Automatic Door Locks when in Park
Discussion in '2nd Gen. Tacomas (2005-2015)' started by roberth2334, Aug 19, 2011.
  1. Aug 19, 2011 at 5:03 PM
    roberth2334
    roberth2334 [OP] Active Member
    Rob
    Western Ky
    2010 Tacoma DC TRD
    Hi everyone. I have been searching and can not find an answer to my question. Is there a way to make ALL your doors unlock automatically when you put the truck in park???? I had a 3/4 ton Chevrolet and it would unlock all the doors when you put the truck in park. That option is VERY convenient and is one of the things I miss most from a full size. It beats having to manually hit the unlock button when you get out and go to the other side of the truck. I have not trained myself to do it yet in the 6 months I have had the truck. I am hoping there is a way to do it. Any thoughts from the pro's??????
  2. Aug 19, 2011 at 5:20 PM
    roberth2334
    Rob
    Western Ky
    2010 Tacoma DC TRD
    Well that sucks.
  3. Aug 19, 2011 at 5:24 PM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
    dont lock them in the first place? :notsure:
  4. Aug 19, 2011 at 6:55 PM
    TerryS
    TerryS Well-Known Member
    Terry
    Cape Cod, Mass.
    '24 Celestial Silver DCLB SR5
    OEM cast aluminum running boards & tonneau cover.
    There's a procedure for reprogramming the keyless entry to lock the doors when the ignition key is turned on and unlock them when turned off. I've never tried it, so I can't vouch for it, but I have it if you want to try.
  5. Aug 19, 2011 at 7:00 PM
    Jetfixr
    Jetfixr What was I thinking??
    William
    Cocoa, Fl.
    Indigo Blue 4 door 6spd 07 4x4 TRD Offroad.
    TRD, filter and exhaust system. Red line hood struts, New frame, Truxedo cover, Spyder pro headlights, 3" lift, 17" wheels.
    My 4R does that but my Taco is a 6 spd so NOT happening!!!!!!!
    Jet
  6. Aug 20, 2011 at 6:29 AM
    jpmorrisvb
    jpmorrisvb Well-Known Member
    Jimmy
    Virginia Beach
    2014 Barcelona Red TRD Off-Road PreRunner
    Clazzio seat covers, KB Voodoo Powder Coated Tailgate Cap, OEM running boards, ImMrYo Rear-View Mirror Lift Bracket, 35% Tinted windows, EGR window vents, color matched door handles and tail gate lift, WeatherTech FloorLiners, OEM bed mat, sound dampening on rear wall and rear doors, on anytime foglight mod
    Unlike other vehicles .... like my wife's Accord ..... you don't need to shift the "lock" switch to open the doors .... the door handle unlocks and opens the door.
    I just noticed this last week when I was driving her car and realized that I had an additional step to perform to open the locked door.
  7. Aug 20, 2011 at 8:02 AM
    megillet
    megillet Resident Badass
    Mark
    Atlanta, GA
    2010 4x4 TRD Sport DCSB MGM 6sp
    I'd like to see this, and try it. Can you post it?
  8. Aug 20, 2011 at 8:25 AM
    TerryS
    Terry
    Cape Cod, Mass.
    Okaaaay, but, as I said already, I can't vouch for it. Let us know if it works or you get dizzy - whichever comes first:
    Programming option allows you to set the doors to lock whenthe key is turned on, and unlock when the key is turned off:
    1. Open the driver’s door. Remove the key from the ignition.
    2. Complete these steps within 30 seconds:
    a. Insert the key into the ignition switch
    b. Close, then open the driver’s door 2 times
    c. Turn the key from LOCK to ON 5 times, ending atON
    3. Programming option (select one of the following):
    a. Ignition controlled lock ON – close the driver’sdoor
    b. Ignition controlled lock OFF – close the driver’sdoor twice, leaving it closed
    4. Turn the key to LOCK. The programming is complete. If programming did not occur, start over.
  9. Aug 20, 2011 at 8:31 AM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    ^^ then click your heels 3 times and repeat... "there's no place like home, there's no place like home." :rolleyes:
  10. Aug 20, 2011 at 8:34 AM
    TerryS
    Terry
    Cape Cod, Mass.
    Yes, but first you have to kill the Wicked Witch of the West and defeat her legion of evil winged monkeys. And don't forget to wear the ruby slippers....
    Update: I found that this info was listed on this forum earlier here:
    http://www.tacomaworld.com/forum/1s...ntry-ignition-engaged-door-lock-function.html
  11. Aug 20, 2011 at 10:54 AM
    Hanz
    Hanz Well-Known Member
    Doug
    Long Island, NY
    2003 Tacoma DC 4X4 TRD
    LED Instrument lights
    I tried it. No joy with my 2008 DC.
  12. Aug 20, 2011 at 4:54 PM
    TerryS
    Terry
    Cape Cod, Mass.
  13. Aug 21, 2011 at 3:42 AM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    I wouldn't like that and would absolutely not want it when my wife is driving... but that's not your question I guess.
    Now, all doors LOCK when the put in D, or starts rolling? THAT I would like. To bad I couldn't get the one without the other.
  14. Aug 21, 2011 at 4:27 AM
    Hanz
    Doug
    Long Island, NY
    I appreciate you looking. I tried those instructions but I think those are to program transmitters and not change how the locks function.
    I think there's no automatic lock in drive and unlock in park for us. :(
  15. Aug 21, 2011 at 5:51 AM
    jpmorrisvb
    Jimmy
    Virginia Beach
    That would be a feature I would be interested in .... got to be a way. Ford had it in their cars 15 years ago.
  16. Aug 21, 2011 at 10:54 AM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    my truck's doors do not even lock unless i do it myself, i just drive around town with them unlocked though, if i am going down the highway i lock them though.
