ATV battery keeps going dead...and its a new battery. HELP!!!
Discussion in 'All Terrain Vehicles' started by RBoyd0325, Sep 11, 2012.
  1. Sep 11, 2012 at 1:31 PM
    RBoyd0325
    RBoyd0325 [OP] Well-Known Member
    Richard
    Alabama
    08 TRD Off Road 4x4 3" lift
    Ive got a Yamaha big bear 350, and it has a brand new battery in it, but after about 2 hours or riding and i shut it off, it wont crank back up cause the battery is dead. If it sat in my basement for a month and i tried cranking it, it would crank right up! It is only when i ride it, that it drains the battery. I can roll it down a hill and pop it into first and itll crank up and run until i shut it off again. Im sure the pull start would work too, it just doesnt work cause its missing a spring so i cant say:confused:. Im kind of in a bit of of predicament..... Can any of you guys help??? it would be greatly appreciated. Thanks
  2. Sep 14, 2012 at 11:51 AM
    Shadetree
    Shadetree Well-Known Member
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Locking Tailgate & Gas Cap and extra bed D-rings
    If the battery has been sitting with out being recharged for several months, it has sulfated and is probably not taking a charge. If it were my battery, I would load test the battery and the charging system.
  3. Sep 14, 2012 at 12:00 PM
    98tacoma27
    Ben
    Not Beech Creek
    If this only happens when riding, you have a short somewhere. It's possible that you may have an exposed wire in the harness "leaking" to the frame or to another wire.
  4. Sep 14, 2012 at 12:04 PM
    easyeatlanta
    easyeatlanta Artificial Intelligence beats natural stupidity
    Eric
    Memphis
    14 DC Trd Off Road
    yeah somewhere has to be a fault in the wiring, but that was quite obvious unfortunately wiring is a bitch to track down the problem
  5. Sep 14, 2012 at 12:07 PM
    Zac808
    Zac808 Custom User Title
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    Ck the fluid.levels. I had the same problem. Filled u with distilled water and it.held the.charge.
  6. Sep 14, 2012 at 12:13 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Check it while running to see what kind of voltage you're getting at the battery. Not sure what a magneto should put out but??
  7. Sep 14, 2012 at 3:27 PM
    RBoyd0325
    Richard
    Alabama
    Its been doing this since the first time I installed the brand new battery. Now iver just learned to not shut it off while riding and just put it on the charge when i get home. Except for the times when it gets bogged down of something while riding and shuts off........then i rely on a buddy to push me while I pop it into first. lol but thanks guys, i guess ill put a voltage meter to the terminals of the battery while its running and see what it reads. I hope its not the generator cause i looked at if i had to replace it and those can be preeetttyyyyyyyy pricey.......
  8. Sep 14, 2012 at 3:30 PM
    SaraLynn44
    SaraLynn44 Well-Known Member
    Sara Lynn
    Fresno CA
    08 PreRunner
    Engage Long Travel Deaver's 2 10" Kicker subs Fuel Rims Nitto Tires
    It could be a bad battery or you have a bad stator...
  9. Sep 15, 2012 at 2:22 PM
    RBoyd0325
    Richard
    Alabama
    Well i stuck a voltage meter to it and with the engine off it read around 13.5, ad when I cranked the engine and revved it up a little, it read around 14-14.1. Does thatean the stator is still good?
  10. Sep 15, 2012 at 2:25 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Yeah. I'm not very familiar with these types of charging systems but 14 volts sounds pretty normal for a 12v charging system.
  11. Sep 17, 2012 at 12:17 PM
    RBoyd0325
    Richard
    Alabama
    well i think i found the problem, up front there were 2 wires that had disconnected from some plug, i dont even know what you would use the plug for anyways because it was attached to the brush guard and when you took the cap off there were 2 prongs in it. But anyways, the wires would have power when you turned the key on (hint why it was dying while riding) and was bumping up against the frame. Thanks for you guys's help!
