Autozone brake calipers
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tomrad, Nov 24, 2022.
  1. Nov 24, 2022 at 4:44 PM
    tomrad
    tomrad [OP] Well-Known Member
    2008 Tacoma Access cab, automatic 4x4
    I replaced my right front (4 piston) caliper in April of this year with an Autozone rebuilt caliper. Looked nice, shiny gray coated and has held up well without rusting. Even has a bushing, copper or brass, inside to help the brake line seal up easily.
    This caliper worked great until the other day, and now it's leaking, truck pulls to the right intermittently (not too often, though).
    Lifetime warranty, but annoying to have to change it after just six or seven months. Anyone have recent experience with Autozone calipers? I'm not sure, but the color of these reminds me of Nugeon brand.
    Thanks, and hope everyone had a nice Thanksgiving!
  2. Nov 24, 2022 at 4:53 PM
    Clearwater Bill
    Billy
    Largo Florida
    All remans are the same pig in a poke
    Yes lifetime is good, but a pain as you say.
    fb40dash5 likes this.
  3. Nov 24, 2022 at 5:08 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    You can spend a “lifetime” replacing it, over and over again.
    At some point, the cost of labor (yours or someone else’s) will exceed the cost of a quality part.
    Warranties make you feel good, they didn’t guarantee that the part is of good quality or free of defects.
    Seriously a warranty has nothing to do with quality.
    69 Jim and MikefromCT like this.
  4. Nov 24, 2022 at 5:13 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    I’m trying some carquest ones now, they seem fine, refurbed in Mexico. Would have gone oem but I needed them now and the nearest pair was 2 states away.
  5. Nov 24, 2022 at 5:53 PM
    TacoTuesday1
    FL
    Find a good condition used one, rebuild, and install
  6. Nov 24, 2022 at 6:00 PM
    Dayman Karate
    Dayman Karate Ruffling feathers and turning eagles into vultures
    Clay
    Central Alabama
    2001 4Runner, JKU Rubicon
    https://www.tacomaworld.com/threads/daymans-karate-class-but-you-wont-learn-nothin-4-link-lt-and-previous-iterations.755134/
    TnShooter likes this.
  7. Nov 24, 2022 at 6:02 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    It’s a limited lifetime warranty. They will replace it one time… not over and over for the rest of your life
  8. Nov 24, 2022 at 6:21 PM
    MARSHBUSTER
    MARSHBUSTER Well-Known Member
    Jim
    Alamogordo NM
    2005 SR5 4X4 Tacoma TRD
    Grill Gaurd/ Winch Bumper, Mile Marker 9000 LBS Winch, Custom Head Ache Rack, Custom Rear Bumper, Marathon Camo Max 4 Seat Covers
    Go With OEM on Brake Parts, You will pay now, But you will be happy later.
    69 Jim and tomrad[OP] like this.
  9. Nov 24, 2022 at 8:11 PM
    MARSHBUSTER
    Jim
    Alamogordo NM
    You can also try, Rock Auto, They offer close to OEM parts. And if you can't get OEM, Go to NAPA.
    No Shoes Nation likes this.
  10. Nov 24, 2022 at 8:16 PM
    MikefromCT
    MikefromCT Well-Known Member
    CT
    2013 TRD OR DCSB
    OME Bp-51; Relentless Armor
    https://m.youtube.com/watch?v=mEB7WbTTlu4
  11. Nov 25, 2022 at 6:09 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Sorry but that sucks as your OEMs are now gone.
    I also read the reviews and even went to Napa and of the 2 they had the coating was a thick mess so I did my own as no OEM available at that time.
    For others needing calipers only $20 for an OEM caliper seal kit is a cheap way to go but time consuming to really pull all apart and clean well.
    2 Gen Caliper Rebuild | Tacoma World
  12. Nov 25, 2022 at 6:17 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Where is it leaking from, piston seals or a body seam? According to South Main Auto, sometimes the bolts holding the caliper halves together aren't tight from the reman factory, so it's recommended to torque them before install.
    6Thick and tomrad[QUOTED][OP] like this.
  13. Nov 25, 2022 at 8:51 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    As you've unfortunately discovered, nice and shiny doesn't equate to a quality remanufactured or rebuilt part. (There is a difference there.) The process and the parts used are far more important. Also unfortunately, most rebuilt / remanufactured parts all come from the same folks and just end up in boxes with different labels on them. And the most important criteria for them is lowest possible cost for parts and process. Guess what that leads to?
    The only remanufactured parts I trust are actual Toyota remanufactured parts because they care about both the parts and process. Unfortunately, these aren't always available and almost always cost more.
    The only parts store remanufactured parts I trust are NAPA and only then, their premium line.
  14. Nov 25, 2022 at 9:22 AM
    tacobp
    tacobp Well-Known Member
    Bob
    North Carolina
    09 Tacoma, 2.7 automatic
    Installed a Pop n Lock,,That's it !..Bone stock
    I learned the hard way about cheap rebuilt calipers...Replaced them on the front end of my Jeep...within a year both failed....
  15. Nov 25, 2022 at 12:10 PM
    69 Jim
    69 Jim 4-word Jimmy
    PNW
    2013 Standard Cab 4x4
    This. Period.
    MARSHBUSTER[QUOTED] likes this.
  16. Nov 25, 2022 at 12:42 PM
    tomrad
    I'm going to check later today, but this sounds likely. Looked like it could be coming from the seam. I'm thinking it may be due to the seals shrinking in the sudden cold weather we're having. I put the caliper on in April when temps were 70-80 degrees.
    Did South Main recommend a torque value (approx)?
    Thanks for the info!
    Oh, I also picked up another reman caliper (just in case). I can return either the defective or new one for a refund. I did notice the newest one does not have the metal rings around the dust boots. Any reason to be concerned (other than me being ocd)? I guess the ones without the rings have a ridge they recess into.
  17. Nov 25, 2022 at 1:03 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    ^No FSM values for the caliper assembly bolts, just snug them up with a 8" ratchet.
    The FSM diagram shows the ring is for keeping the dust boot in place. If you decide to use the new caliper, you should transfer the rings over from the old caliper.
    tomrad[QUOTED][OP] likes this.
  18. Nov 25, 2022 at 1:18 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    You got exactly what you paid for unfortunately.
  19. Nov 25, 2022 at 1:40 PM
    tomrad
    Yeah, I know what you mean. However, my left caliper is a reman, several years old and been fine. Just never know, really.
    My old 99 F150 had an original caliper seize at 50k miles, about five years old. I replaced the pair with Fenco remanufactured.
    Over 200k miles and 19 years later, still using one of those calipers. I swapped one due to rust, but neither one leaked or seized.
    Too bad Fenco is out of business.
  20. Nov 25, 2022 at 1:53 PM
    tomrad
    Yeah, I guess the rebuilder figured "you don't need these." Unless the engineer who designed it declares the part unnecessary, I use it.
    Thanks, I'll swap them over if I use the new caliper.
