Autozone brake calipers
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tomrad, Nov 24, 2022.
  1. Nov 25, 2022 at 3:42 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    You need the metal ring - return for a diff one. Who knows what they did inside the caliper. Another unskilled person doing them or a temp or new hire or all of them.
    Bolts are 17 and 14mm and there is only an o-ring between the 2 halves where the fluid passage is.
  2. Nov 25, 2022 at 4:51 PM
    tomrad
    tomrad [OP] Well-Known Member
    2008 Tacoma Access cab, automatic 4x4
    After doing a bunch of searching, I've concluded the Duralast calipers (at least some) are remanufactured by BBB (NuGeon). Some of their 13WG Toyota calipers have the metal retainer, some don't. Why, I have no idea.
  3. Nov 25, 2022 at 8:52 PM
    H4I2G0H
    H4I2G0H Access, 6spd
    PNW
    22 TRD SPORT, MT
    4EBCCDCD-AEF1-4A2C-B37E-911C034E6D1A.jpg BFAB3756-4011-492D-83AF-0E82FE071A8D.jpg Waiting for these to start my brake project. Had come of a totaled 20 taco. My 13 taco has seized pistons inner driver side. Figured while the calipers are off, I might as well replace rotors and pads as well. Stop tech slotted rotors with stop tech sport pads.
