Auto stop-start feature BAD for turbo
Discussion in '4th Gen. Tacomas (2024+)' started by Gfenza89, Jan 7, 2024.
  1. Jan 7, 2024 at 5:12 AM
    Gfenza89
    Gfenza89 [OP] Well-Known Member
    2024 Tacoma SR5 4x4 DCSB
    I’m trying to wrap my head around this auto Stop-start feature on the new 4th gen engines. Stopping the engine constantly can’t be good for the life of the turbo. I was always under the impression turbo vehicles should be left to idle for a few min after driving the vehicle before shutting it down. What’s your guys thoughts on this?
    2016Tacoman likes this.
  2. Jan 7, 2024 at 5:26 AM
    dickforce
    dickforce Well-Known Member
    If it is a problem, then Toyota should delay the auto off until the engine can safely turn off without cooking the turbo. I'd guess they thought of that, and either it isn't a problem or they have countermeasures in the software auto on/off control.
    TACOFLVRD, 22Coma6MT and Gfenza89[OP] like this.
  3. Jan 7, 2024 at 5:26 AM
    Gfenza89
    You’d really hope they did
    Dirty Harry and 2016Tacoman like this.
  4. Jan 7, 2024 at 5:41 AM
    Raylo
    Raylo Well-Known Member
    MD, USA
    2023 Tundra SR5 OffRoad; (2009 Tacoma - sold)
    All stock, except for audio and convenience add-ons
    In any case if it is like the new Tundras the feature is sensitive to the pressure on the brake pedal. It is very easy to keep the engine from shutting off by not pushing the brake pedal too hard. The Tundra pops up a message to remind you that if you want the engine to stop to press the pedal harder. Of course, you can also turn the feature off via a switch. But there is no need to do that. Just be mindful of the pressure on the brake pedal once you are stopped.
    manwithtools and Gfenza89[OP] like this.
  5. Jan 7, 2024 at 5:42 AM
    Gfenza89
    Yeah that’s true our Toyota Corolla cross is like that. But sometimes just can’t help it and push the pedal to hard. It’s a non turbo engine though so I don’t mind it as much
  6. Jan 7, 2024 at 5:43 AM
    Raylo
    MD, USA
    Sure, but that's not the end of the world or anything. ;-)
    Gfenza89[QUOTED][OP] likes this.
  7. Jan 7, 2024 at 5:46 AM
    Gfenza89
    I just think the gain/loss of constantly turning the engine off is completely unnecessary. Saving a tablespoon of fuel and putting extra wear on the engine
    AvalonTaco and treyus30 like this.
  8. Jan 7, 2024 at 5:51 AM
    dickforce
    Gfenza89[OP] likes this.
  9. Jan 7, 2024 at 5:54 AM
    Gfenza89
  10. Jan 7, 2024 at 6:41 AM
    OpeCity
    OpeCity Well-Known Member
    Long Beach, CA
    Someone better alert the engineers who definitely didn’t think of this
  11. Jan 7, 2024 at 7:03 AM
    Gfenza89
    Engineers aren’t perfect bud. Look at the hundreds of issues vehicles have accross many manufacturers . Most those issues are bad engineering. To top it off, the engineers are being forced to do things for the epa and emission standards regardless if its a good idea long term or not
    Dirty Harry and treyus30 like this.
  12. Jan 7, 2024 at 7:04 AM
    OpeCity
    Long Beach, CA
    I’m going to guess that they know about turbo coking. Hence why it’s a water cooled turbo and not just oil cooled.
    since they know about that, I’m also sure they know about the start/stop feature.
    maineah likes this.
  13. Jan 7, 2024 at 7:06 AM
    Gfenza89
    I’ll agree and maybe there is an electric type of pump that keeps coolant circulating through the turbo once the engine turns off. Maybe a person with more knowledge of the engineering will chime in for us
  14. Jan 7, 2024 at 7:07 AM
    OpeCity
    Long Beach, CA
    There is not an electric water pump. Thermal siphoning is probably what keeps water moving
  15. Jan 7, 2024 at 7:18 AM
    chuychanga
    chuychanga Well-Known Member
    2000 LX470, 2006 Tacoma Prerunner, 2023 Tacoma Off-Road
    I don’t think turbo cooling is a thing anymore. They have cooling systems built in that keep circulating after shutdown.
    Toyota first used auto start/stop back in 1974 and has had it on the Prius since 1997 and other ICE engines since 2009. I’m sure they’ve learned a thing or two in those two decades about turbo cooling, starter life cycles, alternator output, and whatever else keeps people up at night.
    tacoman45 and Gfenza89[OP] like this.
  16. Jan 7, 2024 at 7:27 AM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    The unintended consequence of AS/S will be people sutting still with not enough pressure on the brakes makeing it easier to roll. That's going to be great when you get rear ended sitting at a light, and you get pushed into the vehicles in front. Auto start/stop is hust one example of how silly the world has become.
    Dirty Harry likes this.
  17. Jan 7, 2024 at 7:30 AM
    batacoma
    batacoma Truck Wars
    I thought the turbo was not water cooled on the 2.4t?
  18. Jan 7, 2024 at 7:44 AM
    chuychanga
    You could always, you know… press the brake pedal hard enough. That engine is going to come back on. It’s seamless and damn near immediate. Noting bad is going to happen. You guys are inventing things to be worried about. This feature has been around a very long time.
  19. Jan 7, 2024 at 7:51 AM
    batacoma
    batacoma Truck Wars
    In a world of electronically distracted drivers, having vehicles that shut off when stopped isn't going to do anyone on the road any favors.
  20. Jan 7, 2024 at 7:54 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    But if I'm holding the brake pedal really hard and somebody rear ends me then the rubber on the bottom of my tires will get rubbed off on the pavement as I slide forward. So that isn't good either ..
