AT to MT mpg difference?
Discussion in 'Wheels & Tires' started by batong_23, Jun 21, 2018.
  1. Jun 21, 2018 at 12:46 PM
    batong_23
    batong_23 [OP] vincedprince
    SoCal
    2017 white toyota tacoma trd sport
    how much difference in MPG will there be if you change your all terrain tires to Mud terrain as a daily driver?
  2. Jun 21, 2018 at 1:09 PM
    Shellshock
    Iowa
    Was looking forward to another Auto vs Manual thread and now I'm just disappointed
    But you MT to AT tires, you'll lose a few MPG. Its going to mostly depend on how big of a tire and how heavy it is. I think most people are in the 2-5 MPG loss range.
    tacoguy88, cblow5, Kraken207 and 7 others like this.
  3. Jun 21, 2018 at 1:14 PM
    batong_23
    SoCal
    WHEW!! the 4 or 5 MPG is alot!!! lol i want the aggressive look but not wanna lose alot on MPG since my truck is my daily car.
  4. Jun 21, 2018 at 1:16 PM
    Doggman
    Doggman Well-Known Member
    Alabama
    2017 TRD OR MT
    Same...they are usually entertaining.
    @batong_23
    The actual tread pattern doesn't make much difference for MPG. It's all about the weight.
    DustStorm4x4 likes this.
  5. Jun 21, 2018 at 1:17 PM
    TACOVRD
    TACOVRD I Identify As A Prius
    TW Addict
    AZ/WA
    2019 T4R ORP - Formerly 2013 DCSB OR Spruce Mica
    Workin' on it....
    Aggressive AT is the best compromise.
    Been pleased with my C load Duratracs but everyone has their fav (KO2, AT3 etc.)
    DubfromGA, DustStorm4x4 and Tocamo like this.
  6. Jun 21, 2018 at 1:18 PM
    jsi
    jsi Well-Known Member
    native earthling
    ^ditto^ I was looking for another MT vs AT fight :duel: I lost 2 mpg going from the stock Rugged Fails to BFG AT's. Going to mud tires is going to cost you at the gas pump.
  7. Jun 21, 2018 at 1:19 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    I soooooo want a K02 A/T 255/80 16 in C load! :spending:
  8. Jun 21, 2018 at 1:21 PM
    SWB Tacoma
    SWB Tacoma Well-Known Member
    Arkansas
    2017 Tacoma Limited DC AT SB 4x4
    I will stay with Auto. I had an S-10 one time that was a five speed manual. I put 95,xxx miles on it. I said never again.
  9. Jun 21, 2018 at 1:23 PM
    FuzzysTacos
    FuzzysTacos Well-Known Member
    Corey
    Wichita, KS
    Sold: 2017 TRD OR/2012 TRD Sport
    Reading is overrated. :anonymous:
  10. Jun 21, 2018 at 1:28 PM
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    What if it was a dual clutch paddle shifter!
    With MT tires (to keep it on topic)
  11. Jun 21, 2018 at 1:29 PM
    SWB Tacoma
    Arkansas
    Refer back to post #8. Autos are quicker anyway.
  12. Jun 21, 2018 at 1:33 PM
    Shellshock
    Iowa
    Get a set of Falken AT3W (they are an AT tire). That's what I put on my truck. They've got the look and performance but don't add a lot of weight. My fuel economy is basically unchanged and they are quiet on the highway (MT tires typically are very loud on road)
    Comb likes this.
  13. Jun 21, 2018 at 1:45 PM
    navin r
    navin r Well-Known Member
    2017 double cab short bed trd off road 4wd w/ premium pkg.
    On my 17 DCSB OR I changed the factory 265/70-16 street tires for General Grabber AT2 245/75-16; I think they're about the same weight as the factory tires, about 44 lbs I think, and the same height as factory; 30 1/2". A much better off road tire, they look very similar to AT KO2's, but not as heavy (also not as strong), I don't think they affected the mpg's much if at all.
  14. Jun 21, 2018 at 2:14 PM
    BeaverNation
    BeaverNation Well-Known Member
    Lies!
  15. Jun 21, 2018 at 2:18 PM
    Ram.95
    Ram.95 Well-Known Member
    2017 Black Tacoma TRD OR 4x4 Dallas Tx
    TRD PRO Bilstein Suspension HS Progressive AAL
    Been happy with my KO2's in a C load, at 48 pounds. I do have them in "skinnies" with a 255/75/17. I am sure having a little less rolling resistance helps. But overall the weight of an E rated tire is what will cause your MPG's to drop.
  16. Jun 21, 2018 at 2:47 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    You wont see a significant difference in MPGs assuming they are the same tire size. However MTs will wear significantly more.
    Most MTs are E rated so try to find a tire that is P or C rated. Unless you really need MT I wouldnt bother with them.
    If you want to look sexy just get some Duratracs
  17. Jun 21, 2018 at 3:26 PM
    phsycle
    phsycle Well-Known Member
    CA
    2-5 MPG seems way off. I'm assuming he's asking about the tread itself, not the size. Keeping the overall size the same, I bet you're only 1-2MPG, if that.
    Look at the BFG offerings. In size 265/75/16, both KO2 and KM3 are 53lbs. I'm sure there is slightly more rolling resistance with the blocky mud tread on the KM3, but shouldn't equate to 20%+ mpg loss.
  18. Jun 21, 2018 at 3:40 PM
    batong_23
    SoCal
    i have the cooper discoverer AT3 right now and i saw an add for a set of Federal Mud Terrain with about 70% thread life for $200. same size (265/70/17). Looking at the new ones, the feredal is about 15lbs heavier than the cooper, im just not sure if the 30% wear reduced a good amount of weight..
  19. Jun 21, 2018 at 3:50 PM
    BlakeM
    BlakeM Well-Known Member
    Blake
    Gonzales, LA
    2023 T4R.SR5.4WD.OMG.LOL.WTF
    I have 295/70/17 (MTs). I’m getting around 2-3 MPG less than when it was stock. I know this isn’t the comparison you’re asking for. Just sayin because I don’t think you’d notice much of a difference if you went from AT to MT in the same size tire. Maybe .5-1MPG. But hey, this is just a guess and I’ve been wrong before. :D
  20. Jun 21, 2018 at 4:11 PM
    Pot_Lickr
    Pot_Lickr Well-Known Member
    Ontario, Canada
    2017 Access Cab TRD Off Road
    I'm liking my Firestone's..
    I'm glad I went this route over an AT..
    I went with load E 245/75/16... My OR came with P265/70/16.. Very minimal difference in mileage..
    Traction on the other hand... Huge difference.. I go through some deep mud sometimes..
    DubfromGA and batong_23[OP] like this.
