Average cost for timing belt replacement?
Discussion in '1st Gen. Tacomas (1995-2004)' started by AZG1ANT, Aug 21, 2012.
  1. Aug 21, 2012 at 11:57 AM
    AZG1ANT
    AZG1ANT [OP] Member
    Arizona
    2004 Tacoma Double Cab TRD SR5 3.4l Auto V6
    Nothing yet...that's why I'm here.
    So I called my dealership to get an idea of what I should expect to pay for this. The service receptionist informed me they're running a special for parts and labor for $299. Sounds like a hell of a deal to me since I paid $725 to have the belt done on my old Isuzu Rodeo a few years ago. My timing belt is currently functioning fine, but I'm at 100,800 miles and read it's recommended to be replaced at 90,000. Figure I'll go ahead and get it done since I make long trips to the mountains and Mexico and would rather not get stranded halfway in between. What does a timing belt replacement typically cost?
    Thanks
  2. Aug 21, 2012 at 12:08 PM
    Grousehunter 12
    Grousehunter 12 Well-Known Member
    Ted
    Central Kentucky
    TRD 4x4 Off Road
    Tundra brakes on front
    The cost of parts is more than the quoted price on a job that is done right. My first thought is this price does not include new belts,hoses ,water pump,or thermostat. Add these on to their price and then you will know about how much the job is really going to cost.
  3. Aug 22, 2012 at 7:57 AM
    AZG1ANT
    AZG1ANT [OP] Member
    Arizona
    I've never heard of needing to change out a water pump, thermostat or hoses before. What do they have to do with a timing belt? I'm not a mechanic, but I just don't see the relation. Can you elaborate on the importance of why you feel those also need to be done? Thanks
  4. Aug 22, 2012 at 8:09 AM
    2012 Tacoma
    2012 Tacoma Well-Known Member
    Todd
    Illinois/Arizona
    2012 SR5
    Undercover Classic, TRD Skidplate, Wet Okoles
    Belts, hoses, water pump, t-stat are all easy to get to when the timing belt is changed so get it all done at the same time, this is typical on a lot of vehicles..saves you money down the road
  5. Aug 22, 2012 at 9:03 AM
    PkTaco
    PkTaco Well-Known Member
    David
    Zanesville Ohio
    Agreed. This is what I had done too.
  6. Aug 22, 2012 at 9:13 AM
    Chipskip
    Chipskip N7MCS
    Chip
    Green Ridge, MO
    07 Tundra
    ^ Do this.
    Murphy's Law is relevant here, you go in and replace just the timing belt, your water pump will go out in a very short amount of time... Damn that Murphy... and then you have to have it all ripped out and put back together = $$$ in labor.
    RockAuto has a complete kit, for your truck, with water pump (Kit Includes: Water Pump, Idler Bearing, Tensioner Bearing, Hydraulic Tensioner, Timing Belt) from $145 - $200, just the timing belt and idler is $60 - $110. Plus we get a discount on them.
    I bet that the dealership is not including anything in that deal except the timing belt and idler.
  7. Aug 22, 2012 at 10:30 AM
    Grousehunter 12
    Ted
    Central Kentucky
    TRD 4x4 Off Road
    This is the reason. I like to stick with O.E. for this job,no rebuilt water pumps or O.E.M. replacement kits. O.E. kit will cost you $350-$425. I would also have the cooling system flushed and new coolant added, also a good time to replace radiator cap. This is not cheap,I am. This saves money in the long run. I HATE being 300 miles from home towing a boat or having my dog in his cubby and being broke down in the mountains. Mr. Murphy always shows up at the worst times!
  8. Aug 22, 2012 at 10:34 AM
    98tacoma27
    Ben
    Not Beech Creek
    The belt is behind the pump so the pump needs removed to get to the belt. It's typically changed as a proacvtive measure. As far as the thermostat and hoses, I wouldn't change them unless they need it since they are cheap and relatively easy to change in a few minutes, where as the pump is not.
    I've seen where members have received quotes from delaerships/mechanics in the range of $600 to $1200
  9. Aug 22, 2012 at 11:52 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    I got price quotes from $745 to $1100.
  10. Aug 22, 2012 at 12:25 PM
    Boerseun
    Boerseun Well-Known Member
    Ferdie
    Sarasota, Florida
    2018 Tundra TRD Sport 4x4
    Upgraded 2002 Tacoma to 2018 Tundra
    I just got prices recently ( I am at 90,000 miles) and they ranged between $675 and $790 from 3 dealers and 1 independent garage.
    They all included the time belt, 3 drive belts, tensioners and pullies and water pump.
    I think the radiator gets drained when the water pump hose is disconnected, so it may not include an actual flush, but at least fresh coolant. The price did not include hoses or thermostat.
  11. Aug 22, 2012 at 12:30 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    my at the stealership cost 680 for T belt and water bumper and all new fluids.
  12. Aug 22, 2012 at 3:21 PM
    Robertgeejr1
    Robertgeejr1 Well-Known Member
    Robert
    Aorora, Ill, yeah!
    1996 Toyota Tacoma SR5 4x4
    I have done all the hi-pro mods for a life time, since I got this truck at a great price, I will be happy with showroom new.
    you do know that this is a truck forum, not something that fred flintstone drove?
  13. Aug 24, 2012 at 8:29 AM
    AZG1ANT
    AZG1ANT [OP] Member
    Arizona
    Why must there always be some smart ass tool making comments like this? You did read that I'm not a mechanic, right? I'm hear to learn...not insult others. To all those who did post something helpful I appreciate it.
    Anyhow, the dealership said the water pump was in excellent condition and it was either replaced with a previous owner and not reported or someone took really good care of the truck. $312 later I have a new timing belt and a vote of confidence that I found a diamond in the rough when purchasing this truck a month ago.
  14. Aug 24, 2012 at 9:24 AM
    Robertgeejr1
    Robert
    Aorora, Ill, yeah!
    I can understand why some on here scream use the search function.
    before and after i got my tacoma I spent many hours just reading.
    and you need to tell everyone on here the name and address of the dealership (Toyota?) that did a timing belt for a 3.4 for $312.00
    btw I am not a mechanic either, just dirty fingernails since I was 10.
    Thecoma234 and Noob95.5 like this.
  15. Aug 24, 2012 at 9:29 AM
    AZG1ANT
    AZG1ANT [OP] Member
    Arizona
    Desert Toyota in Tucson, Arizona. I was just calling for prices and the service receptionist told me they were running the special. I said, "sign me up!".
  16. Aug 24, 2012 at 9:44 AM
    Hawaiian05
    Hawaiian05 Well-Known Member
    Tony
    Boise, ID/ Hawaii
    2021 Army Green TRD OR 6mt/ 2002 4Runner Sport
    I just priced out the parts here from the local Toyota dealer, and parts alone are $275. Parts included T-belt, 3 drivebelts, water pump, coolant. I would also replace the thermostat at the same time, but it is easy to get to, so you could save the $20 for later if you'd like.
    As far as the water pump, just get it done now. I used to be a tech for Toyota and those water pumps are notorious for going out @ 80-110k. In my opinion, it's not worth doing the timing belt, then having the water pump leak 10k miles down the road. At that point, your paying for all the same labor to do the timing belt, plus an additional 1 hr labor to r&r the water pump. Just not worth it.
    As for the parts and labor special, I'd jump on it.
    Good luck!
  17. Aug 24, 2012 at 10:33 AM
    BamaToy1997
    Bill
    Navarre, FL
    Sounds to me like a special deal to draw in customers for attempted upsale work. Our dealership did that a lot. Draw in customers with a great deal to get them in the door, then work on trying to upsell things like tires, brakes, alignments, suspension repair, etc. Sometimes you don't make a sale, sometimes you do. Sounds like you got one heck of a deal!
  18. Sep 3, 2012 at 1:03 AM
    WiscTaco
    WiscTaco Well-Known Member
    Wisconsin
    Sr5 Trd 23.42 mpg
    Grey Wire, AFE Pro Dry S
    158,000 miles Looking to do timing belt, water pump, thermostat, upper and lower radiator hose, other 3 belts, upkeep. When should the upper and lower idler pulleys be replaced? There a way to see how they are doing, to save me the $180 in parts for another xx,xxx miles?
    Thanks
  19. May 15, 2023 at 8:49 PM
    TRD_IV
    TRD_IV Well-Known Member
    PNW
    I know this thread is a bit old, but im wondering how much I should be paying for a timing Belt, waterpump, and pulley replacement in 2023?
  20. May 22, 2023 at 9:36 AM
    Chipskip
    Chipskip N7MCS
    Chip
    Green Ridge, MO
    07 Tundra
    Seeing this is in the 1st Gen section, we will struggle with an answer. Best to do is call around to a few shops, dealers to see what they are charging.
    TRD_IV[QUOTED] likes this.
