Audio Test Tones
Discussion in 'Audio & Video' started by Chickenmunga, Jul 10, 2009.
  1. Jul 10, 2009 at 1:51 PM
    Chickenmunga
    Chickenmunga [OP] Nuggety
    Keizer, Oregon
    08 TRD Offroad DC 4x4 with stuff
    All the normal TW BS
    When you are tuning your amplifiers, you'll want to have some test tones on hand. It's fairly easy to create them, but took me a long time to get it working right. To save you guys the headaches, I'll share them here!
    Big thanks to Realmofexcursion.com for the original tones.
    Here's a list of tones that you will most likely need. I recommend contacting Mr Marv for instructions on how to properly use them.
    1 kHz, 0dB
    1 kHz, -3dB
    1 kHz, -6dB
    Left Channel Pink Noise
    Right Channel Pink Noise
    All tones are mp3 format, 1 minute in length.
    If you don't see it here, try looking at Realmofexcursion.com. Please contact me if there's any others you need.
    TreeFortRichard and Biscuits like this.
  2. Jul 20, 2009 at 3:37 PM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    thanks!
  3. Jan 12, 2010 at 6:13 PM
    Ocean's
    Ocean's Well-Known Member
    Thanks for posting!
  4. Feb 14, 2011 at 6:55 PM
    bookmonke
    bookmonke Well-Known Member
    Mark
    Jacksonville, FL
    2008 DC PreRunner Rugged Trail
    Guess I got to learn something new, thanks for the post.
  5. Oct 6, 2011 at 4:38 AM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
  6. Mar 26, 2012 at 6:05 AM
    blogs
    blogs Member
    Thanks for posting! [​IMG]
  7. Mar 23, 2014 at 8:31 AM
    gbreezer80
    gbreezer80 Well-Known Member
    Scott
    Dallas, TX
    07 Prerunner SR5
    Volant CAI w/Scoop, Borla Catback Exhaust, URD MAF Sensor Calibrator, Dual 10" LED Lights, Kickass Audio System
    ItalynStylion .... cannot get to the link you posted. can you please repost?
  8. Apr 13, 2014 at 9:30 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Chicken... Thanks again for tones. I have had them saved on my phone for ages, came in handy often!
  9. Aug 12, 2014 at 12:05 PM
    adrenalnjunky
    adrenalnjunky Well-Known Member
    West Monroe, Louisiana
    07 PreRunner SR5 DCSB
    billie 5100's front @ .85"
    For android users, search the Play store for "PA tone". Probably available for iWhatever too - I'm just not an apple guy.
    Tone generator app you can load on your phone or tablet, you can dial in whatever tone you're looking for if your source unit has aux in.
  10. Oct 29, 2015 at 4:27 AM
    mbrogz3000
    mbrogz3000 Well-Known Member
    Northern NJ
    2020 Toyota 4Runner Limited
    When I set my gains, I ended up following Steve Meade's process and used his own test tones. Below is the link.
    http://www.stevemeadedesigns.com/bo...ones-and-tuning-tutorial-all-new-links-again/
    You can go either full conservative or otherwise liberal when selecting the dB level of tones to play. I picked somewhere in between, and ended up setting them with my head unit volume at a 32 of 35. At 35, I verified that my source signal is still 100% clean, so I still have some headway.
    Ultimately for the normal interior speakers, I ended up backing them off significantly and setting them by ear rather than o-scope because they were way too loud and didn't seem balanced against the sub.
    EXO on youtube also has a good overview video that explains what test tone level should be used for the type of music, and shows the process of using the scope..but its covered rather quickly. Steve Meade fully lays out the whole process.
  11. Nov 12, 2015 at 4:47 AM
    ike3000
    ike3000 Well-Known Member
    This is the absolute best way to set gains. Not sure if it's mentioned in the SMD thread, but our ears are less sensitive to distortion at lower frequencies. That's why something like a -10dB track should be used for subs. I used a -5dB track for my mids and highs.
  12. Sep 6, 2018 at 10:39 PM
    PeeDeeTaco
    PeeDeeTaco Custom Title
    Effingham, SC
    2017 TRD Off Road 4x4 DCSB Blazing Blue Pearl
    5100 + OME 888 + Headstrong AAL SOS Offroad Concepts Streamline Winch Bumper Smittybilt XRC 9500 winch Method Race Wheels MR308 Roost Falken Wildpeak AT3W Image Dynamics speakers/sub Tacotunes Amp and sub enclosure
    Just be aware that MP3 test tones on USB will be at very different levels than WAV test tones on CD. I found out the hard way last night.
  13. Sep 6, 2018 at 10:50 PM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    What about a sine wave generator on a phone using bluetooth, wifi, or cast to a home avr?
  14. Sep 6, 2018 at 10:57 PM
    PeeDeeTaco
    Effingham, SC
    Bluetooth from a phone won't even generate a steady signal. I was getting a 10% oscillation when I tried Bluetooth with my Samsung Galaxy S8. There's no way to get an accurate voltage reading when it's constantly moving. The Entune changes levels quite a bit between each input. Also if you're using Bluetooth, are you sending a signal at 100% volume or 80%? Same for any other remote input.
