Aux cable to factory tape deck
Discussion in '1st Gen. Tacomas (1995-2004)' started by jsidis, Apr 25, 2017.
  1. Apr 25, 2017 at 12:05 PM
    jsidis
    jsidis [OP] Active Member
    Boulder, CO
    Taco
    six inch lift
    I've got long drive coming up next month and want to tap into my digital music and figured Id make it look good by installing a dash-mounted aux port.
    Only problem is, I cant figure out where to solder it down. There's a few Ho-Tos floating around the forums, but they have a CD player, so the board is a little different. I could do trial and error, but am hoping someone more electronics savvy than I might save me the trouble... Its a Dolby unit A56410.
    Here's what Im looking at: https://ibb.co/ftUvD5
    The tape head ribbon has 5 "wires" and connects to the main PCB through the pictured ribbon port (CN803, just below the two pots). Below that, not in a square is CN802, a 7-pin ribbon also connected to the tape unit, FYI.
    There are two pots (VR 801 and VR 802), two "test points" (tp 801 and tp 802).
    Where do i solder up my 3.5 mm wires?
    Here's the view from the other side of the pcb. Squares are drawn around the 5-pins from the ribbon (CN803) and the 3 solder points for each pot: https://ibb.co/fsdGLk
    ChadsPride likes this.
  2. Apr 25, 2017 at 12:06 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
  3. Apr 25, 2017 at 12:15 PM
    jsidis
    Boulder, CO
    Taco
    six inch lift
    Fixed images. Thanks
  4. Apr 25, 2017 at 12:17 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Maybe @mechanicjon could help you
    If you don't figure it out, they make cassette tape AUX cord adapters for like $5.
    tomwil likes this.
  5. Apr 25, 2017 at 12:21 PM
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    hx35 turbo, AEM F/IC, Transgo, custom converter, CalTracs, Elocker, 2-4" drop, 4x4 conversion (2023) on a new purple powdercoated fram, 255/55r18 street, 255/60r16 M&H Racemasters, 7.6 at 91
    dgshelto and T@co_Pr3runn3r like this.
  6. Apr 25, 2017 at 12:23 PM
    jsidis
    Boulder, CO
    Taco
    six inch lift
    Yeah, I own one. They sound and look crappy, IMO, but work in a pinch.
  7. Apr 25, 2017 at 12:25 PM
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    inb4 somebody mentions an "fm modulator". Those are just the worst...
    SellyKlater likes this.
  8. Apr 25, 2017 at 12:28 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Oh my god I bought a cheap one from China for my Benz. It sounded like I was listening to someone playing the radio over a CB radio with a broken antenna.
  9. Apr 25, 2017 at 12:28 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Any reason why you don't just get a new stereo? They're pretty cheap.
  10. Apr 25, 2017 at 12:30 PM
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    I hate the look of all aftermarket. I prefer an upgraded factory "stealth" look. I've spent considerable money adding aux and amp preouts for a hidden amp and sub install. The factory units are so easy to use and look great. I know you weren't asking me, JMO
    COMAtized99 and BartMaster1234 like this.
  11. Apr 25, 2017 at 12:49 PM
    jsidis
    Boulder, CO
    Taco
    six inch lift
    I dig the factory look. Plus, I thought this wld be a fun project and learning exp.
    COMAtized99 likes this.
  12. Apr 25, 2017 at 12:57 PM
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    I commend you on the cheap learning experience. What you're doing has been done and well documented on other makes and models for sure. I'm sure others would use this love to do this cheap mod if it were well documented (like you might have the ability to do). Keep googling, I'll bet you can figure it out.
  13. Apr 25, 2017 at 2:02 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    I'm not sure if the cassette tape signal is the same as an aux input signal. As far as decoding it. I'll have to research that one.
    BartMaster1234 likes this.
  14. Apr 25, 2017 at 2:12 PM
    mechanicjon
    Jon
    Scottsdale Arizona
  15. Apr 25, 2017 at 2:22 PM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Here's what I did.............Grom audio USB/AUX/IPOD & Rostra Bluetooth. Grom in CD1 in back of oem 6 disc non-JBL with black face/silver button mod & 2012 oem lit vol/tun knobs. Rostra Bluetooth plugs into into stereo wiring harness. button is left of steering wheel. mic ran up above rr view mirror. Both are P&P situation. USB under left AC vent and AUX down in lower dash panel slot and IPOD connection just run into glovebox.
    pic of 2012 of vol knob.....
  16. Apr 25, 2017 at 2:25 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    You had a cd in port on back of stereo correct?
  17. Apr 25, 2017 at 2:28 PM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    yes-- CD1 port looks like the lower left one in the pic........
  18. Apr 25, 2017 at 2:31 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    OP doesn't have that.
  19. Apr 25, 2017 at 2:34 PM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    awwww fuck, just noticed gen 1 thread, sorry, focused on what I thought was familiar HU number in first post.
    I would think Grom would have something that'd be P&P for 1st gens too tho........
  20. Apr 25, 2017 at 2:55 PM
    jsidis
    Boulder, CO
    Taco
    six inch lift
    Im not looking for a plug'n'play solution, but something more like the following. Only prob is that mine doesnt have clearly marked "L" and "R" solder points anywhere: https://youtu.be/bRIswrodoM8
    This mod below is close, but I dont know which solder points on the pots to try b/c he didn't get a good pic of it. Also not sure if I'd get the same results since his is a diff. model.
