Audio Set-Up Advice
Discussion in 'Audio & Video' started by Big_Baada_Boom, Jun 9, 2022.
  1. Jun 9, 2022 at 9:56 AM
    Big_Baada_Boom
    Big_Baada_Boom [OP] New Member
    Brian
    2022 Mag Grey Tacoma
    3" Leveling Kit Torch Add-a-Leaf 33" BFG KO2 KSP Wheel Spacers (1.25 Front/1 Rear) Morimoto XB LED Headlights (Amber DRL) Morimoto XB LED Fog Lights Morimoto/MESO LED Taillights SPC Uppers
    Good morning/afternoon all, new to the forum here. I have a 22 SR5 and I'm in the market to upgrade the entire audio set up. I'm looking at Infinity Kappa 6X9 components for the front speakers and use the tweeters to replace the dashboard speakers. I'm also looking at Infinity Kapaa 6.5 for the rear speakers (non-component) and a JL Audio stealthbox 10" with a 5 channel JL amp w/DSP.
    For the rear 6.5's, the mounting depth for the Kappa's are 2 1/8". Is that going to still fit in the back? Also, would you all recommend sound deadening while the door panels are off?
    What are your thoughts on the set up? Would you recommend something else? I'm not really looking for crazy bass which is why the JL 5 channel is only pushing 75 x 4 @ 4 ohms and 300w RMS to the JL Sub (400 RMS max). Looking to see what you all think! My music tastes are all over the place so it could go from some metallica/Five Finger Death Punch to straight acapella type.
    Thanks!
  2. Jun 9, 2022 at 9:58 AM
    Aw9d
    Aw9d That one guy
    Infinity Kappas are okay. Might want to look into other brands. CT sounds have been good.
    JL is good but you pay premium for the name.
    soundman98 likes this.
  3. Jun 9, 2022 at 10:01 AM
    Big_Baada_Boom
    Brian
    I need a speaker that can handle 75w rms and even though I wanted to run JL speakers, a lot of the speakers can't match 75, normal is around 50-55rms. I've had infinity before and i liked them, but it's been over 10 years since I've been in the audio world. Not sure what's the updated speakers worth running these days lol
  4. Jun 9, 2022 at 10:08 AM
    Aw9d
    Aw9d That one guy
    As long as you signal is clean you can run double rms to speakers.
    My focal 6.5s are 80watts RMS.
    I push 220watts to them. Been running that way for 10 years now. I also use an o-scope to turn so I can ensure no distorted signal.
    Unless you're going to go balls deep I'd save some cash and go with non major brands as they charge more.
    @Man of Steel TRD can weigh in on CT sounds.
    Man of Steel TRD and GRNT4R like this.
  5. Jun 9, 2022 at 2:51 PM
    dolbytone
    dolbytone Well-Known Member
    South Carolina
    09 TRD Off Road
    This is poor advice IMO.
  6. Jun 9, 2022 at 3:40 PM
    Aw9d
    Aw9d That one guy
    How so?
  7. Jun 9, 2022 at 3:53 PM
    dolbytone
    South Carolina
    09 TRD Off Road
    It’s an irresponsible generalization. Having a clean signal does not absolve you of the need to be mindful of the electrical and physical limitations of speakers.
    I believe your advice in this context is a recipe for burned voice coils or damage from excursion, whichever comes first.
  8. Jun 9, 2022 at 4:03 PM
    Aw9d
    Aw9d That one guy
    Well I've been installing for over 25 years, did it professionally for many years, always followed this method of doubling RMS with my amps, always used an O-Scope and have still yet to fry any speaker other than the times I was competing in SPL.
    Speakers can take peaks.
    They can't take distortion.
    A guy wrote this years ago and I saved it in my email as it's a very good explination as to why you want to go over RMS of speakers when you buy amps.
    Suppose your speaker can take 100W RMS. Or that you decide to feed 100W RMS to your speaker ( your speakers should be able to take it). Now music contains peaks ( crest factor). There will be momentary peaks with +3dB or +6dB. You need amplifier output for powering those peaks. If your amplifier cannot provide clean power for those peaks it will run into clipping. Clipping always is bad. It is what damages your speaker most of the time by causing voice coil overheating.
    The intention of recommending twice amplifier power is to make sure that a speaker never sees clipped power.
    If you crank up a 50W amplifier all the way up a 200W speaker, there will be clipping and you might damage your speakers.
    If you crank up a 400W amplifier all the way up a 200W speaker you might damage the suspension or make the voice coil of the speakers bottom out.
    The right way is to use a 400W amplifier for a 200W speaker and to feed 200W into the speaker. The extra 200W is reserve for unclipped peaks. Speakers can take peaks.
    Man of Steel TRD likes this.
  9. Jun 9, 2022 at 4:37 PM
    Man of Steel TRD
    Man of Steel TRD Ignorance is the new normal
    Jeremy
    Gilbert, AZ
    2021 Ram Limited Night Edition, 91 300ZXTT, 90 Toyota Pickup ECLB
    Tow package, LED interior lighting, led low beams, led fog lights, led licence plate lights, OEM bed mat, OEM mud flaps, OEM chrome raised tailgate letter inserts, nerf bars, AVS ventshades. Complete Kicker audio system (4 channel amp, mids and tweets in the front, 2 ways in the back, 2 10 inch comp rt subs, Zxsum8, alpine pdx 1.600 boxes and amp rack by Mr Marv), Pop & Lock, Mobtown locking bed storage doors, Bilstein 5100s, Katzkin Leather interior, Redline Hoodstruts, Backflip.
    I do like cheap CT Sounds equipment but their tweeters always break where the wiring is soldered to the leads of the speakers so I have been shying away from them. CDT Audio is my new favorite "cheaper" speaker brand. They always have something on sale. Like most brands they do have expensive stuff but I recently picked up a super nice set of 6.5 components that even come with a 3 way crossover so you can add a 3rd mid driver.
    And on the speaker power handing thing, I'm with you on what you said and I have personally heard his setup @dolbytone. It handles ever single bit of power he pushes and doesn't overheat and fry even in the AZ heat.
  10. Jun 9, 2022 at 4:39 PM
    dolbytone
    South Carolina
    09 TRD Off Road
    So you said:
    I had an issue with that and then you go on to explain how you’re not actually pushing double RMS.
    Like I said, it was an irresponsible generalization.
  11. Jun 9, 2022 at 4:56 PM
    Aw9d
    Aw9d That one guy
    Irresponsible generalization coming form the guy who only says that and never backs anything up. Gotcha. And I said you can push double RMS, but when getting an amp you should always get double RMS power. If you buy good speakers you can push double RMS to them all day. Pro lines are designed for lots of power being consistently ran to them
    Ok you must be new to this. It's pretty simple to measure how much power you are getting out of an amp. There are also tools SMD sells that you can get the power rating of what your amps are pushing.
    https://geoffthegreygeek.com/unders...xt=With a constant sine wave,100/5 = 20 watts.
    Either way, do what you want and enjoy your stereo. I don't have time to teach beginners.
  12. Jun 9, 2022 at 5:23 PM
    Man of Steel TRD
    Jeremy
    Gilbert, AZ
    https://www.cdtaudio.com/main_series/cl/cl61.php
    They come in 2 or 4 ohm loads. They have a lot of great sounding speakers from what I have had experienced and really robust components but everyone goes with the bigger name brand stuff. I have installed 4 different sets of this brand of speakers in the last year and they are really nice.
  13. Jun 9, 2022 at 6:28 PM
    dolbytone
    South Carolina
    09 TRD Off Road
    This is what I install. You aren’t teaching me anything.
    LoMa, GRNT4R and Man of Steel TRD like this.
  14. Jun 9, 2022 at 6:59 PM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    I can’t hear anyone because my eardrums are blown from pushing 220w rms to my 93db sensitive speakers
  15. Jun 9, 2022 at 7:34 PM
    Man of Steel TRD
    Jeremy
    Gilbert, AZ
    Pretty
  16. Jun 9, 2022 at 7:39 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    overall agreed, but 'clean signal' is a bit too abrupt for a very in-depth topic. sorta like saying 'fishing is easy!' as you real one in. and this is coming from someone who ran 100w rms into 10w rms speakers for years without issues.
    it's not that hard to set up an amp that gives a clean signal of 30hz-20khz. but driving a tweeter with 30hz is where the problem will be. in this case, it wouldn't be a signal issue, it's a physical/thermal limitation of the driver design, which is a different type of distortion from the signal.
  17. Jun 9, 2022 at 7:42 PM
    Aw9d
    Aw9d That one guy
    Agreed. I always tuned with an o-scope and a few other tools. I ran crossovers for awhile then went to a network setup where the amp can be adjusted for the tweets and woofers separately.
    soundman98[QUOTED] likes this.
  18. Jun 9, 2022 at 7:45 PM
    Aw9d
    Aw9d That one guy
    Nice picture.
    Still you don't back anything up that you say so enjoy what you do.
    Sorry OP to shit on your question thread.
  19. Jun 9, 2022 at 7:56 PM
    MGMDesertTaco
  20. Jun 10, 2022 at 6:37 AM
    ZMan2k2
    ZMan2k2 “Hold my beer and watch this!”
    Richard
    ‘Berta
    06 Rad Red DCLB SR5, ‘25 SS Red Sport Prem. (on order)
    ZZIIIIIIIPPP!! :duel:
