tacomagator
    Tacomagator Well-Known Member
    Its two separate wires...yellow (to the power)and black (to the ground) it says it right there.
  13. May 5, 2010 at 8:54 AM
    McJosh
    Josh
    Chandler
  14. May 5, 2010 at 8:57 AM
    sil3ncer7
    Stafford Tx
  15. May 5, 2010 at 8:58 AM
    sil3ncer7
    Stafford Tx
    But if you look at the yellow it splits and is run to both lines
  16. May 5, 2010 at 9:01 AM
    McJosh
    Josh
    Chandler
  17. May 5, 2010 at 9:02 AM
    sil3ncer7
    Stafford Tx
    pic of the wires im guessing? Ill have to later tonight when I get outa work.. Or maybe ill do it at lunch.. :D
  18. May 5, 2010 at 9:04 AM
    McJosh
    Josh
    Chandler
    no, just the "working" finished product. :)
  19. May 5, 2010 at 9:07 AM
    sil3ncer7
    Stafford Tx
    Oh, lol will do
  20. May 5, 2010 at 9:08 AM
    McJosh
    Josh
    Chandler
    lol. Good luck :)
