Are you running the same size spare?
Discussion in 'Wheels & Tires' started by AllenOne1, Oct 26, 2019.
  1. Oct 26, 2019 at 6:56 PM
    AllenOne1
    AllenOne1 [OP] Well-Known Member
    Allen
    Nashville, TN
    2013 TRD Sport / 2018 TRD Off Road
    Gen2: Access cab platform, Gen3: MESO Puddle Lights, KTJO Power Folding Mirrors,
    If you have changed tire size from the OEM original size did you also upgrade your spare to match the size or are you just keeping the original spare.
    I just purchased 265/70-17s to replace the factory 265/65-17 but didn't upgrade the spare, should I have? Will the larger size fit in the original spot for the spare without modification?
    NightHawkTaco420 likes this.
  2. Oct 26, 2019 at 8:39 PM
    Taco_Coma
    Taco_Coma That's a lovely accent you have. New Jersey?
    South NJ
    2018 DCSB SR5
    It should fit the spare location there's some guys with way bigger tires in that location. I would get the same size spare if I were you, just less likely to mess something up if all the tires are the same size
  3. Oct 26, 2019 at 8:51 PM
    CGoss
    CGoss Well-Known Member
    Las vegas
    2006 rad red offroad
    It's a 13mm difference (.5inches) it's like running a worn down 265-70-17. You will be fine with your current spare.
    cruxofthebisquit and PvilleJohn like this.
  4. Oct 26, 2019 at 8:58 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    You're spare is fine. Remember those less than full size spares on most cars?
  5. Oct 26, 2019 at 9:04 PM
    NYCTaco52
    NYCTaco52 Half man, half goat
    Somehow known as Stewart, but named Ben
    Ft Lauderdale, FL
    2022 Subaru Ascent
    Just make sure if you have to use a spare, you aren't on locked diffs
    whatstcp and TrdSurgie like this.
  6. Oct 26, 2019 at 9:05 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    It's the diameter that matters. If two tires that share a differential are different, it's not ideal.
    I would prefer a proper size spare.
    Trucknorris and Hardscrabble like this.
  7. Oct 26, 2019 at 9:06 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Depends on what you do with the truck. If it's your DD and always within 50 miles or so from a tire shop, keep the original spare. You can always disable VSC and TRAC if they act up while you're driving on the spare. If you take long trips off road, overland, etc., get a matching spare.
    Navigator1 likes this.
  8. Oct 26, 2019 at 9:34 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    If the diameter doesn't match you can mess up your differential if you run the mismatched spare on the drive wheels. Put the mismatched one up front if you must.
    A lot of cars come with non-matching spares but the diameter is the same. And they were not meant to be run regularly, just for emergency.
    Spend the extra $200 or whatever it costs and get a matching spare, worth the peace of mind
    Hardscrabble and 0xDEADBEEF like this.
  9. Oct 26, 2019 at 11:36 PM
    Southern_Partisan
    Southern_Partisan Member
    2019 Tacoma TRD Off-Road DCLB 4x4, Magnetic Gray Metallic
    TRD Pro Grill; Custom Headache Rack; Expedition One Front Bumper; Fab Fours Rear Bumper; KC Hilites Gravity G4 LED Amber Fog Lights
    Good advice.
  10. Oct 27, 2019 at 7:44 AM
    AllenOne1
    Allen
    Nashville, TN
    It's a daily driver for the most part and it is unlikely that the spare will ever hit the ground. In a perfect world I guess I would get a matching wheel and tire and rotate all 5.
  11. Oct 27, 2019 at 7:45 AM
    singletrack_ftw
    singletrack_ftw “I chopped the wrong leaf!”
    Tyler
    AZ
    ‘08 TRD OR 4wd
    https://www.tacomaworld.com/threads/singletrack’s-‘dad-shred-build-thread’-i’m-just-doing-it-for-the-kids.619250/ Sos offroad sliders (kickout + filler) Sos offroad full belly skids (steel) Sos offroad front recovery point Sos offroad concepts HC rear bumper with bedside kickout tubes Marlin Crawler LCA frame brace kit Trail Gear rear diff cover Bilstein 5100 + OME 885 Total Chaos UCA BILSTEIN b110 OME Dakar standard pack Wheelers Ubolt flip kit Wheelers Superbump f/r Wheelers SS extended brake lines FN five star 16x8 -25 Milestar Patagonia MT 315/75r16 Custom projector retrofit (acme super h1 + morimoto 4300k) Baja Designs S2 sport ditch pods on CBI ditch pod mounts Amazon AMAK rock lights CMC CB radio hardmount
    Yes. 315/75r16 spare on matching spare wheel. I rotate it into my tire rotations every 5k miles.
    Hardscrabble likes this.
  12. Oct 27, 2019 at 5:39 PM
    Lunchmeat79
    Lunchmeat79 Well-Known Member
    Kansas
    '18 Off Road
    check ebay for used tires. I got my full size spare duratrac on there for like $50 shipped. 14/32" and only two years old and no repairs. Also tire shops might keep a look out for a stray that comes in your size
  13. Oct 27, 2019 at 5:57 PM
    singletrack_ftw
    Tyler
    AZ
    ‘08 TRD OR 4wd
    If your new tires are a big difference from your factory spare, it’s always a good idea to go ahead and match the sizes depending on how you use your truck. Even if you have 33’s and you use the factory spare in a pinch you won’t die, but your truck will be a little wonky for a minute while you wait to get a matching replacement tire
  14. Oct 28, 2019 at 9:03 AM
    pro2aaf
    pro2aaf Well-Known Member
    Anyone know how big of a wheel/tire the factory spare location allows for?
  15. Oct 28, 2019 at 9:11 AM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    I have 265/75-16 tires and a 235/85-16 spare.
    Same diameter but that spare can be used for my trailer and gives me 1.2” more ground clearance and tucks up behind my trailer hitch so it doesn’t get scraped when I drag the tail end. Works for me.
  16. Oct 28, 2019 at 9:26 AM
    AllenOne1
    Allen
    Nashville, TN
    Now that is thinking the whole thing through, I like that.
  17. Oct 28, 2019 at 9:31 AM
    2DaMtns
    2DaMtns Well-Known Member
    2011 TRD Sport DCLB in MGM
    Lift, tires, stuff
    I have a 255/80/17 in the stock location with no issue.
  18. Oct 28, 2019 at 10:00 AM
    BuzzardsGottaEat
    Some Toyotas
    Round tires
    its a free lift in the rear ha.
  19. Oct 28, 2019 at 11:48 AM
    pro2aaf
    Tight fit or was there some room to spare?
  20. Oct 28, 2019 at 11:52 AM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    I too am in the "matched" diameter spare group:
    285/75/16 = 285/70/17 with the bracket moved.
    SandyTaco4x4 and asuchemist like this.
