Aux fuse block and relay wiring
Discussion in 'Technical Chat' started by Scrill, Apr 20, 2021.
  1. Apr 20, 2021 at 1:44 PM
    Scrill
    Scrill [OP] Member
    2019 TRDOR
    Hello electrical experts. I am wiring up an axillary fuse box to handle my accessories (GMRS, Fridge, Jackery, lights, compressor) and I would like to confirm I am doing it right.
    I want the aux fuse box to flip on only when the car is running. Is a relay the way to do this? how should I wire relay 86 to accomplish this?Taco aux power diagram.jpg taco aux power relay.jpg
  2. Apr 20, 2021 at 2:13 PM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    You do not need to ground the fuse block but a ground bus is part of the fuse block for your convenience.
    Check where your battery + is attached as I think you may be attaching it to the bus terminal and not the supply terminal that will run through your individual fuses.
    You will want to trigger your relay with an ignition source. Easiest would be in the under hood fuse box with an add-a-fuse tap. There is good info on an ignition source in the switch pro threads so just check that your relay trigger doesn't require a bunch of current and size the add-a-fuse properly.
    Scrill[OP] likes this.
  3. Apr 20, 2021 at 5:38 PM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    Yeah on that fuse block, the top terminal (under the yellow clip thing) is the ground side, and the bottom is the positive side
  4. Apr 20, 2021 at 8:07 PM
    Scrill
    Scrill [OP] Member
    2019 TRDOR
    Thank you for pointing out the +/- issue, and pointing me in the right direction on the add-a-circuit.
    Updated diagram:
    L3GO_MAST3R likes this.
  5. Apr 20, 2021 at 8:42 PM
    ShimStack
    Ben
    NC
    What you have drawn will work. I would likely take the main ground for the bus straight to the battery since it's so close anyway.
  6. Apr 21, 2021 at 8:43 AM
    MR5X5
    MR5X5 Well-Known Member
    Are you also planning to run dedicated relays for some of the heavier loads?
  7. Apr 21, 2021 at 11:11 AM
    Scrill
    Scrill [OP] Member
    2019 TRDOR
    Yeah, anything that I want to control with a switch I will add an additional relay for, like my compressor and aux lights.
    My GMRS, 2 additional 12v sockets powering my fridge and jackery, and my additional USB charging ports for my dash mounted phone and tablet will go directly to this fuse block. Do you see any issues with this approach?
  8. Apr 21, 2021 at 12:24 PM
    MR5X5
    No. Sound approach. Something to consider is using an integrated fused/relay block vs just a fuse block and then a relay block or individual relays. Goal is to minimize wire length runs for high current devices so you can avoid wrestling heavy gauge wire everywhere. Looks like you might already be parts committed though.
  9. Apr 21, 2021 at 2:43 PM
    Scrill
    Scrill [OP] Member
    2019 TRDOR
    Oof, yeah parts committed for sure haha. Excellent tip for any future readers of this thread though.
  10. Apr 22, 2021 at 7:32 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    Looks good except for the aux fuse block ground, don't connect it to the fuse box mount, you'll get a much better ground connection by going right to the battery negative terminal. You don't "need" to ground the aux fuse block if you aren't bringing your grounds for the devices back there and you can just ground to the frame by the device you're wiring up. Something else to consider to save on a little wiring.
    Scrill[QUOTED][OP] likes this.
  11. Apr 22, 2021 at 8:32 PM
    Scrill
    Scrill [OP] Member
    2019 TRDOR
    Appreciate all the help I got on this thread. Got everything installed and it works as intended. Now to add the accessories. PXL_20210423_032514264.jpg
    Aws123 and 6 gearT444E like this.
  12. Apr 24, 2021 at 8:44 AM
    ginger4x4
    ginger4x4 Member
    Brian
    southern ca
    2017 4x4 Tacoma
    2.5 Icon extended CO up front Icons Delta Joint UCAs 2.0 Icons with resies and Icons leaf springs set at medium in the rear Total Chaos Bed stiffners Arb single air compressor in drivers side cubby on EE bed side mount.
    looks great man. ive got a few questions for you though, im thinking of doing a similar set up, what gauge wiring did you run to connect everything ive heard 6 is a good size, but ive also heard of people doing 2. what would be the purpose of going so big?
  13. Apr 24, 2021 at 9:13 AM
    Scrill
    Scrill [OP] Member
    2019 TRDOR
    I am not an expert, but I used 6ga.
    It's cheaper and easier to move around and I don't think I'll be requiring more than the 55 amps it's rated for.
    People might use 2 gauge if they require 115 amps.
    Aws123 likes this.
  14. Mar 29, 2022 at 3:10 PM
    nahman
    nahman Member
    Mid East Coast
    2017 Grey Tacoma SR
    Swing Gate Storage Bins/Fog Lights/baja rack/meso switch panel/arb compressor/mud guards
    Which block from this list would have the relays included already? And is there anything else to consider when choosing that method? https://www.bluesea.com/products/category/16/61/Fuse_Blocks/ST_Blade
  15. Mar 30, 2022 at 1:38 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
  16. Apr 9, 2022 at 9:26 AM
    MR5X5
    It comes down wire length. This is a handy calculator.
    https://www.wirebarn.com/Wire-Calculator-_ep_41.html
    InCogNeatOh Parts likes this.
