AVH-2400BT
Discussion in 'Audio & Video' started by Fuzzyman81, Mar 11, 2012.
  1. Mar 11, 2012 at 7:23 AM
    Fuzzyman81
    Fuzzyman81 [OP] The New Guy
    Jax, FL
    04 PreRunner TRD
    Anyone have any experience with this model? I see alot of other Pioneers floating around. Local stereo shop has a good deal on them.
    Thanks
    PS I did search and found nothing lol
  2. Mar 11, 2012 at 9:04 AM
    Coronach
    Coronach Well-Known Member
    OH! IO!
    2011 SR5 Double Cab Long Bed
    ARB Bumper, Toytec Boss coilovers, OME Dakkars, coffee stains
    I have one. Works great, easy install. Do a search for my username or AVH-P2400BT. I bet you left the "P" out.
    The only issue I have had so far is with the parking brake sensor. I tried to just ground the wire. Didn't work, I needed a relay. So I bought a relay. Works fine, but when I tried to use the autotune function, it still doesn't work. Apparently I need to wire in a switch for power to the sensor circuit, since the HU cuts power to the remote circuit when it goes into autotune mode. Other than that its been great.
  3. Mar 11, 2012 at 9:58 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Are you talking about the autoeq? If so, yes,only way I got that to work was by grounding the parking brake wire directly. Relay didn't cut it
  4. Mar 11, 2012 at 10:07 AM
    Coronach
    OH! IO!
    Yeah, auto-eq. I'm working on about 3 hours sleep right now, stupid Daylight Savings Time.
    I couldn't get the ground-the-wire technique to do anything. I read that the Auto-EQ needs constant power, which it won't get using the relay, since the relay is powered by the remote line, which the HU powers off during Auto-EQ. The solution, apparently is to wire in a line from the power supply that is switched (so you can turn it on for AutoEQ and leave it off for everything else). That, or actually hook up the e-brake line and use it like you're supposed to do ... but no one does that.
