Auto Paint shop recs
Discussion in 'Southern California' started by Vjustinc, Nov 9, 2023.
  1. Nov 9, 2023 at 8:02 AM
    Vjustinc
    Vjustinc [OP] Talk Nerdy to Me
    City of Angels CA
    2021 Toyota Tacoma (it's white)
    Hi all
    Looking to get my TRD Pro skid plate done in a darker silver. Located by LAX area, hoping to find a shop local-ish. Leaning towards powder coat vs paint
    Been having a hard time getting any shop to get back to me with a quote even though they've asked me to email them a photo of the item.
    TIA:cheers:
  2. Nov 9, 2023 at 8:10 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Rattle can DIY. Job is probably too small for a professional shop.
    Vjustinc[OP] likes this.
  3. Nov 9, 2023 at 8:16 AM
    Vjustinc
    City of Angels CA
    Probably. Still hoping though. I only had one response which was it would cost $1000
    Malvolio likes this.
  4. Nov 9, 2023 at 8:25 AM
    ill ay
    ill ay I DO MAN STUFF
    The Valley
    2012 Pre Tacoma & 2017 4x4 SR5 Tacoma
    ^ As @rnish stated, do it yourself. Just do the prep work right and get the right paint. It's a skid plate, it's doing to accrue rock chips and blemishes. If you do it yourself, you can always touch it up as well. It's absolutely not worth the price to have a shop paint it and if you must, get it power-coated imho.
    I used high enamel dark metallic grey paint on mine years ago and I was completely satisfied with the outcome. I did an even 3 coats on mine and its held up very well.
  5. Nov 9, 2023 at 8:32 AM
    Malvolio
    Malvolio free zip ties for Stun
    SoCal Dumbgeon
    2017 DCSB SR5 2WD
    I’ll do it for $900. ;-) for 4Runners suggests Rustoleam high performance enamel working really well.
    Vjustinc[QUOTED][OP] likes this.
  6. Nov 9, 2023 at 9:35 AM
    Vjustinc
    City of Angels CA
    For anyone who has gone DIY what did you guys use? And how did you prep?
  7. Nov 9, 2023 at 6:31 PM
    rnish
    Tacoma 2nd gen
    If it’s really dirty wash it with soap and a scrub brush. Get the crud off. Dry it. Rough up the surface with some thing like a scotch pad, 320 sand paper and or a wire brush also works. It depends on what you got. Then clean it again with a mild solvent e.g., denatured alcohol. If the paint is sound you don’t need to prime but it won’t hurt if you do. I’ve been using the 2 in 1 (primer + top coat) combo spray paint. They seem to work
  8. Dec 20, 2023 at 5:25 PM
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    You won’t even notice the difference up close unless you crawl under between a rattle paint job vs professional paint. You’ll also save 950 plus dollars depending on how many paint can.
